Page 1 of 11 12345 ... LastLast
Results 1 to 10 of 106
Thread: RFO Benchmark v3.# 2020 results
    Administrator Gordon Price's Avatar
    Rotterdam, South Holland
    3,076
    05:17 PM
    [COLOR=#2E2E2E][COLOR=#2E2E2E]Please post your RFOBenchmark V3.# results for the 2020 products here. [/COLOR][/COLOR]
    [COLOR=#2E2E2E][COLOR=#2E2E2E]Comments and suggestions should be made in the [/COLOR][/COLOR][COLOR=#2e2e2e]RFOBenchmark v3.X[/COLOR][COLOR=#2E2E2E][COLOR=#2E2E2E] thread. The download is there too.
    [/COLOR][/COLOR]
    [COLOR=#2E2E2E][COLOR=#2E2E2E]Note: To condense your results, click Go Advanced, highlight the results, then click the code button (the one with a [/COLOR][/COLOR][COLOR=#2E2E2E][COLOR=#2E2E2E]#[/COLOR][/COLOR][COLOR=#2E2E2E][COLOR=#2E2E2E]).[/COLOR][/COLOR]
    [COLOR=#2E2E2E][COLOR=#2E2E2E]Thanks![/COLOR][/COLOR]
    [COLOR=#2E2E2E][COLOR=#2E2E2E]Gordon[/COLOR][/COLOR]
    1,681
    05:17 PM
    WOOT the 2020 benchmark is out !!
    Let me be the first one to post my results:
    Code:
    RVT 2020 - Full_Simplified set - 2019.09.09 @ 21.31.24 on WORKSTATION.txt
        RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2020.1
    _________________________________________________________________
    Model creation benchmark
        4.27   opening and loading the custom template
        9.57   creating the floors levels and grids
       14.41   creating a group of walls and doors
       25.90   modifying the group by adding a curtain wall
        8.90   creating the exterior curtain wall
        6.86   creating the sections
        2.93   changing the curtain wall panel type
       10.88   creating area plans
        1.48   creating and applying view template
       85.20   TOTAL
    Graphics
        4.57   activate View Styles view
        0.95   change view to Wireframe
        0.07   change view to Hidden
        0.28   change view to Shaded
        0.30   change view to Consistent Colors
        0.28   change view to Realistic
        0.70   refresh Wireframe Line view x10
        2.92   refresh Hidden Line view x10
        3.12   refresh Shaded view x10
        2.95   refresh Consistent Colors view x10
        3.73   refresh Realistic view x10
        0.34   activate View Cube view
        2.08   rotate view x1
       22.29   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    OS: Microsoft Windows 10 Pro64-bit
    CPU: Intel(R) Core(TM) i7-8086K CPU @ 4.00GHz
    Max Clock Speed: 4.008Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 32GB @ 3200 3200 3200 3200Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 970 EVO Plus 500GB
    Graphics Card: NVIDIA GeForce GTX 1070 Ti
    Graphics RAM: 3.9990234375GB
    Driver version: 25.21.14.1967
    Screen Resolution: 1920x1080x32bit @ 60Hz
    DPI Scaling: 100%
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    279
    08:17 AM
    Production machine. 9900k w/tune
    Code:
    RVT 2020 - Full_Simplified set - 2019.08.25 @ 11.22.32 on DESKTOP-JOMGR58.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Run on Revit 2020 FCS
        3.89   opening and loading the custom template
        9.78   creating the floors levels and grids
       14.79   creating a group of walls and doors
       26.74   modifying the group by adding a curtain wall
        9.00   creating the exterior curtain wall
        7.09   creating the sections
        2.96   changing the curtain wall panel type
       10.55   creating area plans
        1.46   creating and applying view template
       86.26   TOTAL
    Graphics
        4.46   activate View Styles view
        0.29   change view to Shaded
        0.31   change view to Consistent Colors
        0.29   change view to Realistic
        0.68   refresh Wireframe Line view x10
        2.98   refresh Hidden Line view x10
        3.13   refresh Shaded view x10
        2.97   refresh Consistent Colors view x10
        3.83   refresh Realistic view x10
        0.35   activate View Cube view
        2.13   rotate view x1
       22.44   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Remis Computer Solutions
    Model: Anvil-R
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 32GB @ 3200 3200Mhz
    Drive Model: CT1000P1SSD8
    Graphics Card: NVIDIA GeForce RTX 2060 SUPER
