Results 1 to 10 of 11
Thread: Architects Drawing Furniture/Curtains/Screens with Model Lines on the Floor
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    309
    03:46 AM
    How does everyone deal with architects using model lines for things that should be elements? We have several architects that will draw curtains for patient areas or screens on the floor with model lines. This stops us from being able to see them in our reflected ceiling views.
    I've asked the architect if they could possible place these lines on a reference plane lifted off the floor so we could adjust our cut and see them. They said sure they'd do that no problem.
    They haven't.
    For now we've sided on having our cut plane go through or spaces for tagging rather than at the floor for the architects lines. If the architect doesn't want to change how they show these than I don't think there if much I can do about it.
    Also, I wish you could set a view range in here with out using linked view.
    Kingdom of Denmark
    4,262
    09:46 AM
    3 Not allowed! Not allowed!
    Personally Id just go and punch the architect in the nose, and tell him/her to model it right.
    July 26, 2019
    DFW, Texas
    52
    02:46 AM
    You will find them over at the Civil Engineer's office hitting with a stick everyone who created a circular xref siteplan file in only 2/3 Civil 3D in "emulate acad" format. And not being able to find the clearly-labeled "export as AutoCAD" button. So that, along with the circular references, the 40-50,000 unshared custom linetypes with unshared shx files, the excrement files have around 3.2 million proxy objects in them as well, with embedded layer names (do we really need to share $0$sbind$0$bndry_surv0934t5834$0$no_print$0$S_ex_F ence_Mickey_Mouse-plot-only ?)
    July 10, 2015
    Boise, Idaho
    766
    01:46 AM
    2 Not allowed! Not allowed!
    Quote Originally Posted by CapnMac View Post
    Yes but only if the line is 3" long horizontally and 17 miles vertically
    Member FBlome's Avatar
    Menlo Park, California
    97
    12:46 AM
    You will find them over at the Civil Engineer's office hitting with a stick everyone who created ...clip....
    Cool, so my Civil is not the only one. Latest issue was a simple residential addition for which they did a storm water management plan, on top of one or two previous phases they had completed for the site. And included every single layer and proxy and whatever else in the resulting pdf. It barely scrolled in Reader, my repro house gave up trying to print their sheets, and when I asked for a clean pdf, Civil themselves ended up printing 1/2 size sheets and scanned them. This Civil is one of the main big firms in our area.....
    April 30, 2015
    Michigan
    309
    03:46 AM
    Civil and food service are going to continue to be issues at our firm. I'm working on converting everything we're doing in-house to Revit and stop linking cad. Some will remain drafting views while other will eventually because schedules. I have never heard of civil working in Revit and have only heard one story of a FSE working in Revit. I've thought about doing a pick line with dynamo of both but I'm worried trying to get it to work with multiple civil or FSE firm would be a nightmare. Also civil tends to put letters in their lines and I'm not sure how I could automate adding those to the conversion. On top of that I don't know if having that many lines in revit would cause any performance issues.
    10,716
    02:46 AM
    Save yourself the aggravation: if you use pick lines, you are just trading one set of problems for another. Might as well keep the CAD at that point.
    April 30, 2015
    Michigan
    309
    03:46 AM
    Just discovered that the same architect modeled a louver with glazing and mullions. How the hell am I supposed to filter that out? Same families and types as used elsewhere. GREAT.
    10,716
    02:46 AM
    I hate to say this, but thats super common. All of my clients have families for them, but a lot of folks dont know how to build them.
    Forum Addict Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    1,015
    11:46 PM
    Quote Originally Posted by CRapai View Post
    The best way to handle this a phone call that explains your dilemma, and request a solution from the architect. Always works for me.
  1. Model not aligned with Architects. Can I just move it?
    By DCLowery in forum Structure - General Questions
    Last Post: June 10th, 2016, 06:16 PM
  2. can not show furniture on floor plan !!!!
    Last Post: January 21st, 2015, 10:19 PM
  3. Working in Architects model
    By JamesLawrence in forum MEP - General
    Last Post: January 20th, 2015, 04:26 PM
  4. Revit OpEd: Stage Curtains
    Last Post: October 16th, 2014, 04:45 AM
  5. Floor tiles over furniture
    By Helena Fields in forum Architecture and General Revit Questions
    Last Post: May 22nd, 2012, 03:34 PM
