Results 1 to 9 of 9
Thread: Can I Make an Invisible Rail to Host Balusters to?
    July 21, 2018
    83
    01:54 AM
    We've started doing a lot of our rails unhosted and manually controlling the slopes via the sketch settings. It works fine as long as the railing family has rails to host the bottom of the baluster, as the rails seem to follow the sketched path "Height Correction" setting. The problem is that if we have a rail that is entirely balusters, then it stays hosted to the floor, despite adjusting the line height in the sketch.
    The quickest/most obvious workaround seems to be to add a 1mmě rail, but I'm just wondering if there's another way? The 1mm line in plan views is rather annoying:
    It's a little weird because with no rails the balusters are set to "Host" as the Base and Top, for some reason the Top setting is correct and adjusts per the sketch, whereas the Base seems to stay stuck at 0 :/
    November 4, 2012
    86
    03:54 PM
    Possible workaround: in railing type settings use top rail->yes, set up every baluster base from the Top rail.
    In a view select the top rail by 'tabbing', unpin the top rail and delete. The railing will remain the same, you can put back the top rail by clicking reset railing.
    July 21, 2018
    83
    01:54 AM
    Nice. As with most workarounds it's a little ugly, but I can still appreciate the beauty in it haha, so thanks for the suggestion. Might even create a new top rail type called "Host Balusters Then Delete Me In Views" or something like that and make it a very thin plane so users understand what's going on. Thanks again
    edit: also, setting the Top rail to 0mm height means that controlling the baluster height is far more intuitive and the rail will reflect the sketched path heights.
    May 18, 2011
    Calgary, AB
    416
    07:54 AM
    Hmm, can you use an empty profile for a rail or does it have to have lines in it?
    November 4, 2012
    86
    03:54 PM
    You can save, but can't load an empty profile:
Name:	Jegyzet 2019-08-14 172657.png
    May 18, 2011
    Calgary, AB
    416
    07:54 AM
    Quote Originally Posted by infeeeee View Post
    Dang.
    888
    12:54 AM
    Use a column profile and adaptive points on a 3d model line....
    Not the best video but a similar workflow to this except you would need to change the orientation of your profile to perpendicular to the point, rather then aligned with the point
    https://www.youtube.com/watch?v=2aXLSDVVdjg
    Member anthonyB's Avatar
    August 31, 2011
    Sydney, Australia
    435
    01:54 AM
    If I can't get the Railing tool to place the uprights as I want, I will use my Work Plane Based Generic Model baluster family to place them individually, exactly where I want them. You would not want to place a heap of them, but for a special stair it is easy and quick.
    July 26, 2019
    DFW, Texas
    51
    08:54 AM
    As an experiment, I "cheated" and changed hte top rail Material to "Air"--it sort of behaves.
    I meant to try to make a 0.01mm railing Profile, but, likw, w*rk, etc. got in the way.
  1. Make an invisible decal host?
    By ccabral3 in forum Architecture and General Revit Questions
    Last Post: August 16th, 2018, 05:10 PM
  2. Invisible Rail
    By agrieveson in forum Architecture and General Revit Questions
    Last Post: February 24th, 2017, 10:35 AM
  3. How to make specific parameters within a label invisible.
    By Spiegel in forum Structure - Family Creation
    Last Post: December 8th, 2016, 10:26 PM
  4. Cannot make item invisible in Plan View
    Last Post: December 16th, 2013, 02:52 AM
    Last Post: February 5th, 2013, 05:45 AM