    Driver version: 26.21.14.3170
    DPI Scaling: 100%
    Standard test
    Code:
    RVT 2020 - Full_Standard set - 2019.08.25 @ 11.26.02 on DESKTOP-JOMGR58.txt    RFO Benchmark v3.2 (build 01.05.2018)
        RevitForum.org
    Update
        8.86   update previous version file
        3.88   opening and loading the custom template
        9.70   creating the floors levels and grids
       14.64   creating a group of walls and doors
       26.68   modifying the group by adding a curtain wall
        8.87   creating the exterior curtain wall
       10.47   creating area plans
       85.74   TOTAL
    Export benchmark
       49.60   export all views as PNGs at 300 dpi
       45.46   export all views as DWFs
       71.66   export all views as DWGs
       48.01   print all views as vector *
       77.11   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       46.30   render
    Graphics - Standard View
        4.45   activate View Styles view
        0.34   change view to Wireframe
        0.54   change view to Hidden
        0.76   change view to Shaded
        0.73   change view to Consistent Colors
        1.29   change view to Realistic
        0.59   refresh Wireframe Line view x10
        2.57   refresh Hidden Line view x10
        2.75   refresh Shaded view x10
        2.61   refresh Consistent Colors view x10
        2.90   refresh Realistic view x10
        2.07   rotate view x1
       21.94   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: Anvil-R
    DPI Scaling: 100%
    RAW DATA:
        8.953    8.832    8.801   update previous version file
        3.894    3.891    3.867   opening and loading the custom template
        9.691    9.680    9.742   creating the floors levels and grids
       14.797   14.547   14.570   creating a group of walls and doors
       26.770   26.609   26.652   modifying the group by adding a curtain wall
        8.801    8.848    8.953   creating the exterior curtain wall
        7.102    7.082    7.082   creating the sections
        2.969    2.922    2.914   changing the curtain wall panel type
       10.438   10.453   10.531   creating area plans
        1.547    1.430    1.473   creating and applying view template
       49.555   49.613   49.629   export all views as PNGs at 300 dpi
       45.531   45.430   45.406   export all views as DWFs
       71.672   71.875   71.438   export all views as DWGs
       48.059   47.996   47.980   print all views as vector
       77.109   77.215   76.992   print all views as raster
       44.098   50.750   44.059   render
        4.461    4.445    4.441   activate View Styles view
        0.340    0.344    0.348   change view to Wireframe
        0.535    0.559    0.539   change view to Hidden
        0.750    0.762    0.754   change view to Shaded
        0.734    0.719    0.738   change view to Consistent Colors
        1.297    1.301    1.285   change view to Realistic
        0.590    0.594    0.598   refresh Wireframe Line view x10
        2.559    2.578    2.566   refresh Hidden Line view x10
        2.738    2.773    2.734   refresh Shaded view x10
        2.602    2.621    2.594   refresh Consistent Colors view x10
        2.883    2.918    2.887   refresh Realistic view x10
        0.340    0.344    0.340   activate View Cube view
        2.059    2.113    2.051   rotate view x1
    Member kubsix's Avatar
    March 31, 2011
    Quad Cities, Illinois
    309
    10:17 AM
    i7-8700K CPU @ 3.70GHz w/ OC
    Code:
    RVT 2020 - Full_Simplified set - 2019.09.13 @ 08.48.28 on JDK1826BOX10.txt
        RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
    Run on Revit 2020.1
        3.27   opening and loading the custom template
        9.18   creating the floors levels and grids
       14.90   creating a group of walls and doors
       26.25   modifying the group by adding a curtain wall
        9.30   creating the exterior curtain wall
        7.65   creating the sections
        3.15   changing the curtain wall panel type
       10.97   creating area plans
        1.60   creating and applying view template
       86.27   TOTAL
    Graphics
        3.78   activate View Styles view
        1.02   change view to Wireframe
        0.31   change view to Shaded
        0.33   change view to Consistent Colors
        0.31   change view to Realistic
