Thread: Steel connections causing problems with "views on sheets"
    March 20, 2018
    13
    04:58 AM
    I use the steel connections to model my connections, howevwer when i bring views onto sheets, the view stretches out across the project picking up many "sub-Connections. this makes it difficult to work on the sheet. any input to solve this would be a great help.
    December 11, 2010
    Astana
    227
    10:58 PM
    This bug was fixed in Revit 2020, but left in 2019.
    August 5, 2019
    04:58 PM
    You need to use proper simple joint model and the joint between the steel need to be pinned with nominal connections. Need a steel connection with sheets in a coincidental manner.
  1. change instance parameter w/ "Edit" for multiple views/sheets
    Last Post: October 22nd, 2014, 08:56 AM
