Results 1 to 9 of 9
Thread: BMU (Building Maintenance Unit) - Advice Req'd on Making a Family
    January 12, 2011
    London, UK
    572
    02:54 PM
    Hi All,
    I'm going about making a BMU family for the rooftop of a high-rise project we're working on. I've tried looking on the forum but no mention of such a thing.
    The BMU itself will be a mechanical equipment family; could be any number of family types but I want to control its visibility with other mechanical equipment on the roof.
    The difficulty I am having is how to model the rail / track that the BMU sits on.The rail / track normally follows the edge of the parapet, so it is dependent on the edge of the roof.
    For making the family I am working along these lines:
    1. The mech. eqpmt. family BMU (with a parametric gondola) hosted on #2 below:
    2. The rail / track made from a profile following a line drawn as per roof edge sitting on #3 below:
    3. Sleepers made as arrayed (either in the family with global parameters as per Revit Cat's recent blog) or arrayed in the model. These arrays will have to be set up manually as I can't understand how to run the array to follow the rails in #2 above.
    Question: Does anyone have any ideas of how to make a rail / track with arrayed sleepers that follow a line ?
    Image below showing intention:
Name:	BMU PLAN & SECTION.JPG
    Thank you in advance.
    6,287
    09:54 AM
    Assuming you don't mind having multiple families for the track assembly - the straight segments of the rail & sleepers can easily be arrayed in the family and controlled with some formulas. This could be a line-based family or instance based, depends on what functionality you want / need later on. The radius can also be done this way, but it gets complicated quickly. If your radius is the same everywhere, it might be easier at first to just make that piece static.
    January 12, 2011
    London, UK
    572
    02:54 PM
    Hi Chad. Interesting. So to summarize your suggestions, you're saying I make a toy railway type of arrangement with straight sections, that I can set the lengths to, instance-wise, and curved bits with either fixed radii (very likely this will be the option) with an instance-angle or an all in one variable-radii curve if I have the time to make it geometrically.
Name:	BMU Toy Railway Pieces_1.jpg
    Nice one = sublime !
    Should have thought about that. Whether in Revit or wood, plastic or metal, it's been being done for decades for kids.
    4,426
    02:54 PM
    I'd be inclined to use a railing and let the BMU subbie to the rest.
    January 12, 2011
    London, UK
    572
    02:54 PM
    . . . and let the BMU subbie to the rest.
    Hey, contractually-wise you're totally right.
    Our team are taking this to DD (Stage-3 / 4) only and handing over to our partners and we'd like to make our drawings look top-notch for that team and the costing team, etc., and to convey as much design intent on our sheets as possible before the handover.
    We've got the facade maintenance consultant's CAD layout and equipment drawings and I know your answer applies to all of my responses too but this is something that has been a wish-list family for almost a decade now and I finally have a chance to complete it, so pleeeeeaaaase don't stop me !!!!!!!!!!!
    January 12, 2011
    London, UK
    572
    02:54 PM
    I'd be inclined to use a railing . . .
    Another good idea - can I host the BMU to a railing ??? TTGT (TimeToGoogleThat)
    3,061
    06:54 AM
    +1 for railing - use the Support sub-feature for Handrail type for the anchor/supports and you can move them anywhere along the railing you need them after using a basic spacing rule to place them roughly. A railing could "host" the BMU if it is a support too, or post/baluster.
    January 12, 2011
    London, UK
    572
    02:54 PM
    +1 for railing . . . A railing could "host" the BMU if it is a support too, or post/baluster.
    Thanks for that that - so many good ideas today !
    6,287
    09:54 AM
    Your summary of my post was pretty much spot-on, although after reading through what everyone else said I would lean towards a railing as well. There are tradeoffs either way, it is just a matter of where you place your effort
  1. Building Coder: Unit Abbreviations
    Last Post: August 18th, 2017, 11:45 AM
  2. Advice RE Long-term Model Maintenance (Facilities Mgmt)
    Last Post: March 30th, 2017, 01:00 PM
  3. Building Coder: Mapping Display Unit Type to Unit Types
    Last Post: November 5th, 2013, 11:15 AM
  4. Building Coder: Unit Abbreviations
    Last Post: November 4th, 2013, 10:15 AM
  5. Building Coder: Revit Add-in Unit Testing
    Last Post: July 12th, 2013, 01:15 PM
