Thread: Variable Facade Panel Fail
    November 28, 2018
    03:05 PM
    I am a heavy Rhino/Grasshopper user transitioning to Revit/Dynamo.
    I am in the proccess of modeling a facade paneling system that will ultimately work with an attractor curve.
    The following was modeled in Rhino/GH; I want to model the same system in Revit.
    To achieve this, I've created 3 revit files:
    -A sweep profile as a conceptual mass
    -A curtain panel family that models each "bowtie".
    -A conceptual mass file with 2 surface with a checkerboard patterns, one of which is indented and globally rotated.
    Within the curtain panel family itself, all parameters run as expected.
    When implemented within the Conceptual Mass as an actual applied checkerboard pattern, only certain UV settings produce acceptable results; in other cases, the bowtie curtain panel family breaks in ways I don't understand where constraining dimension lines and predetermined symmetries are ignored.
ID:	37190Click image for larger version.
    Any help would be highly appreciated.
    Attached are all relevant rfa files.
    Thanks!
    3,202
    10:05 AM
    Welcome to the forum.
    Don't use dimensions in pattern-based families. That seems to be the error. As soon as all those dimensions are deleted, your panel starts to work. Replace use of dimensions with snaps or offsets. For example, instead of using equal-equal, simply put a point in the middle of a line. Instead of fixing a point with a dimension and parameter, control it by the offset from another point.
  1. Replies: 15
    Last Post: March 21st, 2017, 05:45 PM
  2. RTC: Plan to Fail
    By RTC in forum Blog Feeds
    Last Post: June 21st, 2016, 02:15 AM
  3. Revit Fail
    Last Post: December 18th, 2015, 04:37 PM
  4. Precast Panel Facade Documents using Parts
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: February 27th, 2015, 02:02 AM
  5. Do U Revit: DWF in the Cloud: #Fail
    Last Post: March 23rd, 2012, 06:15 PM
