Page 11 of 11 FirstFirst ... 7891011
Results 101 to 106 of 106
Thread: RFO Benchmark v3.# 2020 results
  1.    #101
    March 19, 2014
    55
    02:54 AM
    When panning a sheet in revit its really slowing my system (i7-4790K). I did not find a portion of RFO which benchmarks this part of revit.
    Is revit really slow with panning or are more modern cpu's a lot faster at panning in revit?
    (picture below shows proc 4 at almost 50%).
  2.    #102
    March 23, 2018
    07:54 PM
    Fresh HP Z2 Workstation
    This is a brand new HP Z2 workstation.
    It was ran through a windows remote desktop connection. Will that slow the score down?
    Code:
    RVT 2020 - Full_Standard set - 2020.09.14 @ 16.28.32 on BAI-BUILD33.txt
        RFO Benchmark v3.3 (build 30.07.2020)
        RevitForum.org
    All times are in seconds, lower is better.
    Run on Revit 2020 FCS
    _________________________________________________________________
    Update
        9.39   update previous version file
    Model creation benchmark
        4.39   opening and loading the custom template
       10.98   creating the floors levels and grids
       16.19   creating a group of walls and doors
       28.52   modifying the group by adding a curtain wall
        9.66   creating the exterior curtain wall
        7.75   creating the sections
        3.33   changing the curtain wall panel type
       11.23   creating area plans
        1.59   creating and applying view template
       93.64   TOTAL
    Export benchmark
       57.73   export all views as PNGs at 300 dpi
       49.57   export all views as DWFs
       75.77   export all views as DWGs
       49.92   print all views as vector *
       79.55   print all views as raster *
    Notes:
     *  Print Views tests require the 'Microsoft XPS Document Writer' printer be installed.
    Render benchmark
       64.32   render
    Graphics - Standard View
        4.90   activate View Styles view
        0.40   change view to Wireframe
        0.61   change view to Hidden
        0.82   change view to Shaded
        0.81   change view to Consistent Colors
        1.40   change view to Realistic
        0.68   refresh Wireframe Line view x10
        2.67   refresh Hidden Line view x10
        2.88   refresh Shaded view x10
        2.69   refresh Consistent Colors view x10
        3.01   refresh Realistic view x10
        0.36   activate View Cube view
        2.21   rotate view x1
       23.44   TOTAL
    Notes:
        Graphics benchmark measures the entire graphics stack, which includes CPU and memory.
        To meaningfully compare graphics cards, test all cards in the same machine
        and use the 'Graphics - expanded' benchmark.
    TEST CONDITIONS:
    Mfr:   HP
    Model: HP Z2 Tower G4 Workstation
    OS:    Microsoft Windows 10 Pro 64-bit (build 2004)
    CPU0: Intel(R) Core(TM) i7-9700K CPU @ 3.60GHz
    Max Clock Speed: 3.6Ghz
    Physical Processors: 8
    Logical Processors: 8
    Total Physical Memory: 32GB
    ChannelB: 16GB @ 2667Mhz
    ChannelA: 16GB @ 2667Mhz
    Graphics Card: Radeon Pro WX 7100
    Graphics RAM: 3.9990234375GB
    Driver version: 27.20.1010.1
    Screen Resolution: 1920 x 1080 x bit @ 60Hz (max 75Hz)
    Graphics Card: Microsoft Remote Display Adapter
    Graphics RAM: 0GB
    Driver version: 10.0.19041.423
    Screen Resolution: 1600 x 900 x bit @ 32Hz (max 32Hz)
    DPI Scaling: 100%
    Drive Type: Local Disk (NTFS)
    Drive Model: SAMSUNG MZ7LN512HAJQ-000H1
    RAW DATA:
        9.445    9.394    9.320   update previous version file
        4.473    4.301    4.394   opening and loading the custom template
       11.211   10.738   10.988   creating the floors levels and grids
       15.980   16.246   16.356   creating a group of walls and doors
       28.336   28.543   28.676   modifying the group by adding a curtain wall
        9.707    9.598    9.684   creating the exterior curtain wall
        7.699    7.832    7.711   creating the sections
        3.383    3.348    3.250   changing the curtain wall panel type
       11.207   11.316   11.176   creating area plans
        1.644    1.539    1.590   creating and applying view template
       57.461   58.012   57.703   export all views as PNGs at 300 dpi
       49.312   49.809   49.602   export all views as DWFs
       76.777   74.902   75.617   export all views as DWGs
       49.758   49.996   50.012   print all views as vector
       79.680   79.418   79.543   print all views as raster
       62.102   69.578   61.293   render
        4.867    4.906    4.918   activate View Styles view
        0.398    0.391    0.402   change view to Wireframe
        0.617    0.609    0.602   change view to Hidden
        0.805    0.832    0.809   change view to Shaded
        0.801    0.816    0.805   change view to Consistent Colors
        1.434    1.383    1.394   change view to Realistic
        0.668    0.688    0.691   refresh Wireframe Line view x10
        2.633    2.691    2.691   refresh Hidden Line view x10
        2.856    2.891    2.902   refresh Shaded view x10
        2.664    2.719    2.691   refresh Consistent Colors view x10
        2.980    3.031    3.016   refresh Realistic view x10
        0.352    0.363    0.367   activate View Cube view
        2.184    2.230    2.215   rotate view x1
  3.    #103
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    166
    02:54 AM
    Quote Originally Posted by BrentstickCarlson View Post
    No the remote destop does not slow the revit benchmark down. Only thing that the remote desktop application does is stream the video output of Z2 workstation to another computer. The benchmark runs on the Z2 itself and is not slowed down.