        0.78   refresh Wireframe Line view x10
        3.40   refresh Hidden Line view x10
        3.40   refresh Shaded view x10
        3.24   refresh Consistent Colors view x10
        4.09   refresh Realistic view x10
        0.37   activate View Cube view
        2.73   rotate view x1
       23.83   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: BOXX Technologies
    Model: APEXX S3
    OS: Microsoft Windows 10 Enterprise64-bit
    CPU: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
    Max Clock Speed: 3.696Ghz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: Samsung SSD 960 PRO 512GB
    Graphics Card: NVIDIA Quadro P1000
    Driver version: 26.21.14.3039
    Screen Resolution: 1920x1200x32bit @ 59Hz
    DPI Scaling: 100%
    Code:
    RVT 2020 - Full_Standard set - 2019.09.13 @ 08.53.57 on JDK1826BOX10.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        8.14   update previous version file
        3.15   opening and loading the custom template
        9.07   creating the floors levels and grids
       15.02   creating a group of walls and doors
       26.35   modifying the group by adding a curtain wall
        9.24   creating the exterior curtain wall
        7.57   creating the sections
        3.13   changing the curtain wall panel type
       10.83   creating area plans
        1.58   creating and applying view template
       85.94   TOTAL
    Export benchmark
       51.37   export all views as PNGs at 300 dpi
       46.16   export all views as DWFs
       75.50   export all views as DWGs
       51.94   print all views as vector *
       79.27   print all views as raster *
    Notes:
    Render benchmark
       54.86   render
        3.88   activate View Styles view
        0.38   change view to Wireframe
        0.62   change view to Hidden
        0.81   change view to Shaded
        0.83   change view to Consistent Colors
        1.37   change view to Realistic
        0.67   refresh Wireframe Line view x10
        2.81   refresh Hidden Line view x10
        2.91   refresh Shaded view x10
        2.79   refresh Consistent Colors view x10
        3.06   refresh Realistic view x10
        0.38   activate View Cube view
        2.72   rotate view x1
       23.23   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: APEXX S3
    DPI Scaling: 100%
    RAW DATA:
        8.176    8.133    8.125   update previous version file
        3.162    3.123    3.172   opening and loading the custom template
        9.064    9.053    9.090   creating the floors levels and grids
       14.982   15.043   15.039   creating a group of walls and doors
       26.312   26.490   26.238   modifying the group by adding a curtain wall
        9.309    9.180    9.238   creating the exterior curtain wall
        7.459    7.719    7.539   creating the sections
        3.098    3.121    3.160   changing the curtain wall panel type
       10.691   10.945   10.844   creating area plans
        1.609    1.555    1.578   creating and applying view template
       51.258   51.152   51.691   export all views as PNGs at 300 dpi
       46.338   45.824   46.309   export all views as DWFs
       75.164   74.953   76.371   export all views as DWGs
       51.717   51.793   52.297   print all views as vector
       78.887   79.164   79.762   print all views as raster
       56.330   54.059   54.195   render
        3.727    4.176    3.723   activate View Styles view
        0.373    0.391    0.371   change view to Wireframe
        0.617    0.633    0.625   change view to Hidden
        0.820    0.812    0.805   change view to Shaded
        0.809    0.836    0.848   change view to Consistent Colors
        1.357    1.359    1.383   change view to Realistic
        0.674    0.652    0.684   refresh Wireframe Line view x10
        2.742    2.934    2.766   refresh Hidden Line view x10
        2.953    2.910    2.871   refresh Shaded view x10
        2.830    2.781    2.754   refresh Consistent Colors view x10
        3.062    3.074    3.051   refresh Realistic view x10
        0.385    0.371    0.383   activate View Cube view
        2.703    2.699    2.746   rotate view x1
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    188
    05:17 PM
    Hm another I9 9900K but different results?!?
