Results 1 to 10 of 14
Thread: How to model foundation concrete piles
    August 26, 2019
    4
    12:32 PM
    Hello all,
    I have a project where I need to model concrete piles as part of my foundation design. Revit does not have any concrete piles under foundation options but only steel piles. Is the best way to model concrete piles as concrete columns? Has anyone done this before?
    1,618
    07:32 PM
    Just looked at the construction model of one of the projects I worked on and the structural guys made the concrete piles 'Structural Foundation' which makes sense I think.
    August 26, 2019
    4
    12:32 PM
    So Revit has an option/family for concrete piles? Or was it custom made?
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    295
    12:32 PM
    Quote Originally Posted by kcabrera3 View Post
    The OOTB steel pile family is a good starting point for creating a custom concrete pile/pier/caisson. It should just be a matter of changing the "Material for Model Behavior" from steel to concrete. And then updating the structural material parameter within your project environment.
    1,618
    07:32 PM
    Yep was custom made, but you will have to get used to that I guess, you will not manage with just the OOTB Revit content.
    What Tony says is a good starting point indeed.
    December 11, 2010
    Astana
    227
    11:32 PM
    Try using Structural Columns as piles.
    SC have few advantages over Isolated Structural Foundations:
    No (interfering) auto-attachment to slabs, floors and structural columns;
    "Show family pre-cut in plan views" family parameter, gives you more graphics options;
    Control piles length via Top / Base level constraints;
    Column location mark and Graphical Column Schedule.
    890
    03:32 AM
    As you may be aware in Revit we have mutliple "Categories" of objects.
    Some people have suggested using columns as piles.
    Personally I don't like this option for a few reasons - but essentially a pile is a buried column...so technically yes you could use the column as a vertical element to model the geometry.
    Understand that in Revit there are often multiple ways to get something modeled, the problems will arise later when you want to filter / isolate objects, change graphics of objects, and most importantly extract data out of objects.
    All of those above things mentioned, are driven by the object "category". Piles also have different parameters available that columns do not that are related to piles - (but those could indeed also be created and included in a column family if you really wanted to)
    You can easily create your own Piles and Pile caps that can report exactly the output you need such as serviceablity loads, factored design loads, length etc...types of information that are not included in column families or column categories.
    The most important limitation when you model your piles as "columns" will come when you export your model as part of your deliverables.
    If your contract requires you to provide an IFC model as part of the deliverables, revit will automatically export your piles under the incorrect IFC classification and this will end up with you having to rework them so that they export under the correct element and type classification. A rigorous BIM Manager or model checker will not let you create piles as columns.
    Column > IfcColumn > IfcColumnType NO
    Pile > IfcPile > n/a NO
    Pile Cap > IfcFooting PILE_CAP NO
    This also determines how other programs used in the collaboration process will read your objects...
    Just keep in mind there are many ways to skin the revit cat but think down the road (and out of your disciplines box) to see that there may be unintended / unwanted consequences by taking short cuts or "cheating" or simply thinking that a method is more convenient for graphical tables etc that exist for another category. If you are just using Revit internally and not sharing it then model how you want, if you are on a large project team delivering complex shared geometry....model it properly. In fact just get in the habit of modeling it properly....is my recomendation.
    This is a good blog on the IFC subject.
    https://bimblog.bondbryan.co.uk/ifc-...k-revit-users/
    August 26, 2019
    4
    12:32 PM
    wow. Lots of information. Thanks everyone. The main reason of bringing this up is because like Karalon10 posted, we need to model objects correctly for counting/coordination purposes. I will definitely look into creating a new foundation family in the next few days. I will start with the OOTB steel piles. Would everyone agree this is the best way?
    December 11, 2010
    Astana
    227
    11:32 PM
    IFC export not a problem. Info from Revit help:
    Revit exports building elements to an IFC file based on the categories (and subcategories) to which the elements belong.
    For example, Revit exports a wall to the IFC entity IfcWallStandardCase, because the wall is an element from the wall category. In many cases, exporting elements from Revit to IFC is straightforward and simple, and the default settings make sense.
    In some cases, however, you may want to specify the IFC entity to which elements from a particular family should belong. For example, suppose you design an escalator family. It belongs to the Generic Model category, and you create for it a subcategory called Escalator. You want to ensure that when you export a project to IFC, an escalator is properly (and automatically) mapped to the class IfcTransportElement and the type IfcTransportElementType.
    https://help.autodesk.com/view/RVT/2...5-750410D867C9
    890
    03:32 AM
    As I said, you can "work around" issues you create by using the wrong category, or you can just use the correct category and save yourself all the rework in remapping, creating new filters, modifying view templates, creating shared parameters and the like.
    Yes you can do it, the question is more why bother doing it when there is little benefit to it?
    I have never needed to produce a graphic pile schedule. Which is about the only benefit I can see out of using a column instead of a pile family.
  1. How to model a long ground beam with piles?
    By daer in forum Structure - General Questions
    Last Post: May 23rd, 2016, 12:13 PM
  2. Concrete Step, Model-In Place
    By Usernumerouno in forum Architecture and General Revit Questions
    Last Post: September 10th, 2015, 08:26 PM
  3. Sheet Piles
    By snowyweston in forum Structure - General Questions
    Last Post: July 16th, 2015, 06:56 PM
  4. How to add Lean concrete under the foundation and Ground Beams.
    By azsaqib in forum Structure - General Questions
    Last Post: December 9th, 2013, 12:07 PM
  5. Using Curtain Wall for Piles walls
    Last Post: July 18th, 2011, 04:54 AM