  4.    #104
    August 7, 2019
    07:54 PM
    Water cooled i9-9900K @ 4.9 GHz
    Code:
    RVT 2020 - Full_Standard set - 2020.09.16 @ 15.34.30 on SCIA-BIM-JOSHV.txt
        RevitForum.org
    Run on Revit 2020.2.3
    Update
        9.66   update previous version file
        4.79   opening and loading the custom template
       11.71   creating the floors levels and grids
       16.92   creating a group of walls and doors
       29.12   modifying the group by adding a curtain wall
       11.25   creating the exterior curtain wall
        9.33   creating the sections
        3.44   changing the curtain wall panel type
       13.95   creating area plans
        1.89   creating and applying view template
      102.40   TOTAL
    Export benchmark
       55.19   export all views as PNGs at 300 dpi
       48.41   export all views as DWFs
       82.19   export all views as DWGs
       56.04   print all views as vector *
       85.13   print all views as raster *
    Notes:
    Render benchmark
       44.75   render
        4.97   activate View Styles view
        0.39   change view to Wireframe
        0.58   change view to Hidden
        0.78   change view to Shaded
        0.78   change view to Consistent Colors
        1.34   change view to Realistic
        0.63   refresh Wireframe Line view x10
        2.69   refresh Hidden Line view x10
        2.85   refresh Shaded view x10
        2.70   refresh Consistent Colors view x10
        0.37   activate View Cube view
        2.22   rotate view x1
       23.31   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr:   To Be Filled By O.E.M.
    Model: To Be Filled By O.E.M.
    OS:    Microsoft Windows 10 Pro 64-bit (build 1903)
    CPU0: Intel(R) Core(TM) i9-9900K CPU @ 3.60GHz
    Max Clock Speed: 3.601Ghz
    Logical Processors: 16
    Total Physical Memory: 64GB
    BANK 0: 16GB @ 2133Mhz
    BANK 1: 16GB @ 2133Mhz
    BANK 2: 16GB @ 2133Mhz
    BANK 3: 16GB @ 2133Mhz
    Graphics Card: NVIDIA GeForce RTX 2080
    Driver version: 27.21.14.5206
    Screen Resolution: 1920x 1080 x bit @ 59Hz (max 75Hz)
    DPI Scaling: 100%
    Drive Model: Samsung SSD 970 PRO 1TB
    RAW DATA:
        9.648    9.609    9.715   update previous version file
        4.883    4.766    4.711   opening and loading the custom template
       11.562   11.816   11.750   creating the floors levels and grids
       17.133   16.809   16.805   creating a group of walls and doors
       28.867   29.461   29.047   modifying the group by adding a curtain wall
       11.410   11.219   11.109   creating the exterior curtain wall
        9.379    9.461    9.148   creating the sections
        3.438    3.363    3.512   changing the curtain wall panel type
       13.949   14.035   13.852   creating area plans
        1.832    1.887    1.957   creating and applying view template
       55.109   55.266   55.207   export all views as PNGs at 300 dpi
       48.426   48.258   48.535   export all views as DWFs
       81.770   81.516   83.277   export all views as DWGs
       56.148   55.879   56.090   print all views as vector
       85.008   84.918   85.465   print all views as raster
       44.856   44.469   44.934   render
        4.914    5.055    4.941   activate View Styles view
        0.391    0.394    0.379   change view to Wireframe
        0.582    0.586    0.574   change view to Hidden
        0.785    0.785    0.777   change view to Shaded
        0.773    0.793    0.777   change view to Consistent Colors
        1.363    1.344    1.324   change view to Realistic
        0.637    0.641    0.621   refresh Wireframe Line view x10
        2.703    2.707    2.660   refresh Hidden Line view x10
        2.832    2.891    2.824   refresh Shaded view x10
        2.715    2.734    2.660   refresh Consistent Colors view x10
        3.000    3.066    2.973   refresh Realistic view x10
        0.363    0.375    0.363   activate View Cube view
        2.207    2.270    2.191   rotate view x1
  5.    #105
    January 15, 2020
    The Netherlands
    166
    02:54 AM
    Quote Originally Posted by jrv4life View Post
    Code:
        RevitForum.org
    Update
      102.40   TOTAL
    Export benchmark
    Notes:
    Render benchmark
       44.75   render
        2.22   rotate view x1
       23.31   TOTAL
    Notes:
    TEST CONDITIONS:
    DPI Scaling: 100%
    RAW DATA:
    Hmm that result seems on the low side. The benchmark reports your ram is running at 2133mhz, not sure if thats actually true, but if it is try to enable the XMP profile from the bios and try the benchmark again.
    Also if your i9 9900k has a good water cooler you could easely lock it to 5GHz all core
  6.    #106
    December 6, 2017
    10:54 AM
    I have been searching for a pioneer who has a result with Ryzen 3300X but there is none. So I spent $A467 for the CPU + new B550M motherboard + new case. Worth it for Revit Structure that I am using. I hope my result would encourage others out there to go with AMD. There is no need to over stretch your budget for similar work with Revit Structure/CAD. I don't do rendering but I guess there may be disadvantage here with the CPU.
    This budget CPU beats i7 7700k in gaming and now RFO. Results are from my new AMD workstation at home and my 3yo i7 7700k workstation at work.
    Ryzen 3300X. All default setting. No OC.
    Code:
    RVT 2020 - Full_Simplified set - 2020.09.20 @ 15.17.21 on DESKTOP-9LQEIDB.txt    RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
        5.03   opening and loading the custom template
       11.36   creating the floors levels and grids
       17.01   creating a group of walls and doors
       29.86   modifying the group by adding a curtain wall
       11.16   creating the exterior curtain wall
        9.64   creating the sections
        3.71   changing the curtain wall panel type
       12.63   creating area plans
        1.80   creating and applying view template
      102.20   TOTAL
    Graphics
        5.01   activate View Styles view
        1.28   change view to Wireframe
        0.09   change view to Hidden
        0.36   change view to Shaded
        0.39   change view to Consistent Colors
        0.38   change view to Realistic
        0.98   refresh Wireframe Line view x10
        3.93   refresh Hidden Line view x10
        4.10   refresh Shaded view x10
        3.92   refresh Consistent Colors view x10
        4.83   refresh Realistic view x10
        0.44   activate View Cube view
        2.77   rotate view x1
       28.48   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: Gigabyte Technology Co., Ltd.
    Model: B550M DS3H
    OS: Microsoft Windows 10 Pro64-bit
    CPU: AMD Ryzen 3 3300X 4-Core Processor
    Max Clock Speed: 3.793Ghz
    Number of Processors: 4
    Number of Logical Processors: 8
    Total Physical Memory: 16GB @ 2400 2400Mhz
    Drive Type: local Disk (NTFS)
    Drive Model: ST4000DM004-2CV104
    Graphics Card: AMD Radeon (TM) R9 200 Series
    Graphics RAM: 2GB
    Driver version: 26.20.15029.27017
    Screen Resolution: 1920x1200x32bit @ 60Hz
    DPI Scaling: 100%
    Core i7 7700K:
    Code:
    RVT 2020 - Full_Simplified set - 2020.06.04 @ 16.45.27 on REVIT-PC03.txt    RFO Benchmark v3.2 (build 19.08.2019)
        RevitForum.org
        5.73   opening and loading the custom template
       13.67   creating the floors levels and grids
       19.34   creating a group of walls and doors
       34.27   modifying the group by adding a curtain wall
       13.23   creating the exterior curtain wall
        9.98   creating the sections
        4.15   changing the curtain wall panel type
       15.77   creating area plans
        2.21   creating and applying view template
      118.35   TOTAL
    Graphics
        5.52   activate View Styles view
        1.33   change view to Wireframe
        0.38   change view to Shaded
        0.40   change view to Consistent Colors
        1.03   refresh Wireframe Line view x10
        4.04   refresh Hidden Line view x10
        4.12   refresh Shaded view x10
        4.12   refresh Consistent Colors view x10
        5.03   refresh Realistic view x10
        0.45   activate View Cube view
        3.04   rotate view x1
       29.93   TOTAL
    Notes:
    TEST CONDITIONS:
    Mfr: MSI
    Model: MS-7998
    CPU: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
    Max Clock Speed: 4.2Ghz
    Total Physical Memory: 16GB @ 2133 2133Mhz
    Drive Model: WDC WD1003FZEX-00MK2A0
    Graphics RAM: 2GB
    Driver version: 26.20.15019.15019
    DPI Scaling: 100%
  1. RFO Benchmark v3.# 2019 results
    By Gordon Price in forum Hardware and Infrastructure
    Last Post: September 3rd, 2020, 08:54 PM
  2. RFO Benchmark v3 2017 results
    Last Post: May 9th, 2018, 08:20 AM
  3. RFO Benchmark v3 2015 results
    Last Post: June 22nd, 2017, 11:39 AM
  4. RFO Benchmark v3 2016 results
    Last Post: May 9th, 2017, 12:00 AM