    Using intell performace maximiser to OC (in dummy mode)
    Code:
    RVT 2020 - Full_Standard set - 2019.09.12 @ 17.24.17 on FRACTAL-WIT.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        9.53   update previous version file
        4.29   opening and loading the custom template
       12.30   creating the floors levels and grids
       17.43   creating a group of walls and doors
       30.01   modifying the group by adding a curtain wall
       10.99   creating the exterior curtain wall
        9.57   creating the sections
        3.52   changing the curtain wall panel type
       13.40   creating area plans
        1.89   creating and applying view template
      103.40   TOTAL
    Export benchmark
       55.44   export all views as PNGs at 300 dpi
       48.28   export all views as DWFs
       79.85   export all views as DWGs
       54.95   print all views as vector *
       84.64   print all views as raster *
    Notes:
    Render benchmark
       44.89   render
        4.77   activate View Styles view
        0.57   change view to Hidden
        0.80   change view to Shaded
        0.79   change view to Consistent Colors
        0.65   refresh Wireframe Line view x10
        2.84   refresh Hidden Line view x10
        3.02   refresh Shaded view x10
        2.85   refresh Consistent Colors view x10
        3.18   refresh Realistic view x10
        0.40   activate View Cube view
        2.39   rotate view x1
       24.01   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd.
    Model: MS-7B98
    Total Physical Memory: 64GB @ 2133 2133 2133 2133Mhz
    Drive Model: CT500P1SSD8
    Graphics Card: NVIDIA GeForce RTX 2070
    Driver version: 26.21.14.3186
    DPI Scaling: 100%
    RAW DATA:
        9.590    9.516    9.484   update previous version file
        4.289    4.277    4.305   opening and loading the custom template
       12.379   12.328   12.180   creating the floors levels and grids
       17.496   17.328   17.461   creating a group of walls and doors
       29.996   29.902   30.125   modifying the group by adding a curtain wall
       10.836   11.000   11.121   creating the exterior curtain wall
        9.547    9.613    9.559   creating the sections
        3.531    3.535    3.492   changing the curtain wall panel type
       13.394   13.488   13.328   creating area plans
        1.875    1.906    1.891   creating and applying view template
       55.340   55.785   55.191   export all views as PNGs at 300 dpi
       48.480   48.203   48.148   export all views as DWFs
       79.680   79.461   80.394   export all views as DWGs
       55.195   54.961   54.707   print all views as vector
       84.934   84.547   84.441   print all views as raster
       44.961   44.898   44.812   render
        4.754    4.789    4.754   activate View Styles view
        0.387    0.383    0.371   change view to Wireframe
        0.570    0.590    0.562   change view to Hidden
        0.785    0.797    0.816   change view to Shaded
        0.797    0.781    0.785   change view to Consistent Colors
        1.356    1.394    1.359   change view to Realistic
        0.648    0.652    0.660   refresh Wireframe Line view x10
        2.805    2.812    2.894   refresh Hidden Line view x10
        3.000    3.012    3.039   refresh Shaded view x10
        2.816    2.856    2.891   refresh Consistent Colors view x10
        3.148    3.188    3.211   refresh Realistic view x10
        0.402    0.387    0.402   activate View Cube view
        2.394    2.367    2.410   rotate view x1
    May 18, 2015
    Las Vegas, NV
    279
    08:17 AM
    Hello @Geert
    What probably happened is that the Intel performance tool set an all core overclock of say 4.7ghz which disabled your 5ghz boost clock. If this is the recent tool that they released about a month or two ago I am nearly certain that is what happened.
