Tool for batch print of sheets or sheet sets to PDF files including automatic sheet size selection, custom filenames and other options.
Screenshot:
Features:
  • Automatic sheet size selection.
  • Batch print sheets or sheet sets to PDF files.
  • Custom filenames with variables and option for remove diacritics option.
  • Support for merge selected sheets into one PDF file.
  • Options for print setup (bw × color, ...).
Tool supports BIM application Autodesk Revit® 2017–2020.
Printed sheets paper sizes will always correspond to the sheet dimensions in Autodesk Revit® (scale will be preserved).
All sheets in one PDF
Print speed
Sheets are printed to PDF in a few seconds.
Print setup options
Setup for colors, raster quality, hide ref/work planes, hide scope boxes, and more.
Custom output
  • No additional output files rename. Custom filenames solution allows you to compose filenames from an optional text and parameters available in the project.
  • Remove diacritics option.
Sheet Collections
  • Use collection for easy grouping of your sheets and reuse it for future print.
  • Collections are compatible with native Revit Sheet Sets. Any changes made in CCpdf will apply to the Revit Sheet Sets.
Advanced features
Filtering all sheets by parameters.
More info:
