Excellent results. Done via a Remote Desktop session.
Code:RVT 2020 - Full_Simplified set - 2020.01.23 @ 16.19.41 on WINDOWS-DJJS20I.txt RFO Benchmark v3.2 (build 19.08.2019) RevitForum.orgAll times are in seconds, lower is better. Run on Revit 2020 FCS_________________________________________________________________ Model creation benchmark 4.61 opening and loading the custom template 9.88 creating the floors levels and grids 14.99 creating a group of walls and doors 26.74 modifying the group by adding a curtain wall 8.96 creating the exterior curtain wall 6.93 creating the sections 3.00 changing the curtain wall panel type 10.50 creating area plans 1.20 creating and applying view template 86.81 TOTAL_________________________________________________________________ Graphics 4.45 activate View Styles view 0.88 change view to Wireframe 0.07 change view to Hidden 0.27 change view to Shaded 0.29 change view to Consistent Colors 0.27 change view to Realistic 0.68 refresh Wireframe Line view x10 2.76 refresh Hidden Line view x10 2.93 refresh Shaded view x10 2.74 refresh Consistent Colors view x10 3.61 refresh Realistic view x10 0.33 activate View Cube view 1.89 rotate view x1 21.17 TOTALNotes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. TEST CONDITIONS: _______________________________________________________ Mfr: Micro-Star International Co., Ltd. Model: MS-7B17 OS: Microsoft Windows 10 Pro64-bit_______________________________________________________ CPU: Intel(R) Core(TM) i9-9900KS CPU @ 4.00GHz Max Clock Speed: 4.008Ghz Number of Processors: 8 Number of Logical Processors: 16 Total Physical Memory: 32GB @ 3000 3000Mhz_______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 970 EVO Plus 1TB_______________________________________________________ Graphics Card: Microsoft Remote Display Adapter Graphics RAM: 0GB Driver version: 10.0.18362.329Graphics Card: NVIDIA GeForce RTX 2080 SUPER Graphics RAM: 3.9990234375GB Driver version: 26.21.14.4166_______________________________________________________ Screen Resolution: 1280 1920x800 1080x32bit @ 32 60Hz DPI Scaling: 100%[FONT=Tahoma][/FONT]
Hi, everyone. This is my first post in this forum. I want to share my RFO Benchmark result of my new laptop:
Code:RVT 2020 - Full_Simplified set - 2020.02.09 @ 13.01.31 on MSI.txt RFO Benchmark v3.2 (build 19.08.2019) RevitForum.org All times are in seconds, lower is better. Run on Revit 2020.2.1 _________________________________________________________________ Model creation benchmark 5.21 opening and loading the custom template 11.18 creating the floors levels and grids 17.71 creating a group of walls and doors 30.87 modifying the group by adding a curtain wall 10.91 creating the exterior curtain wall 9.21 creating the sections 3.80 changing the curtain wall panel type 13.70 creating area plans 1.97 creating and applying view template 104.56 TOTAL _________________________________________________________________ Graphics 4.32 activate View Styles view 1.25 change view to Wireframe 0.08 change view to Hidden 0.36 change view to Shaded 0.46 change view to Consistent Colors 0.35 change view to Realistic 0.90 refresh Wireframe Line view x10 3.91 refresh Hidden Line view x10 3.99 refresh Shaded view x10 3.81 refresh Consistent Colors view x10 4.65 refresh Realistic view x10 0.42 activate View Cube view 2.57 rotate view x1 27.07 TOTAL Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. TEST CONDITIONS: _______________________________________________________ Mfr: Micro-Star International Co., Ltd. Model: WS65 9TK OS: Microsoft Windows 10 Home Single Language64-bit _______________________________________________________ CPU: Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz Max Clock Speed: 2.601Ghz Number of Processors: 6 Number of Logical Processors: 12 Total Physical Memory: 32GB @ 2667 2667Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: WDC PC SN730 SDBPNTY-512G-1032 _______________________________________________________ Graphics Card: Intel(R) UHD Graphics 630 Graphics RAM: 1GB Driver version: 26.20.100.7262 Graphics Card: NVIDIA Quadro RTX 3000 Graphics RAM: 3.9990234375GB Driver version: 25.21.14.2545 _______________________________________________________ Screen Resolution: 1920 x1080 x32bit @ 60 Hz DPI Scaling: 100%
AMD 3950x Benchmark 16c/32t, stock w/3600mhz RAM.