    Another thing, if you have overclocked RAM and the z390 chipset (can only see it is MSI) make sure to enable your XMP profile on the RAM otherwise you may be at 2133mhz. In my testing RAM speed makes a slight difference as well.
    Quote Originally Posted by Geert View Post
    Code:
        RevitForum.org
    Run on Revit 2020.1
    Update
      103.40   TOTAL
    Export benchmark
    Notes:
    Render benchmark
       44.89   render
        2.39   rotate view x1
       24.01   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B98
    DPI Scaling: 100%
    RAW DATA:
    February 8, 2011
    188
    05:17 PM
    Hi remisc
    So not overclocking might in the end be a better idea?
    It is the recent tool all right. not a magic bullet than. if there is such a thing. I did not boost ram speed that I know of
    It is the MSI Z390 A-pro. bit of the entrance board of the MSI Z390 line but in theory is all I need. only thing missing, for my needs, is bluetooth
    February 8, 2011
    188
    05:17 PM
    Uninstalled the intell performance maximizer utility but clockspeed remained limited at 4.7
    Processor core ratio was locked at 47x
    changed this to 50 nd boost speed goes up to 5 GHz now.
    I reran the benchmark and here are the results.
    Code:
    RVT 2020 - Full_Standard set - 2019.09.17 @ 13.28.53 on FRACTAL-WIT.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
        8.91   update previous version file
        4.11   opening and loading the custom template
       11.08   creating the floors levels and grids
       15.90   creating a group of walls and doors
       28.04   modifying the group by adding a curtain wall
        9.95   creating the exterior curtain wall
        8.65   creating the sections
        3.22   changing the curtain wall panel type
       12.11   creating area plans
        1.75   creating and applying view template
       94.81   TOTAL
    Export benchmark
       50.98   export all views as PNGs at 300 dpi
       44.57   export all views as DWFs
       73.90   export all views as DWGs
       50.65   print all views as vector *
       78.40   print all views as raster *
    Notes:
    Render benchmark
       50.91   render
        4.55   activate View Styles view
        0.35   change view to Wireframe
        0.74   change view to Shaded
        0.75   change view to Consistent Colors
        1.27   change view to Realistic
        0.61   refresh Wireframe Line view x10
        2.60   refresh Hidden Line view x10
        2.76   refresh Shaded view x10
        2.62   refresh Consistent Colors view x10
        2.91   refresh Realistic view x10
        2.25   rotate view x1
       22.33   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B98
    Drive Model: Samsung SSD 860 QVO 1TB
    DPI Scaling: 100%
    RAW DATA:
        8.871    9.023    8.844   update previous version file
        4.109    4.113    4.098   opening and loading the custom template
       10.992   11.070   11.188   creating the floors levels and grids
       15.902   15.984   15.824   creating a group of walls and doors
       28.848   27.691   27.574   modifying the group by adding a curtain wall
        9.973    9.859   10.016   creating the exterior curtain wall
        8.750    8.656    8.535   creating the sections
        3.250    3.180    3.238   changing the curtain wall panel type
       12.219   12.008   12.094   creating area plans
        1.750    1.758    1.754   creating and applying view template
       50.789   51.066   51.078   export all views as PNGs at 300 dpi
       44.410   44.637   44.668   export all views as DWFs
       73.535   74.480   73.684   export all views as DWGs
       50.730   50.535   50.691   print all views as vector
       78.656   78.059   78.477   print all views as raster
       44.703   50.918   57.117   render
        4.551    4.535    4.555   activate View Styles view
        0.356    0.348    0.356   change view to Wireframe
        0.527    0.551    0.551   change view to Hidden
        0.746    0.738    0.727   change view to Shaded
        0.762    0.762    0.734   change view to Consistent Colors
        1.293    1.277    1.242   change view to Realistic
        0.609    0.617    0.598   refresh Wireframe Line view x10
        2.609    2.613    2.566   refresh Hidden Line view x10
        2.746    2.809    2.734   refresh Shaded view x10
        2.617    2.648    2.590   refresh Consistent Colors view x10
        2.898    2.945    2.894   refresh Realistic view x10
        0.394    0.371    0.379   activate View Cube view
        2.238    2.270    2.246   rotate view x1
    Without any specific overclocking
    May 18, 2015
    Las Vegas, NV
    279
    08:17 AM
    Hi Geert,
    Was meaning to reply sooner. I would get back into the BIOS and default it which is usually F5 or F7, please check the BIOS shorcuts usually in the help section to be certain. Please check fan speed settings before defaulting as well, especially if you have an AIO Liquid Cooler. Take notes as these will be set to default as well in the process.
