Thread: Global Width
    May 31, 2018
    Quebec, Canada
    62
    04:03 PM
    Global Width
    Hi everyone,
    I was wondering, is there a way in revit to do a global widht like in autocad where you can start a line for example @ 3 and end up @7.
    I use this technique for creating depth in roofing so I was wondering if it is possible!
    Thanks for your help!
    Midaz
    3,130
    10:03 AM
    If you're talking about a PLine that gets wider along its length, no there isn't anything like that in Revit (other than a Filled Region)
    You could probably create some sort of a Line-based family that would accomplish that, but I have to wonder what you want this? Why not create a Roof with a variable depth?
    In other words, actually model it like it would be built.
    May 31, 2018
    Quebec, Canada
    62
    04:03 PM
    yeah this is what I am talking about,
    the goal is that when you start your line wider, and end up smaller, it creates a depth in a 2D shape. with regular lines in revit, the line is the same thickness the entire time which don't have the same. It just gives the illusion that the roof actually gets further when you do it that way, it is purely illustrative thanks for your reply! I will try to find a way !
    3,130
    10:03 AM
    Ah. You're talking about a pen weight. I thought you were looking for tapered insulation.
    Not exactly the same as line weights, but Depth Cueing should accomplish what you're looking for.
    https://www.youtube.com/watch?v=7wcBZWnVp48
    March 5, 2011
    Southern California
    666
    08:03 AM
    if it's depth perception in views, there is a tool in Revit for Depth Cueing:
    https://knowledge.autodesk.com/suppo...D1E96-htm.html
    (EDIT: oops, i see DaveP just posted the same thing!)
    May 31, 2018
    Quebec, Canada
    62
    04:03 PM
    You guys are genius, thank you so much for help it will be so much nicer, damn can't wait to use it! thanks again!
  1. Replies: 4
    Last Post: September 20th, 2016, 09:12 PM
  2. Tag length and Width of a wall
    By Lauft in forum Architecture and General Revit Questions
    Last Post: October 23rd, 2015, 02:59 PM
  3. Text Width in Schedules
    Last Post: February 9th, 2015, 07:29 AM
  4. make arch width change along with width change ??!!
    By ahmed_hassan in forum Architecture - Family Creation
    Last Post: December 25th, 2011, 07:24 PM
  5. Wall Sweep Width
    By Will P. in forum Architecture and General Revit Questions
    Last Post: June 30th, 2011, 07:49 PM
