Page 15 of 15 FirstFirst ... 51112131415
Results 141 to 147 of 147
Thread: RFO Benchmark v3.# 2020 results
  1. #141
    January 14, 2021
    01:59 AM
    Quote Originally Posted by remiscs View Post
    Hello guys,
    AMD 3970x 32core/64thread RFO run. Another non-revit build but ran it on the system. Impressive, this thing is a beast at parallel workloads but for the core count, single core is impressive!
    Code:
    RVT 2020 - Full_Standard set - 2020.02.12 @ 14.30.26 on DESKTOP-P1PLLG4.txt
        RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
    Run on Revit 2020 FCS
    Update
       10.41   update previous version file
    Model creation benchmark
        4.19   opening and loading the custom template
       11.34   creating the floors levels and grids
       17.27   creating a group of walls and doors
       29.60   modifying the group by adding a curtain wall
       10.83   creating the exterior curtain wall
        9.03   creating the sections
        3.65   changing the curtain wall panel type
       13.17   creating area plans
        1.82   creating and applying view template
      100.90   TOTAL
    Export benchmark
       59.23   export all views as PNGs at 300 dpi
       52.94   export all views as DWFs
       87.07   export all views as DWGs
       61.66   print all views as vector *
       93.65   print all views as raster *
    Notes:
    Render benchmark
       20.90   render
    Graphics - Standard View
        4.88   activate View Styles view
        0.43   change view to Wireframe
        0.63   change view to Hidden
        0.87   change view to Shaded
        0.86   change view to Consistent Colors
        1.52   change view to Realistic
        0.68   refresh Wireframe Line view x10
        3.00   refresh Hidden Line view x10
        3.19   refresh Shaded view x10
        3.06   refresh Consistent Colors view x10
        3.35   refresh Realistic view x10
        0.41   activate View Cube view
        2.45   rotate view x1
       25.33   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    CPU: AMD Ryzen Threadripper 3970X 32-Core Processor
    Max Clock Speed: 3.693Ghz
    Number of Processors: 32
    Number of Logical Processors: 64
    Total Physical Memory: 64GB @ 3600 3600 3600 3600Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: Samsung SSD 970 EVO Plus 2TB
    Graphics Card: NVIDIA GeForce RTX 2080 Ti
    Graphics RAM: 3.9990234375GB
    Driver version: 26.21.14.4219
    Screen Resolution: 1920 x1080 x32bit @ 60 Hz
    DPI Scaling: 100%
    RAW DATA:
       11.012    9.992   10.227   update previous version file
        4.238    4.160    4.172   opening and loading the custom template
       11.891   11.035   11.098   creating the floors levels and grids
       17.644   17.020   17.152   creating a group of walls and doors
       29.734   29.394   29.676   modifying the group by adding a curtain wall
       10.988   10.809   10.699   creating the exterior curtain wall
        8.996    9.023    9.059   creating the sections
        3.742    3.606    3.613   changing the curtain wall panel type
       13.500   13.016   12.988   creating area plans
        1.856    1.801    1.793   creating and applying view template
       59.383   59.043   59.250   export all views as PNGs at 300 dpi
       53.301   52.695   52.812   export all views as DWFs
       86.902   87.375   86.938   export all views as DWGs
       61.617   61.691   61.680   print all views as vector
       94.023   93.367   93.566   print all views as raster
       20.930   20.848   20.938   render
        4.891    4.836    4.926   activate View Styles view
        0.441    0.410    0.426   change view to Wireframe
        0.633    0.621    0.637   change view to Hidden
        0.875    0.856    0.879   change view to Shaded
        0.867    0.856    0.871   change view to Consistent Colors
        1.566    1.473    1.527   change view to Realistic
        0.680    0.684    0.680   refresh Wireframe Line view x10
        3.016    2.996    3.000   refresh Hidden Line view x10
        3.195    3.195    3.191   refresh Shaded view x10
        3.059    3.055    3.055   refresh Consistent Colors view x10
        3.356    3.352    3.352   refresh Realistic view x10
        0.406    0.402    0.410   activate View Cube view
        2.449    2.422    2.477   rotate view x1
    Hello remiscs! Would you mind take a look of my test and give some advices on why my benchmark is soo low? thanks!
    I have 3970x too but the benchmark is very rough for me especially on Model creation benchmark I got around 142 secs at mutuple times. There could be mutiple reasons for that I am not sure, from what I see the main difference from my set to your set is the memory speed. I have the 3200mhz running on 4 channels at total 32x4128gb.
    I did turn on the muti-thread and test on either default and auto oc setting on my cpu.
  2. #142
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    191
    02:59 AM
    Maybe have a look in this thread:
    https://revitforum.org/showthread.ph...l=1#post235112
    This solved my issues with my underperforming i7.
  3. #143
    Junior Member apsis0215's Avatar
    February 16, 2012
    7
    09:59 PM
    Code:
    RVT 2020 - Full_Expanded set - 2021.01.20 @ 14.25.54 on IRVBOXX-08.txt
        RFO Benchmark v3.3 (build 30.07.2020)
        RevitForum.org
    Run on Revit 2020.2.3
    Update
        9.32   update previous version file
        4.05   opening and loading the custom template
        0.04   saving the new project
       13.28   loading and arraying link
       14.87   setting links to halftone
        0.62   saving the project with links
       31.18   creating the floors levels and grids
       17.13   creating a group of walls and doors
       28.96   modifying the group by adding a curtain wall
       47.36   creating the exterior curtain wall
       20.68   creating the sections
       10.95   changing the curtain wall panel type
       18.62   creating area plans
        2.52   creating and applying view template
        0.90   saving the project with completed model
      211.16   TOTAL
    Export benchmark
      912.50   export all views as PNGs at 300 dpi
      478.40   export all views as DWFs
     1853.99   export all views as DWGs
     2257.21   print all views as vector *
        0.00   print all views as raster *
    Notes:
    Render benchmark
       51.36   render
    Graphics - Activate first view
       22.66   activate View Styles view
    Graphics - Change view visual style from a common start
       12.89   common start: from Hidden Line to Wireframe
       13.80   common start: from Hidden Line to Shaded
       13.23   common start: from Hidden Line to Consistent Colors
       14.58   common start: from Hidden Line to Realistic
        5.29   common start: from Consistent Colors to Wireframe
       13.04   common start: from Consistent Colors to Hidden Line
       13.84   common start: from Consistent Colors to Shaded
       14.10   common start: from Consistent Colors to Realistic
      100.77   TOTAL
    Graphics - Change view visual style from a common end
       12.95   common end: from Wireframe to Hidden Line
       12.96   common end: from Shaded to Hidden Line
       13.14   common end: from Consistent Colors to Hidden Line
       13.04   common end: from Realistic to Hidden Line
       12.95   common end: from Wireframe to Consistent Colors
       13.32   common end: from Hidden Line to Consistent Colors
       13.33   common end: from Shaded to Consistent Colors
       13.08   common end: from Realistic to Consistent Colors
      104.77   TOTAL
    Graphics - Change view visual style in sequence
        5.19   in sequence: from Realistic to Wireframe
       12.94   in sequence: from Wireframe to Hidden Line
       13.71   in sequence: from Hidden Line to Shaded
       13.15   in sequence: from Shaded to Consistent Colors
       14.09   in sequence: from Consistent Colors to Realistic
       13.14   in sequence: from Realistic to Consistent Colors
       13.71   in sequence: from Consistent Colors to Shaded
       13.06   in sequence: from Shaded to Hidden Line
        5.25   in sequence: from Hidden Line to Wireframe
      104.24   TOTAL
    Graphics - Refresh views
       29.67   refresh Wireframe view x10
       64.63   refresh Hidden Line view x10
       67.62   refresh Shaded view x10
       65.70   refresh Consistent Colors view x10
       68.58   refresh Realistic view x10
      296.20   TOTAL
    Graphics - Rotate views
        7.57   activate View Cube view
       36.32   rotate view x1
        4.50   activate View Cube - Sketchy view
       48.65   rotate sketchy view x1
       97.04   TOTAL
    Notes:
        To meaningfully compare graphics cards, test all cards in the same machine.