    After it is defaulted you can enable the XMP profile if you like to make sure you are getting the most out of your RAM. With Intel you shouldnt need to do anything else, RAM should be stable at default XMP.
    Your score as it is seems within range but I think you might be able to get it closer to 90 seconds flat. Stock Intel boost table for the 9900k should be as follows
    50x = 1 core/thread load
    50
    49
    48
    48
    47
    47
    47x = 8+ threads (technically this can drop to 40-43x after TDP is exceeded for 20-30 seconds)
    (Multiplier mentioned above x 100 = system mhz clock speed)
    47 x 100 = 4700 or 4.7ghz
    Either way, glad to see there was an improvement!
    Code:
        RevitForum.org
    Run on Revit 2020.1
    Update
       94.81   TOTAL
    Export benchmark
    Notes:
    Render benchmark
       50.91   render
        2.25   rotate view x1
       22.33   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: MS-7B98
    DPI Scaling: 100%
    RAW DATA:
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    07:17 AM
    The Xeon I was originally setup with:
    Code:
    RVT 2020 - Full_Standard set - 2019.09.20 @ 15.21.19 on KJWA-LV-297PM.txt
        RevitForum.org
    Run on Revit 2020.0.1
    Update
       13.35   update previous version file
        4.57   opening and loading the custom template
       12.47   creating the floors levels and grids
       17.75   creating a group of walls and doors
       30.53   modifying the group by adding a curtain wall
       11.62   creating the exterior curtain wall
       10.16   creating the sections
        3.95   changing the curtain wall panel type
       14.42   creating area plans
        2.01   creating and applying view template
      107.48   TOTAL
    Export benchmark
       57.57   export all views as PNGs at 300 dpi
       52.01   export all views as DWFs
       86.91   export all views as DWGs
       63.25   print all views as vector *
       90.14   print all views as raster *
    Notes:
    Render benchmark
       92.99   render
        5.27   activate View Styles view
        0.49   change view to Wireframe
        0.83   change view to Hidden
        1.10   change view to Shaded
        1.10   change view to Consistent Colors
        1.70   change view to Realistic
        0.87   refresh Wireframe Line view x10
        3.43   refresh Hidden Line view x10
        3.58   refresh Shaded view x10
        3.42   refresh Consistent Colors view x10
        3.77   refresh Realistic view x10
        0.45   activate View Cube view
        3.16   rotate view x1
       29.17   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 5820 Tower
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Xeon(R) W-2125 CPU @ 4.00GHz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 32GB @ 2666 2666Mhz
    Drive Model: PM981 NVMe SED Samsung 512GB
    Graphics Card: NVIDIA Quadro P5000
    Screen Resolution: 2560x1440x32bit @ 59Hz
    DPI Scaling: 100%
    RAW DATA:
       10.230    9.688    9.863   10.266   update previous version file
        4.539    4.613    4.555   opening and loading the custom template
       12.371   12.359   12.668   creating the floors levels and grids
       17.766   17.762   17.711   creating a group of walls and doors
       30.074   30.414   31.090   modifying the group by adding a curtain wall
       11.457   11.660   11.750   creating the exterior curtain wall
       10.215   10.270    9.984   creating the sections
        4.090    3.840    3.930   changing the curtain wall panel type
       14.793   14.770   13.711   creating area plans
        2.016    2.055    1.965   creating and applying view template
       57.414   57.930   57.359   export all views as PNGs at 300 dpi
       51.984   52.102   51.941   export all views as DWFs
       86.570   86.754   87.410   export all views as DWGs
       62.684   62.238   64.816   print all views as vector
       89.606   90.484   90.316   print all views as raster
       92.812   93.633   92.527   render
