Results 1 to 10 of 12
Thread: Changing the colour of a window in an elevation
    June 25, 2016
    97
    03:10 PM
    Hi you all
    I want to change the colour of the glass of the window to a gray in an elevation view. The thing is that when I want to select the window I actually select the entire family and not the glass, even after using TAB
    Thanks a lot
    1,681
    04:10 PM
    That means the glass is either in the same family as the window (so not nested) or is nested, but not shared.
    But why not change the material to be grey?
    June 25, 2016
    97
    03:10 PM
    Thanks a lot
    That would change it colour in the elevations as well? How can I do that?
    1,681
    04:10 PM
    Yep, all my glass is a gray-ish/blue color, just change the surface pattern
Name:	material color.JPG
    June 25, 2016
    97
    03:10 PM
    Done it! It worked like a charm
    1,681
    04:10 PM
    Makes it look much better if you ask me, kinda like the old days where you would color the back of your paper to make the glass grey so I heard. Not that old myself, but still it looks good
    4,466
    03:10 PM
    Because setting solid fill patterns on materials is a selfish practice when working with others?
    1,681
    04:10 PM
    Why is that? The only thing that might be an issue is when exporting to AutoCAD, unless I miss something.
    4,466
    03:10 PM
    Why is that?
    I don't want other's stuff in my hidden line-style views coming through coloured in - in the same way I don't want folk using MEP folk using system overrides.
    Sure, I could write custom overrides on your links - and/or build filters to override stuff (presuming there are consistent property fields to fetch at) but like I said, that's me suffering a selfish practice.
    Yes, it's no different to others providing cut and surface patterns in the graphic definitions of their materials - but they are almost always appropriate (cut patterns on steel and concrete, etc) - but a solid-fill colour? Like a certain v.large structural outfit who colour their concrete-cut a putrid shade of bile green? Pass.
    11,255
    09:10 AM
    LOL at that "being selfish."
    Had my glazing colored gray for almost a decade, now. Number of complaints I've heard about it stands at exactly one (in this thread).
    I'll keep being selfish, I guess.
  1. Building Coder: Changing Text Colour
    By Building Coder in forum Blog Feeds
    Last Post: February 28th, 2018, 08:15 AM
  2. Changing the colour of an AutoCAD files fills in Revit?
    By Lox in forum Architecture and General Revit Questions
    Last Post: April 20th, 2017, 02:26 PM
  3. OBJ exporter - Colour changing problem
    By Nuwan in forum Structure - General Questions
    Last Post: December 16th, 2015, 05:11 AM
  4. Changing colour surfaces on a custom family member (trusses)
    By craigten in forum Architecture - Family Creation
    Last Post: June 30th, 2015, 11:47 AM
  5. changing colour of beam
    By joewallace in forum Architecture and General Revit Questions
    Last Post: December 9th, 2011, 05:30 PM
