Page 2 of 15 FirstFirst 12345612 ... LastLast
Results 11 to 20 of 147
Thread: RFO Benchmark v3.# 2020 results
  1. #11
    December 20, 2010
    1,152
    09:45 PM
    Is there anyone putting together a graph comparing the results from release to lease. IE average times reported for each benchmark from all the data gathered here, so we can see the performance improvements year to year compiled?
  2. #12
    11,550
    08:45 PM
    I used to keep one, and it was a monster. But there are too many factors that affect the outcome, especially when you consider a production machine thats been in use for multiple years. If you want to see the difference in just how Revit performs, i would want to:
    Take a clean machine (freshly imaged): Install 2016. Run RFOB.
    Reimage the same machine: Install 2017. Run RFOB.
    Reimage the same machine: Install 2018. Run RFOB.
    Reimage the same machine: Install 2019. Run RFOB.
    Reimage the same machine: Install 2020. Run RFOB.
    Even then, i think there are minor differences in RFOB 3.1 and 3.2, but i dont remember if any of them mean a different in scores.
    My *butt dyno* says that 2020 is a bit faster than 2019. But thats not very scientific.
  3. #13
    Member tidalwave1's Avatar
    OKC
    146
    06:45 PM
    My new computer at work...
    Code:
    RVT 2020 - Full_Standard set - 2019.09.30 @ 15.16.22 on KJWA-LV-284.txt
        RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
    Run on Revit 2020 FCS
    Update
       11.43   update previous version file
    Model creation benchmark
        4.99   opening and loading the custom template
       13.85   creating the floors levels and grids
       20.96   creating a group of walls and doors
       35.72   modifying the group by adding a curtain wall
       13.58   creating the exterior curtain wall
       11.14   creating the sections
        4.37   changing the curtain wall panel type
       16.20   creating area plans
        2.40   creating and applying view template
      123.21   TOTAL
    Export benchmark
       68.09   export all views as PNGs at 300 dpi
       58.90   export all views as DWFs
       98.86   export all views as DWGs
       73.82   print all views as vector *
      115.29   print all views as raster *
    Notes:
    Render benchmark
       76.05   render
    Graphics - Standard View
        5.69   activate View Styles view
        0.51   change view to Wireframe
        0.83   change view to Hidden
        1.13   change view to Shaded
        1.11   change view to Consistent Colors
        1.82   change view to Realistic
        0.89   refresh Wireframe Line view x10
        3.73   refresh Hidden Line view x10
        3.96   refresh Shaded view x10
        3.82   refresh Consistent Colors view x10
        4.15   refresh Realistic view x10
        0.57   activate View Cube view
        3.16   rotate view x1
       31.37   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: Precision 5820 Tower
    OS: Microsoft Windows 10 Pro for Workstations64-bit
    CPU: Intel(R) Xeon(R) W-2133 CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Number of Processors: 6
    Number of Logical Processors: 12
    Total Physical Memory: 64GB @ 2666 2666 2666 2666Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: NVMe KXG50ZNV512G NVM
    Graphics Card: NVIDIA Quadro P4000
    Graphics RAM: 3.9990234375GB
    Driver version: 23.21.13.9133
    DPI Scaling: 100%
    RAW DATA:
       11.379   11.391   11.508   update previous version file
        4.980    5.016    4.973   opening and loading the custom template
       13.996   13.816   13.734   creating the floors levels and grids
       20.867   21.059   20.957   creating a group of walls and doors
       35.496   35.602   36.055   modifying the group by adding a curtain wall
       13.543   13.434   13.754   creating the exterior curtain wall
       11.133   11.156   11.129   creating the sections
        4.301    4.379    4.426   changing the curtain wall panel type
       16.156   16.184   16.258   creating area plans
        2.375    2.398    2.426   creating and applying view template
       68.027   68.152   68.090   export all views as PNGs at 300 dpi
       59.180   58.758   58.758   export all views as DWFs
       98.969   98.945   98.672   export all views as DWGs
       73.984   73.574   73.914   print all views as vector
      115.594  115.223  115.062   print all views as raster
       82.484   73.012   72.656   render
        5.688    5.734    5.656   activate View Styles view
        0.508    0.512    0.523   change view to Wireframe
        0.840    0.820    0.844   change view to Hidden
        1.109    1.137    1.133   change view to Shaded
        1.090    1.098    1.129   change view to Consistent Colors
        1.809    1.828    1.832   change view to Realistic
        0.902    0.879    0.875   refresh Wireframe Line view x10
        3.715    3.766    3.711   refresh Hidden Line view x10
        3.938    3.988    3.945   refresh Shaded view x10
        3.848    3.836    3.766   refresh Consistent Colors view x10
        4.168    4.141    4.144   refresh Realistic view x10
        0.570    0.574    0.562   activate View Cube view
        3.137    3.164    3.176   rotate view x1
  4. #14
    OKC
    146
    06:45 PM
    my personal laptop that I bought earlier this summer...
    Code:
    RVT 2020 - Full_Standard set - 2019.10.02 @ 09.26.04 on DESKTOP-UNU14DL.txt
        RevitForum.org
    Run on Revit 2020.1
    Update
       11.96   update previous version file
        5.00   opening and loading the custom template
       13.54   creating the floors levels and grids
       19.99   creating a group of walls and doors
       34.80   modifying the group by adding a curtain wall
       13.09   creating the exterior curtain wall
       10.85   creating the sections
        4.23   changing the curtain wall panel type
       16.19   creating area plans
        2.13   creating and applying view template
      119.82   TOTAL
    Export benchmark
       64.32   export all views as PNGs at 300 dpi
       65.96   export all views as DWFs
      103.62   export all views as DWGs
       68.73   print all views as vector *
       98.40   print all views as raster *
    Notes:
    Render benchmark
       90.06   render
        5.77   activate View Styles view
        0.75   change view to Wireframe
        0.85   change view to Hidden
        1.04   change view to Shaded
        1.04   change view to Consistent Colors
        1.72   change view to Realistic
        0.83   refresh Wireframe Line view x10
        3.16   refresh Hidden Line view x10
        3.33   refresh Shaded view x10
        3.15   refresh Consistent Colors view x10
        3.58   refresh Realistic view x10
        0.45   activate View Cube view
        2.87   rotate view x1
       28.54   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Dell Inc.
    Model: XPS 15 7590
    CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz
    Max Clock Speed: 2.592Ghz
    Total Physical Memory: 32GB @ 2667 2667Mhz
    Drive Model: NVMe Samsung SSD 970
    Graphics Card: Intel(R) UHD Graphics 630
    Graphics RAM: 1GB
    Driver version: 26.20.100.6911
    Graphics Card: NVIDIA GeForce GTX 1650
    Driver version: 26.21.14.3123
    Screen Resolution: 1920 x1080 x32bit @ 59 Hz
    DPI Scaling: 125%
    RAW DATA:
       12.504   11.676   11.695   update previous version file
        5.000    4.988    5.012   opening and loading the custom template
       13.723   13.516   13.375   creating the floors levels and grids
       19.949   20.188   19.848   creating a group of walls and doors
       34.746   34.766   34.887   modifying the group by adding a curtain wall
       13.270   13.047   12.945   creating the exterior curtain wall
       10.777   10.914   10.859   creating the sections
        4.242    4.227    4.219   changing the curtain wall panel type
       16.176   16.207   16.188   creating area plans
        2.211    2.109    2.082   creating and applying view template
       64.418   64.230   64.316   export all views as PNGs at 300 dpi
       65.176   66.402   66.297   export all views as DWFs
      104.336  103.656  102.883   export all views as DWGs
       68.625   68.887   68.691   print all views as vector
       98.242   98.441   98.520   print all views as raster
       87.289   86.945   95.953   render
        5.746    5.707    5.871   activate View Styles view
        0.758    0.742    0.742   change view to Wireframe
        0.875    0.848    0.840   change view to Hidden
        1.043    1.035    1.051   change view to Shaded
        1.031    1.047    1.027   change view to Consistent Colors
        1.715    1.727    1.719   change view to Realistic
        0.820    0.836    0.848   refresh Wireframe Line view x10
        3.160    3.113    3.199   refresh Hidden Line view x10
        3.309    3.309    3.359   refresh Shaded view x10
        3.137    3.141    3.184   refresh Consistent Colors view x10
        3.617    3.570    3.559   refresh Realistic view x10
        0.449    0.445    0.453   activate View Cube view
        2.867    2.840    2.902   rotate view x1
  5. #15
    June 4, 2019
    03:45 AM
    My new gaming rig.
    Code:
    RVT 2020 - Full_Simplified set - 2019.11.17 @ 00.24.13 on DESKTOP-D8RPILT.txt
        RevitForum.org
        3.89   opening and loading the custom template
        9.83   creating the floors levels and grids
       15.54   creating a group of walls and doors
       28.32   modifying the group by adding a curtain wall
        9.52   creating the exterior curtain wall
        7.36   creating the sections
        3.08   changing the curtain wall panel type
       10.74   creating area plans
        1.49   creating and applying view template
       89.77   TOTAL
    Graphics
        4.38   activate View Styles view
        0.91   change view to Wireframe
        0.06   change view to Hidden
        0.28   change view to Shaded
        0.30   change view to Consistent Colors
        0.29   change view to Realistic
        0.65   refresh Wireframe Line view x10
        2.86   refresh Hidden Line view x10
        3.06   refresh Shaded view x10
        2.89   refresh Consistent Colors view x10
        3.74   refresh Realistic view x10
        0.34   activate View Cube view
        2.04   rotate view x1
       21.80   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: Z390 AORUS ULTRA
    CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz
    Max Clock Speed: 4.008Ghz
    Number of Processors: 8
    Number of Logical Processors: 16
    Total Physical Memory: 32GB @ 3200 3200Mhz
    Drive Model: KINGSTON SA2000M8500G
    Graphics Card: NVIDIA GeForce GTX 1080 Ti
    Driver version: 26.21.14.4120
    DPI Scaling: 100%
  6. #16
    September 9, 2019
    09:45 PM
    2 Not allowed! Not allowed!
    New build for an open Revit designer position I have. 9900k OC to 5.3ghz 2 core and 5.2ghz all core. Water cooled. I haven't overclocked the 1080ti yet. I couldn't get the standard test to run correctly but the simplified set and the Graphics test ran fine.
    Code:
    RVT 2020 - Full_Simplified set - 2019.11.13 @ 16.49.19 on DESKTOP-EP1MT1E.txt
        RevitForum.org
        2.64   opening and loading the custom template
        7.09   creating the floors levels and grids
       13.44   creating a group of walls and doors
       25.02   modifying the group by adding a curtain wall
        8.02   creating the exterior curtain wall
        5.87   creating the sections
        2.68   changing the curtain wall panel type
        8.29   creating area plans
        1.23   creating and applying view template
       74.28   TOTAL
    Graphics
        3.47   activate View Styles view
        0.83   change view to Wireframe
        0.27   change view to Shaded
        0.29   change view to Consistent Colors
        0.27   change view to Realistic
        0.62   refresh Wireframe Line view x10
        3.03   refresh Hidden Line view x10
        2.88   refresh Shaded view x10
        2.73   refresh Consistent Colors view x10
        3.55   refresh Realistic view x10
        0.31   activate View Cube view
        1.87   rotate view x1
       20.18   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Micro-Star International Co., Ltd.