    TEST CONDITIONS:
    Mfr:   BOXX Technologies
    Model: FLEXX S1G_01
    OS:    Microsoft Windows 10 Pro for Workstations 64-bit (build 1909)
    CPU0: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Physical Processors: 8
    Logical Processors: 8
    Total Physical Memory: 32GB
    BANK 0: 16GB @ 2666Mhz
    BANK 2: 16GB @ 2666Mhz
    Graphics Card: NVIDIA Quadro P2200
    Driver version: 27.21.14.5239
    Screen Resolution: 1819 x 919 x bit @ 60Hz (max 60Hz)
    DPI Scaling: 100%
    Drive Type: Local Disk (NTFS)
    Drive Model: Samsung SSD 970 PRO 512GB
  4. #144
    February 16, 2012
    7
    09:59 PM
    Code:
    RVT 2020 - Graphics_Comparison set - 2021.01.21 @ 08.32.10 on IRVBOXX-08.txt
        RevitForum.org
        4.26   activate View Styles view
        0.35   change view to Wireframe
        0.51   change view to Hidden
        0.68   change view to Shaded
        0.69   change view to Consistent Colors
        1.18   change view to Realistic
        0.58   refresh Wireframe Line view x10
        2.35   refresh Hidden Line view x10
        2.52   refresh Shaded view x10
        2.38   refresh Consistent Colors view x10
        2.63   refresh Realistic view x10
        0.32   activate View Cube view
        1.97   rotate view x1
       20.42   TOTAL
    Graphics - Sketchy View
        0.29   activate View Styles - Sketchy view
        1.36   change sketchy view to Wireframe
        0.79   change sketchy view to Hidden
        1.02   change sketchy view to Shaded
        0.99   change sketchy view to Consistent Colors
        0.85   change sketchy view to Realistic
        1.19   refresh sketchy Wireframe Line view x10
        2.96   refresh sketchy Hidden Line view x10
        3.13   refresh sketchy Shaded view x10
        2.99   refresh sketchy Consistent Colors view x10
        3.25   refresh sketchy Realistic view x10
        0.38   activate View Cube - Sketchy view
        2.39   rotate sketchy view x1
       21.59   TOTAL
    Graphics - Levels View
        0.35   activate View Styles - Levels view
        1.02   change levels view to Wireframe
        0.61   change levels view to Hidden
        0.79   change levels view to Shaded
        0.86   change levels view to Consistent Colors
        0.80   change levels view to Realistic
        1.23   refresh levels Wireframe Line view x10
        3.07   refresh levels Hidden Line view x10
        3.24   refresh levels Shaded view x10
        3.09   refresh levels Consistent Colors view x10
        3.19   refresh levels Realistic view x10
        0.39   activate View Cube - levels view
        2.05   rotate levels view x1
       20.69   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: FLEXX S1G_01
    DPI Scaling: 100%
  5. #145
    Member Marcel Jansen's Avatar
    December 26, 2011
    The Netherlands
    296
    02:59 AM
    Quote Originally Posted by apsis0215 View Post
    Code:
        RevitForum.org
    Update
      211.16   TOTAL
    Export benchmark
    Notes:
    Render benchmark
       51.36   render
      100.77   TOTAL
      104.77   TOTAL
      104.24   TOTAL
      296.20   TOTAL
       97.04   TOTAL
    Notes:
    TEST CONDITIONS:
    Model: FLEXX S1G_01
    DPI Scaling: 100%
    This is a really bad score for that CPU, it should be around 100 sec instead of the 211 you get.