This was not a Revit build but figured I would throw it on and bench it while it was on the test bench. Keep in mind, the 3950x beats out intel's 18 core CPU in a lot of multi-threaded benchmarks now. I suspect the 3900x would probably be in the same ballpark if not a pinch slower in the RFO bench.
STANDARD:
SIMPLIFIED:Code:RVT 2020 - Full_Standard set - 2020.02.10 @ 00.14.39 on DESKTOP-D5VG1CT.txt RFO Benchmark v3.2 (build 19.08.2019) RevitForum.org All times are in seconds, lower is better. Run on Revit 2020 FCS _________________________________________________________________ Update 10.29 update previous version file _________________________________________________________________ Model creation benchmark 4.13 opening and loading the custom template 11.19 creating the floors levels and grids 17.08 creating a group of walls and doors 30.03 modifying the group by adding a curtain wall 10.56 creating the exterior curtain wall 8.83 creating the sections 3.53 changing the curtain wall panel type 12.90 creating area plans 1.77 creating and applying view template 100.02 TOTAL _________________________________________________________________ Export benchmark 58.03 export all views as PNGs at 300 dpi 52.52 export all views as DWFs 84.50 export all views as DWGs 60.48 print all views as vector * 91.62 print all views as raster * Notes: * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed. _________________________________________________________________ Render benchmark 29.13 render _________________________________________________________________ Graphics - Standard View 4.69 activate View Styles view 0.41 change view to Wireframe 0.60 change view to Hidden 0.82 change view to Shaded 0.82 change view to Consistent Colors 1.41 change view to Realistic 0.67 refresh Wireframe Line view x10 2.95 refresh Hidden Line view x10 3.12 refresh Shaded view x10 2.98 refresh Consistent Colors view x10 3.28 refresh Realistic view x10 0.40 activate View Cube view 2.36 rotate view x1 24.51 TOTAL Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. TEST CONDITIONS: _______________________________________________________ Mfr: System manufacturer Model: System Product Name OS: Microsoft Windows 10 Pro64-bit _______________________________________________________ CPU: AMD Ryzen 9 3950X 16-Core Processor Max Clock Speed: 3.493Ghz Number of Processors: 16 Number of Logical Processors: 32 Total Physical Memory: 64GB @ 3600 3600 3600 3600Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 970 EVO Plus 2TB _______________________________________________________ Graphics Card: NVIDIA GeForce RTX 2080 Ti Graphics RAM: 3.9990234375GB Driver version: 26.21.14.4166 _______________________________________________________ Screen Resolution: 1920x1080x32bit @ 60Hz DPI Scaling: 100% RAW DATA: _________________________________________________________________ 11.090 9.878 9.889 update previous version file 4.210 4.086 4.107 opening and loading the custom template 11.900 10.858 10.812 creating the floors levels and grids 17.831 16.632 16.789 creating a group of walls and doors 32.034 28.897 29.171 modifying the group by adding a curtain wall 10.817 10.450 10.412 creating the exterior curtain wall 8.796 8.877 8.830 creating the sections 3.653 3.488 3.444 changing the curtain wall panel type 13.000 12.758 12.938 creating area plans 1.805 1.731 1.768 creating and applying view template 57.967 57.940 58.171 export all views as PNGs at 300 dpi 52.382 52.922 52.267 export all views as DWFs 84.447 84.198 84.841 export all views as DWGs 60.436 60.412 60.593 print all views as vector 91.426 91.478 91.959 print all views as raster 29.171 29.077 29.142 render 4.684 4.704 4.694 activate View Styles view 0.403 0.411 0.401 change view to Wireframe 0.596 0.600 0.603 change view to Hidden 0.812 0.826 0.820 change view to Shaded 0.814 0.824 0.820 change view to Consistent Colors 1.396 1.455 1.378 change view to Realistic 0.667 0.667 0.681 refresh Wireframe Line view x10 2.941 2.950 2.969 refresh Hidden Line view x10 3.105 3.122 3.137 refresh Shaded view x10 2.966 2.984 3.001 refresh Consistent Colors view x10 3.252 3.295 3.297 refresh Realistic view x10 0.399 0.397 0.398 activate View Cube view 2.377 2.375 2.328 rotate view x1