    Model: MS-7B17
    OS: Microsoft Windows 10 Enterprise 2016 LTSB64-bit
    CPU: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Total Physical Memory: 64GB @ 3200 3200 3200 3200Mhz
    Drive Model: Sabrent
    Driver version: 23.21.13.9135
    DPI Scaling: 100%
    Graphics_Expanded
    Code:
    RVT 2020 - Graphics_Expanded set - 2019.11.13 @ 16.55.56 on DESKTOP-EP1MT1E.txt
        RevitForum.org
    Graphics - Activate first view
       20.25   activate View Styles view
    Graphics - Change view visual style from a common start
       11.98   common start: from Hidden Line to Wireframe
       12.12   common start: from Hidden Line to Shaded
       11.78   common start: from Hidden Line to Consistent Colors
       13.23   common start: from Hidden Line to Realistic
        4.42   common start: from Consistent Colors to Wireframe
       11.93   common start: from Consistent Colors to Hidden Line
       12.25   common start: from Consistent Colors to Shaded
       12.75   common start: from Consistent Colors to Realistic
       90.46   TOTAL
    Graphics - Change view visual style from a common end
       11.70   common end: from Wireframe to Hidden Line
       11.97   common end: from Shaded to Hidden Line
       11.96   common end: from Consistent Colors to Hidden Line
       11.95   common end: from Realistic to Hidden Line
       11.81   common end: from Wireframe to Consistent Colors
       11.99   common end: from Hidden Line to Consistent Colors
       12.00   common end: from Shaded to Consistent Colors
       12.05   common end: from Realistic to Consistent Colors
       95.43   TOTAL
    Graphics - Change view visual style in sequence
        4.32   in sequence: from Realistic to Wireframe
       11.75   in sequence: from Wireframe to Hidden Line
       12.30   in sequence: from Hidden Line to Shaded
       11.97   in sequence: from Shaded to Consistent Colors
       12.83   in sequence: from Consistent Colors to Realistic
       11.85   in sequence: from Realistic to Consistent Colors
       12.32   in sequence: from Consistent Colors to Shaded
       11.92   in sequence: from Shaded to Hidden Line
        4.45   in sequence: from Hidden Line to Wireframe
       93.71   TOTAL
    Graphics - Refresh views
       28.63   refresh Wireframe view x10
       65.26   refresh Hidden Line view x10
       67.90   refresh Shaded view x10
       66.07   refresh Consistent Colors view x10
       68.23   refresh Realistic view x10
      296.09   TOTAL
    Graphics - Rotate views
        7.59   activate View Cube view
       34.45   rotate view x1
        2.83   activate View Cube - Sketchy view
       47.16   rotate sketchy view x1
       92.03   TOTAL
    Notes:
        To meaningfully compare graphics cards, test all cards in the same machine.
    TEST CONDITIONS:
    Model: MS-7B17
    DPI Scaling: 100%
  7. #17
    11,550
    08:45 PM
    Got the new Anvil (Texas Edition) up and running, and ran it through all of its Deployments last night. Just knocked out a 2020 benchmark (3.2) to make sure everything was working as expected.