  6.    #146
    February 2, 2021
    07:59 PM
    AMD Build (Ryzen 3900X with Radeon 6800XT)
    Code:
    RVT 2021 - Full_Standard set - 2021.02.02 @ 12.42.42 on GEOFFRO-DESKTOP.txt
        RevitForum.org
    Run on Revit 2021 FCS
    Update
       12.16   update previous version file
        5.52   opening and loading the custom template
       16.59   creating the floors levels and grids
       24.45   creating a group of walls and doors
       36.94   modifying the group by adding a curtain wall
       15.29   creating the exterior curtain wall
       12.23   creating the sections
        5.03   changing the curtain wall panel type
       18.50   creating area plans
        3.00   creating and applying view template
      137.55   TOTAL
    Export benchmark
       65.80   export all views as PNGs at 300 dpi
       56.92   export all views as DWFs
      106.54   export all views as DWGs
       67.52   print all views as vector *
      104.79   print all views as raster *
    Notes:
    Render benchmark
       37.57   render
        6.22   activate View Styles view
        0.48   change view to Wireframe
        0.70   change view to Hidden
        0.98   change view to Shaded
        0.99   change view to Consistent Colors
        5.09   change view to Realistic
        0.87   refresh Wireframe Line view x10
        3.51   refresh Hidden Line view x10
        3.76   refresh Shaded view x10
        3.61   refresh Consistent Colors view x10
        3.95   refresh Realistic view x10
        0.49   activate View Cube view
        3.27   rotate view x1
       33.92   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr:   To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    OS:    Microsoft Windows 10 Pro 64-bit (build 2009)
    CPU0: AMD Ryzen 9 3900X 12-Core Processor
    Max Clock Speed: 4.2Ghz
    Physical Processors: 12
    Logical Processors: 24
    P0 CHANNEL A: 32GB @ 3200Mhz
    P0 CHANNEL B: 32GB @ 3200Mhz
    Graphics Card: AMD Radeon RX 5700 XT
    Driver version: 27.20.14533.1000
    Screen Resolution: 1280 x 720 x bit @ 59Hz (max 75Hz)
    Graphics Card: AMD Radeon RX 6800 XT
    Screen Resolution: 3840 x 1200 x bit @ 120Hz (max 120Hz)
    DPI Scaling: 100%
    Drive Model:  ST4000DM004-2CV1 SCSI Disk Device
    RAW DATA:
       14.680   10.898   10.910   update previous version file
        5.633    5.457    5.461   opening and loading the custom template
       16.805   16.543   16.434   creating the floors levels and grids
       24.602   24.387   24.356   creating a group of walls and doors
       37.031   36.949   36.836   modifying the group by adding a curtain wall
       14.898   15.621   15.340   creating the exterior curtain wall
       12.039   12.055   12.602   creating the sections
        5.098    4.969    5.027   changing the curtain wall panel type
       18.785   18.508   18.211   creating area plans
        2.922    3.082    2.996   creating and applying view template
       65.766   65.555   66.078   export all views as PNGs at 300 dpi
       56.852   56.582   57.336   export all views as DWFs
      106.227  103.805  109.578   export all views as DWGs
       68.254   66.973   67.336   print all views as vector
      104.398  104.941  105.020   print all views as raster
       37.648   36.727   38.328   render
        6.137    6.160    6.359   activate View Styles view
        0.453    0.480    0.508   change view to Wireframe
        0.691    0.707    0.707   change view to Hidden
        0.973    0.988    0.992   change view to Shaded
        0.984    0.992    1.004   change view to Consistent Colors
        5.129    5.012    5.117   change view to Realistic
        0.856    0.867    0.883   refresh Wireframe Line view x10
        3.516    3.488    3.539   refresh Hidden Line view x10
        3.719    3.727    3.844   refresh Shaded view x10
        3.547    3.578    3.691   refresh Consistent Colors view x10
        3.883    3.852    4.102   refresh Realistic view x10
        0.488    0.465    0.523   activate View Cube view
        3.262    3.230    3.309   rotate view x1
  7.    #147
    March 19, 2014
    64
    02:59 AM
    Well the 3900 should be faster because with the i7-4790K i get for model creation is 115 with a fully installed workstation and no tinkering...
    Your cpu is probably also holding back the gpu score. What i've seen is that when the cpu gets a lot faster the gpu score also gets much better.
    The question is: is revit feeling much faster when the model creation goes from 115 to 80?
  1. RFO Benchmark v3.# 2019 results
    Last Post: November 15th, 2020, 10:29 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 09:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 12:39 PM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 01:00 AM
