Thread: Roof help
    March 21, 2018
    7
    08:54 AM
    Roof help
    Hi
    I am trying to draw a roof to a single storey house with porch. My porch roof needs to be 300mm above the main roof. I am not getting it right and do not understand what I am doing wrong. Can anyone help me please? I am attaching a revit file and a picture.
    Regards
    parm
    July 26, 2019
    DFW, Texas
    52
    02:54 AM
    Well, that's a newer version than mine--what, exactly is the problem?
    Have you tried Join Roof?
    March 21, 2018
    7
    08:54 AM
    Hi CapnMac
    Thank you for your reply. Yes I tried joining roof but my roof line was leaving an undesired valley between the porch and main roof. This valley is not practically workable.
    Regards
    Parm
    December 20, 2010
    1,102
    03:54 AM
    you have to make the lower roof wider (grow to the right) to raise the ridge to eliminate the valley, or you need to modify your porch roof moving it left to ellimnate the unwanted valley. This is not a revit problem but a roof design issue.
    January 12, 2011
    London, UK
    572
    08:54 AM
    Quote Originally Posted by CapnMac View Post
    That roof file was in v.2016 - which version are you working in ?!?
    January 12, 2011
    London, UK
    572
    08:54 AM
    Quote Originally Posted by enaries View Post
    Unlike floors, roofs sit on the Revit Level at their BASE.
    And the extra height you are getting is from the difference in the thicknesses of the two roofs in an inclined (plumbcut) thickness, NOT as a difference of 300-150mm.
    Plus the roof sits on Revit level on the INSIDE of the overhang. See image below. Hope this helps.
ID:	37472 Click image for larger version.
    July 26, 2019
    DFW, Texas
    52
    02:54 AM
    Quote Originally Posted by kamranmirza View Post
    2015 (employer is stingy)
  1. Roof with one plane on a different plate height **complex roof system**
    By lparnell583 in forum Architecture and General Revit Questions
    Last Post: December 7th, 2016, 10:42 PM
  2. Roof framing plan - roof visibility issue
    By sknsnw9 in forum Architecture and General Revit Questions
    Last Post: September 16th, 2015, 04:15 PM
  3. How to use downloaded roof panels family and input them on roof surface
    By kjubas in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2014, 12:31 AM
    Last Post: May 5th, 2014, 09:45 PM
