Thread: Some Window families shows Blanks on schedule
    June 9, 2013
    03:02 PM
    Hi, some of my windows families shows blank cells on schedule but I can see them in drop down menu. Also I have to tick Include elements in links in order to see them all but there is no link model in my project. Can someone help me out with that? thanks
    1,447
    04:02 PM
    Looks like you are sorting your schedule to something (and hiding that column) and have your 'itemize every instance' turned off causing multiple different families to bunch up into 1 row.
    June 9, 2013
    03:02 PM
    Hi, I have done that and they all shows up on schedule. but I wonder why it only appears on those families?
    1,447
    04:02 PM
    Example:
    Window 1 | description: this is a window | more random data
    Window 2 | description: this is a window | more random data
    Window 3 | description: this is also a window | more random data
    You make a schedule for your windows and sort by description and turn off itemize every instance effectively bunching evenything with the same value together into 1 row.
    This way you will get 2 rows, 1 displaying 'this is a window' and 1 displaying 'this is also a window'.
    If you also add a 'count' cell in there you would get 2 for 'this is a window' and 1 for 'this is also a window'
    Because there are 2 windows with the same description Revit can not display the family names of both in 1 cell in your schedule and leaves the cell blank.
    April 12, 2011
    Chicago, IL
    540
    09:02 AM
    on the sorting/grouping tab, set at least one row to sort by "family"
  1. Nothing shows in the drawing window
    By dizzo in forum Architecture and General Revit Questions
    Last Post: January 7th, 2019, 12:54 PM
  2. window shows up in upper plans
    By leilakaram in forum Architecture and General Revit Questions
    Last Post: June 19th, 2017, 02:52 PM
  3. Schedule that shows REFERENCE LEVEL...???
    By Emmanuel777 in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2015, 08:46 PM
  4. Schedule Shows Incorrect on Sheet
    By Jrobker in forum MEP - General
    Last Post: August 27th, 2014, 11:08 PM
  5. window shows profile on top of the window in the model
    By mno in forum Architecture - Family Creation
    Last Post: November 14th, 2011, 07:35 PM