Code:RVT 2020 - Full_Simplified set - 2020.02.10 @ 00.58.12 on DESKTOP-D5VG1CT.txt RFO Benchmark v3.2 (build 19.08.2019) RevitForum.org All times are in seconds, lower is better. Run on Revit 2020 FCS _________________________________________________________________ Model creation benchmark 5.34 opening and loading the custom template 11.94 creating the floors levels and grids 17.84 creating a group of walls and doors 31.69 modifying the group by adding a curtain wall 10.80 creating the exterior curtain wall 8.90 creating the sections 3.69 changing the curtain wall panel type 13.48 creating area plans 1.83 creating and applying view template 105.51 TOTAL _________________________________________________________________ Graphics 4.75 activate View Styles view 1.05 change view to Wireframe 0.08 change view to Hidden 0.34 change view to Shaded 0.35 change view to Consistent Colors 0.34 change view to Realistic 0.75 refresh Wireframe Line view x10 3.41 refresh Hidden Line view x10 3.56 refresh Shaded view x10 3.42 refresh Consistent Colors view x10 4.27 refresh Realistic view x10 0.40 activate View Cube view 2.38 rotate view x1 25.10 TOTAL Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. TEST CONDITIONS: _______________________________________________________ Mfr: System manufacturer Model: System Product Name OS: Microsoft Windows 10 Pro64-bit _______________________________________________________ CPU: AMD Ryzen 9 3950X 16-Core Processor Max Clock Speed: 3.493Ghz Number of Processors: 16 Number of Logical Processors: 32 Total Physical Memory: 64GB @ 3600 3600 3600 3600Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 970 EVO Plus 2TB _______________________________________________________ Graphics Card: NVIDIA GeForce RTX 2080 Ti Graphics RAM: 3.9990234375GB Driver version: 26.21.14.4166 _______________________________________________________ Screen Resolution: 1920x1080x32bit @ 60Hz DPI Scaling: 100%
Hello guys,
AMD 3970x 32core/64thread RFO run. Another non-revit build but ran it on the system. Impressive, this thing is a beast at parallel workloads but for the core count, single core is impressive!
Code:RVT 2020 - Full_Standard set - 2020.02.12 @ 14.30.26 on DESKTOP-P1PLLG4.txt RFO Benchmark v3.2 (build 19.08.2019) RevitForum.org All times are in seconds, lower is better. Run on Revit 2020 FCS _________________________________________________________________ Update 10.41 update previous version file _________________________________________________________________ Model creation benchmark 4.19 opening and loading the custom template 11.34 creating the floors levels and grids 17.27 creating a group of walls and doors 29.60 modifying the group by adding a curtain wall 10.83 creating the exterior curtain wall 9.03 creating the sections 3.65 changing the curtain wall panel type 13.17 creating area plans 1.82 creating and applying view template 100.90 TOTAL _________________________________________________________________ Export benchmark 59.23 export all views as PNGs at 300 dpi 52.94 export all views as DWFs 87.07 export all views as DWGs 61.66 print all views as vector * 93.65 print all views as raster * Notes: * Print Views tests require the 'Microsoft XPS Document Writer' printer be installed. _________________________________________________________________ Render benchmark 20.90 render _________________________________________________________________ Graphics - Standard View 4.88 activate View Styles view 0.43 change view to Wireframe 0.63 change view to Hidden 0.87 change view to Shaded 0.86 change view to Consistent Colors 1.52 change view to Realistic 0.68 refresh Wireframe Line view x10 