        5.219    5.336    5.246   activate View Styles view
        0.477    0.512    0.477   change view to Wireframe
        0.828    0.852    0.820   change view to Hidden
        1.082    1.141    1.066   change view to Shaded
        1.074    1.113    1.106   change view to Consistent Colors
        1.668    1.715    1.727   change view to Realistic
        0.867    0.871    0.863   refresh Wireframe Line view x10
        3.375    3.465    3.449   refresh Hidden Line view x10
        3.594    3.531    3.602   refresh Shaded view x10
        3.406    3.465    3.398   refresh Consistent Colors view x10
        3.723    3.852    3.730   refresh Realistic view x10
        0.445    0.461    0.453   activate View Cube view
        3.047    3.348    3.078   rotate view x1
    The i9 I decided to switch to instead, but realized I had disabled the Intel Speedstep in the BIOS:
    Code:
    RVT 2020 - Full_Standard set - 2019.09.20 @ 16.48.37 on KJWALV-297MP.txt
        RevitForum.org
    Update
       11.81   update previous version file
        4.49   opening and loading the custom template
       13.42   creating the floors levels and grids
       20.86   creating a group of walls and doors
       37.16   modifying the group by adding a curtain wall
       12.82   creating the exterior curtain wall
       10.36   creating the sections
        4.17   changing the curtain wall panel type
       14.48   creating area plans
        2.08   creating and applying view template
      119.84   TOTAL
    Export benchmark
       65.96   export all views as PNGs at 300 dpi
       57.95   export all views as DWFs
       98.21   export all views as DWGs
       62.15   print all views as vector *
      100.59   print all views as raster *
    Notes:
    Render benchmark
       63.90   render
        5.15   activate View Styles view
        0.46   change view to Wireframe
        0.79   change view to Hidden
        1.06   change view to Shaded
        1.04   change view to Consistent Colors
        1.81   change view to Realistic
        0.82   refresh Wireframe Line view x10
        3.74   refresh Hidden Line view x10
        3.98   refresh Shaded view x10
        3.76   refresh Consistent Colors view x10
        4.17   refresh Realistic view x10
        0.50   activate View Cube view
        3.18   rotate view x1
       30.46   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 3630 Tower
    Total Physical Memory: 64GB @ 2666 2666 2666 2666Mhz
    Drive Model: Micron 2200S NVMe 1024GB
    Graphics Card: NVIDIA Quadro RTX 4000
    Driver version: 26.21.14.3140
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 25.20.100.6617
    Screen Resolution: 2560 2560x1440 1440x32bit @ 59 59Hz
    DPI Scaling: 125%
    RAW DATA:
       12.891   11.262   11.277   update previous version file
        4.324    4.555    4.606   opening and loading the custom template
       14.188   12.836   13.250   creating the floors levels and grids
       20.391   20.356   21.840   creating a group of walls and doors
       36.242   36.410   38.820   modifying the group by adding a curtain wall
       12.770   12.469   13.234   creating the exterior curtain wall
        9.980    9.957   11.133   creating the sections
        4.004    4.094    4.422   changing the curtain wall panel type
       14.184   14.082   15.168   creating area plans
        2.102    2.023    2.121   creating and applying view template
       65.641   66.383   65.848   export all views as PNGs at 300 dpi
       57.258   59.406   57.191   export all views as DWFs
       97.777   99.578   97.281   export all views as DWGs
       61.969   63.043   61.430   print all views as vector
      100.543  101.191  100.031   print all views as raster
       58.582   76.621   56.504   render
        5.129    5.188    5.141   activate View Styles view
        0.457    0.477    0.453   change view to Wireframe
        0.805    0.785    0.781   change view to Hidden
        1.078    1.070    1.043   change view to Shaded
