Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: Little Revit Things that Drive Me Crazy
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    309
    01:52 AM
    2 Not allowed! Not allowed!
    Line Style Menu - Why collapsed?
Name:	Crazy Thing - Line Styles.PNG
    June 21, 2012
    Tours, France
    1,060
    07:52 AM
    One thing I don't like very much is the way Revit act when putting dimensions ! in my current job we do a lot of renovations and here in Europe old buildings are never straight, or parallel and so on!, so putting dimensions in a pain
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    882
    05:52 PM
    Why do important things have such small clickable buttons/arrows?
    July 10, 2015
    Boise, Idaho
    766
    11:52 PM
    At least once a week something requires two people to look at the screen before it works right.
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,504
    11:52 PM
    Quote Originally Posted by CRapai View Post
    I asked about that a long time ago, and was told it was likly because they just reused the general V/G item list. That probably isn't coded with the option to force expansion of the list on open.
    I agree, it annoys me every time I encounter it!
    April 30, 2015
    Michigan
    309
    01:52 AM
    So I just learned that you can tap the right arrow key to expand this a bit so I've added that movement after my hotkey.
    I still hold the right to be mad.
    6,309
    01:52 AM
    I believe that is a default windows functionality. + and - also do the same thing. And they all work in the project browser
    June 21, 2012
    Tours, France
    1,060
    07:52 AM
    Always learning new stuff in RFO! Cheers
    May 6, 2014
    Dallas, Texas
    19
    12:52 AM
    When I cut a section over a certain length, the far clip offset goes all the way past the end of the building.
    January 17, 2011
    2,094
    12:52 AM
    We had a discussion yesterday in the office about how it was when we were all first learning Revit, back in the days before Google could yield results for you and Youtube didn't exist yet. One thing that drove all of us MEP designers crazy back then, without really knowing it at the time, was that the default Mechanical template's Level 1 and 2 top View Range was set to 7'-6", and the default elevation of the Duct and Pipe tool was 9'-0", so when you, as a very new beginner and newcomer to Revit, would "tinker" by clicking the duct or pipe tool, it would, by default, be hidden in the View and an alert would pop up letting you know that it's hidden (which seemed like an error to us beginners).
    DROVE. US. INSANE. I couldn't close Revit fast enough during those days. And once I finally figured out how to adjust it on a project, I wouldn't touch Revit for months, forgetting how I did it before. Oh and let's not get started on RCP Views where it's all flipped and upside down. Once you thought you had a grasp on View Ranges, you get into RCP Views and back on the emotional roller coaster you went.
    I still see questions even to this day asking the same thing. If only Autodesk would at least set the default template to a more inviting setup, instead of LITERALLY needing to problem solve the moment you open the program.
    -TZ
    Last Post: October 10th, 2017, 01:45 AM
  2. Selection in 3D view in Revit 2016 is going crazy!
    By michelevu in forum Architecture and General Revit Questions
    Last Post: April 18th, 2017, 02:11 PM
    Last Post: April 27th, 2016, 01:15 AM
  4. revit 2013: one machine goes crazy
    By jbenoit44 in forum Hardware and Infrastructure
    Last Post: June 18th, 2012, 12:59 PM
    Last Post: March 9th, 2012, 02:45 AM