    Code:
    RVT 2020 - Full_Standard set - 2019.12.19 @ 12.18.44 on PRLXRCWS02.txt    RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
    Run on Revit 2020.2
    Update
        8.91   update previous version file
        3.99   opening and loading the custom template
        9.61   creating the floors levels and grids
       14.30   creating a group of walls and doors
       25.32   modifying the group by adding a curtain wall
        8.80   creating the exterior curtain wall
        7.01   creating the sections
        2.84   changing the curtain wall panel type
       10.17   creating area plans
        1.42   creating and applying view template
       83.46   TOTAL
    Export benchmark
       46.16   export all views as PNGs at 300 dpi
       42.88   export all views as DWFs
       67.49   export all views as DWGs
       44.19   print all views as vector *
       71.61   print all views as raster *
    Notes:
    Render benchmark
       43.98   render
        4.24   activate View Styles view
        0.33   change view to Wireframe
        0.50   change view to Hidden
        0.69   change view to Shaded
        0.69   change view to Consistent Colors
        1.21   change view to Realistic
        0.56   refresh Wireframe Line view x10
        2.46   refresh Hidden Line view x10
        2.63   refresh Shaded view x10
        2.48   refresh Consistent Colors view x10
        2.76   refresh Realistic view x10
        0.33   activate View Cube view
        2.05   rotate view x1
       20.93   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: System manufacturer
    Model: System Product Name
    Total Physical Memory: 64GB @ 3600 3600 3600 3600Mhz
    Drive Model: Samsung SSD 970 EVO 2TB
    Graphics Card: NVIDIA GeForce RTX 2080 Ti
    Driver version: 26.21.14.4128
    DPI Scaling: 100%
    RAW DATA:
        9.644    8.566    8.508   update previous version file
        4.020    3.969    3.988   opening and loading the custom template
        9.621    9.688    9.508   creating the floors levels and grids
       14.394   14.258   14.238   creating a group of walls and doors
       25.328   25.262   25.363   modifying the group by adding a curtain wall
        8.848    8.816    8.727   creating the exterior curtain wall
        7.035    7.004    6.980   creating the sections
        2.879    2.836    2.805   changing the curtain wall panel type
       10.188   10.156   10.180   creating area plans
        1.434    1.441    1.391   creating and applying view template
       46.176   46.176   46.121   export all views as PNGs at 300 dpi
       43.016   42.863   42.766   export all views as DWFs
       67.684   67.375   67.410   export all views as DWGs
       44.453   44.039   44.086   print all views as vector
       71.852   71.531   71.449   print all views as raster
       45.820   45.887   40.238   render
        4.211    4.258    4.246   activate View Styles view
        0.328    0.336    0.316   change view to Wireframe
        0.516    0.496    0.480   change view to Hidden
        0.703    0.688    0.691   change view to Shaded
        0.688    0.691    0.688   change view to Consistent Colors
        1.219    1.215    1.191   change view to Realistic
        0.566    0.555    0.555   refresh Wireframe Line view x10
        2.480    2.457    2.449   refresh Hidden Line view x10
        2.660    2.609    2.613   refresh Shaded view x10
        2.504    2.477    2.469   refresh Consistent Colors view x10
        2.793    2.750    2.746   refresh Realistic view x10
        0.332    0.332    0.328   activate View Cube view
        2.031    2.051    2.062   rotate view x1
    Super happy with it. Both this one, and the 8086k variant i have from 18 months ago, are going to be around for a while.
  8. #18
    New Member bimboxusa's Avatar
    February 11, 2019
    San Diego
    06:45 PM
    We have been working with a client, Clark Construction, on a much heavier RFO. Would love to work to get it on here. Included multiple linked files, and we have added a point cloud in as well. Single test on a BIMBOX Stryker II takes 13:46. It hit the system a lot harder. Would love to collaborate to get it on here if your open.
  9. #19
    March 19, 2014
    64
    03:45 AM
    Love to see the new amd ryzen 3x00(X) being tested. Too bad there aren't any
  10. #20
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    314
    06:45 PM
    Quote Originally Posted by mdingemanse View Post
    I have only built a few 3950x systems for software developers but in benchmarking them in other software I am sure it will do well in Revit. Problem is, the 9900k should be as good and more likely better than a 3900x/3950x and both of those CPU currently cost more. I suspect the 3800x would fall behind the 9900k.
    The AMD supply is finally starting to stabilize so I am sure I will start selling more of them, I just do not see them being the go to CPU for most AEC/BIM applications. That is not to say that the 3800x/3900x/3950x would be bad either, just not the best for Revit. Unlike previous Ryzen in which I think would have been a bad choice.
  1. RFO Benchmark v3.# 2019 results
    Last Post: November 15th, 2020, 10:29 AM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 09:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 12:39 PM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 01:00 AM
