Thread: Deck Display Thickness (Gage)
    October 31, 2017
    6
    07:02 AM
    Hello all,
    I'm new to modeling concrete on metal deck floors. I noticed that, when cutting a section parallel to the deck span, Revit displays the thickness of the deck (e.g. the deck gage) much thicker than the Thickness parameter specified in the deck profile. For example, most of the default steel deck profiles have a 1/32" Thickness (see image below), yet they are displayed at almost exactly 10% of the deck rib height (e.g. 0.2" for a 2" deck, 0.3" for a 3" deck, etc.Śsee second image below). Is there any way to reduce the display thickness of the metal deck or maybe to just not show those additional lines at all and just show the top and bottom lines of the deck rib? Thanks in advance for your help.
    Dave
    Attached Thumbnails Attached Thumbnails Deck Profile Thickness.png   Deck Display Thickness.png
    Member Darius's Avatar
    May 6, 2013
    493
    08:02 AM
    so i have never actully dimensioned this but the 45deg. slope at the end is what your are seeing is it 3/16"
    October 31, 2017
    6
    07:02 AM
    Quote Originally Posted by Darius View Post
    Very good question. I hadn't thought of that. Unfortunately, that doesn't look to be the case, because: (1) on every deck I've checked, the gap is exactly 10" of the deck height (e.g. on a 2" deck, the gap is 51/256"~0.2"); and (2) as a test, I created an abnormally large deck profile (8" tall) without those 45░ lips on the ends and the gap still shows up and is once again 10% (0.8"). Thanks for your input!
    Senior Member Alex Page's Avatar
    Wellington, New Zealand
    685
    02:02 AM
    Ive never been able to work out how to change the distance; I think its just there as a visual reference.
    What I have worked out is how to turn them off - and its not obvious.
    The continuous line at the top and the dashed line at the base designating the thickness of the deck are actually controlled by the "Line" category!
    "Thin Lines" for the continuous one and "Overhead" for the dashed one - very strange
    3,031
    05:02 AM
    Quote Originally Posted by Alex Page
    Yes I don't think it is trying to show the actual distance in this case. Most of the time that distance might be too small to see? I've never seen anything that formally explains it though.
    October 31, 2017
    6
    07:02 AM
    Quote Originally Posted by Alex Page View Post
    That's interesting how those line categories control the display of those lines. Regardless, that's a good enough solution for me, as I was having to draw white lines on top of them to mask them, so this is much easier. Thanks Alex!
  7.    #7
    December 16, 2010
    885
    11:02 PM
    the deck profile is drawn using a "profile" in the revit families. Your profile will not adapt to changes in the deck thickness, you will need to specify the correct profile, and so in your type properties you will need to manage that the correct profile is being used for each different slab thickness.
  1. Walls with same material and thickness display differently in 3d
    By TheCyclist in forum Architecture and General Revit Questions
    Last Post: February 14th, 2014, 02:15 PM
  2. lt. gage metal roof truss
    By LeanneZ in forum Structure - Family Creation
    Last Post: June 15th, 2011, 04:21 AM
