Thread: Floor finish (timber) not showing in render view
    July 28, 2019
    03:21 PM
    Hello! I'm trying to render my view in Revit, but for some reason my timber flooring is not showing. I've attached screenshots of the properties and settings and hopefully someone can help me!
ID:	37084   Click image for larger version.
ID:	37085   Click image for larger version.
ID:	37086   Click image for larger version.
ID:	37087   Click image for larger version.
ID:	37089   Click image for larger version.
    1,628
    07:21 AM
    The only thing I can think of is that your wooden floor is inside the floor below it. You wooden floor is at 0 from the level and I asume you have a concrete floor at the same level as well. Try moving the wood 10mm or so up and see what happens.
    July 26, 2019
    DFW, Texas
    67
    12:21 AM
    Yes, that was my first thought, too--that the finish floor was part of the Core, and not above that level.
    You might check to see which Bump map is applied to your Render material, too.
    July 28, 2019
    03:21 PM
    Thanks for the replies. I kind of cheated with this one so I actually only have one flooring and put the timber finish on it.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,572
    11:21 PM
    It looks like the floor is existing. Is the view (and the furniture & casework) new? If so, you likely need to change the views phase filter to "Show Complete". Unless you've changed settings, by default existing elements (which look like your walls, floor and ceiling) will use the material set in the phase overrides.
    6,387
    01:21 AM
    Quote Originally Posted by jmk View Post
    This is my guess also.
    July 28, 2019
    03:21 PM
    Thanks! I'll give that a try
  1. Floor highlight in floor plan view not showing
    By m b in forum Architecture and General Revit Questions
    Last Post: September 5th, 2018, 01:30 PM
  2. Continuous finish from floor to wall to floor
    By Tom Newsom in forum Architecture and General Revit Questions
    Last Post: June 17th, 2017, 12:54 PM
  3. Callout view showing floor beneath, but sheet it is referencing is not...?
    By Dynamek in forum Architecture and General Revit Questions
    Last Post: May 28th, 2015, 12:10 PM
  4. View showing wrong floor
    By DaveP in forum Architecture and General Revit Questions
    Last Post: April 7th, 2015, 10:32 PM
  5. Finish Render
    By andyl0193 in forum Architecture and General Revit Questions
    Last Post: May 24th, 2012, 06:27 AM