3.00 refresh Hidden Line view x10 3.19 refresh Shaded view x10 3.06 refresh Consistent Colors view x10 3.35 refresh Realistic view x10 0.41 activate View Cube view 2.45 rotate view x1 25.33 TOTAL Notes: Graphics benchmark measures the entire graphics stack, which includes CPU and memory. To meaningfully compare graphics cards, test all cards in the same machine and use the 'Graphics - expanded' benchmark. TEST CONDITIONS: _______________________________________________________ Mfr: System manufacturer Model: System Product Name OS: Microsoft Windows 10 Pro64-bit _______________________________________________________ CPU: AMD Ryzen Threadripper 3970X 32-Core Processor Max Clock Speed: 3.693Ghz Number of Processors: 32 Number of Logical Processors: 64 Total Physical Memory: 64GB @ 3600 3600 3600 3600Mhz _______________________________________________________ Drive Type: local Disk (NTFS) Drive Model: Samsung SSD 970 EVO Plus 2TB _______________________________________________________ Graphics Card: NVIDIA GeForce RTX 2080 Ti Graphics RAM: 3.9990234375GB Driver version: 26.21.14.4219 Graphics Card: NVIDIA GeForce RTX 2080 Ti Graphics RAM: 3.9990234375GB Driver version: 26.21.14.4219 _______________________________________________________ Screen Resolution: 1920 x1080 x32bit @ 60 Hz DPI Scaling: 100% RAW DATA: _________________________________________________________________ 11.012 9.992 10.227 update previous version file 4.238 4.160 4.172 opening and loading the custom template 11.891 11.035 11.098 creating the floors levels and grids 17.644 17.020 17.152 creating a group of walls and doors 29.734 29.394 29.676 modifying the group by adding a curtain wall 10.988 10.809 10.699 creating the exterior curtain wall 8.996 9.023 9.059 creating the sections 3.742 3.606 3.613 changing the curtain wall panel type 13.500 13.016 12.988 creating area plans 1.856 1.801 1.793 creating and applying view template 59.383 59.043 59.250 export all views as PNGs at 300 dpi 53.301 52.695 52.812 export all views as DWFs 86.902 87.375 86.938 export all views as DWGs 61.617 61.691 61.680 print all views as vector 94.023 93.367 93.566 print all views as raster 20.930 20.848 20.938 render 4.891 4.836 4.926 activate View Styles view 0.441 0.410 0.426 change view to Wireframe 0.633 0.621 0.637 change view to Hidden 0.875 0.856 0.879 change view to Shaded 0.867 0.856 0.871 change view to Consistent Colors 1.566 1.473 1.527 change view to Realistic 0.680 0.684 0.680 refresh Wireframe Line view x10 3.016 2.996 3.000 refresh Hidden Line view x10 3.195 3.195 3.191 refresh Shaded view x10 3.059 3.055 3.055 refresh Consistent Colors view x10 3.356 3.352 3.352 refresh Realistic view x10 0.406 0.402 0.410 activate View Cube view 2.449 2.422 2.477 rotate view x1
Nice to see the threadripper bench!
Looks like the top intel is somewhat 15% faster at singlecore.
Maybe Revit needs an optimization for the zen2 architecture, or is that not possible?
When looking at the difference of the render times between the 16/32thr and 32/64thr you would expect 100% faster but its actually 50% faster
Yeah, could be a Revit thing, the scaling is not 100% in other benchmarks but it is a lot more efficient than Revit rendering.
The 3970x and 3950x were both on 360mm AIO liquid coolers. The 3970x had the tr4 specific enermax since the client declined a custom EK loop.
Last edited by remiscs; February 16th, 2020 at 02:05 AM. Reason: cooling solution update
OH watch out, you might be insulting Anthony right now, with the pre build question
He is a custom computer builder (https://www.remiscs.com/) so no pre build stuff for him.
Oooow crap. My apologies. Im just a long time lurker, first time poster. I was just going through his results and could not see the motherboard manufacturer so I thought it might be a pre-build (please don't kill me).
On the other hand, I do custom builds and mods on systems that I own as a hobby. Did a couple for the office too.
