Thread: Walls not wrapping
    February 7, 2017
    10
    07:30 PM
    Walls not wrapping
    I have noticed that in my first small Revit project that some exterior & interior walls are not wrapping.
    EG; refer 3 red circles.
    I have used the trim tool to the walls but get same results
    Both wall types have wrapping ticked under Strucutre & I have included a dbx of the interior wall 'Type Properties'.
    I have looked at legacy plans & they only go back a couple of days....same issues.
    Any thoughts of what I have done wrong & what is the fix?
    Cheers, Steve
    6,309
    04:30 AM
    I would start by pulling the walls back from the corner and then re-trimming them together. The wall join tool may help, but it can be fickle at times - especially if there are a bunch of walls coming together.
    February 7, 2017
    10
    07:30 PM
    Thanx....the wall trim did work with miter....was set to butt......Steve
    3,159
    03:30 AM
    TBH, I've never understood why miter isn't the default.
    Seems like it would fix the issue s with materials on the ends of walls, too
  1. Annoyances No. 41 - walls of different thicknesses meeting and finish not wrapping
    Last Post: April 11th, 2016, 08:51 AM
  2. Brick walls + wrapping plaster, THEN partition walls (gypsum boards with metal const)
    By turuly in forum Architecture and General Revit Questions
    Last Post: July 21st, 2014, 07:44 PM
  3. The finishes of two walls are intersecting instead of wrapping in the corner
    By constrainmenot in forum Architecture and General Revit Questions
    Last Post: June 21st, 2014, 08:54 AM
  4. Wall finish wrapping at two different walls that intersect
    By msilanit in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 03:51 PM
  5. Wrapping Roofs
    Last Post: November 18th, 2011, 08:49 PM