        1.027    1.059    1.023   change view to Consistent Colors
        1.832    1.793    1.797   change view to Realistic
        0.809    0.824    0.812   refresh Wireframe Line view x10
        3.746    3.758    3.711   refresh Hidden Line view x10
        4.023    3.965    3.953   refresh Shaded view x10
        3.730    3.801    3.758   refresh Consistent Colors view x10
        4.129    4.211    4.160   refresh Realistic view x10
        0.492    0.500    0.500   activate View Cube view
        3.168    3.223    3.156   rotate view x1
    Same i9, with Speedstep turned back on:
    Code:
    RVT 2020 - Full_Standard set - 2019.09.23 @ 13.29.33 on KJWALV-297MP.txt
        RevitForum.org
    Update
        9.64   update previous version file
        3.99   opening and loading the custom template
       10.63   creating the floors levels and grids
       15.89   creating a group of walls and doors
       27.81   modifying the group by adding a curtain wall
       10.11   creating the exterior curtain wall
        8.25   creating the sections
        3.32   changing the curtain wall panel type
       11.54   creating area plans
        1.68   creating and applying view template
       93.22   TOTAL
    Export benchmark
       51.91   export all views as PNGs at 300 dpi
       45.85   export all views as DWFs
       75.70   export all views as DWGs
       46.68   print all views as vector *
       78.35   print all views as raster *
    Notes:
    Render benchmark
       51.30   render
        4.58   activate View Styles view
        0.64   change view to Hidden
        0.86   change view to Shaded
        0.84   change view to Consistent Colors
        1.44   change view to Realistic
        2.97   refresh Hidden Line view x10
        3.10   refresh Shaded view x10
        2.96   refresh Consistent Colors view x10
        3.27   refresh Realistic view x10
        2.71   rotate view x1
       24.80   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Graphics RAM: 1GB
    DPI Scaling: 100%
    RAW DATA:
       10.363    9.281    9.285   update previous version file
        4.008    3.977    3.973   opening and loading the custom template
       10.754   10.473   10.656   creating the floors levels and grids
       15.965   15.742   15.953   creating a group of walls and doors
       27.754   27.766   27.910   modifying the group by adding a curtain wall
       10.113   10.051   10.156   creating the exterior curtain wall
        8.207    8.289    8.262   creating the sections
        3.340    3.320    3.309   changing the curtain wall panel type
       11.496   11.535   11.586   creating area plans
        1.695    1.672    1.688   creating and applying view template
       52.078   51.652   52.008   export all views as PNGs at 300 dpi
       46.043   45.676   45.820   export all views as DWFs
       75.375   75.285   76.434   export all views as DWGs
       44.379   47.375   48.301   print all views as vector
       77.836   77.953   79.266   print all views as raster
       51.344   50.449   52.117   render
        4.508    4.535    4.703   activate View Styles view
        0.387    0.375    0.387   change view to Wireframe
        0.617    0.617    0.680   change view to Hidden
        0.848    0.856    0.871   change view to Shaded
        0.824    0.828    0.867   change view to Consistent Colors
        1.418    1.426    1.465   change view to Realistic
        0.648    0.644    0.672   refresh Wireframe Line view x10
        2.918    2.965    3.023   refresh Hidden Line view x10
        3.051    3.137    3.117   refresh Shaded view x10
        2.930    2.977    2.973   refresh Consistent Colors view x10
        3.223    3.309    3.281   refresh Realistic view x10
        0.379    0.391    0.426   activate View Cube view
        2.672    2.691    2.754   rotate view x1
  1. RFO Benchmark v3.# 2019 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: September 3rd, 2020, 08:54 PM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
