Thread: Issues with reference view
    September 12, 2019
    08:38 PM
    Hello!
    I am new in this forum and in the Revit software. I have looked everywhere and cant find the answer to this. I wonder if there is a regen comand in revit, because my reference that I imported in DWG from autocad is looking messy like the picture below. I tried copying and pasting again and nothing seems to work.
    Thank you in advance!
    3,117
    02:38 PM
    That typically happens when your DWG is far away from the Origin
    Like miles, or dozens of miles away.
    The best way to fix it is to open the DWG and moves everything close to 0,0,0
    July 10, 2015
    Boise, Idaho
    749
    01:38 PM
    Nothing like regen exists
    New Member dcnilsson's Avatar
    November 16, 2015
    Atlanta, GA
    03:38 PM
    I suspect the origin (0,0,0) of the imported CAD file is very distant from the linework. Miles away kinda distant. Revit doesn't like that. Try opening the CAD file, moving the line work to 0,0 and reimport it, it should read correctly. As an aside, you probably want to look into linking your reference file instead of importing. A search on here will yield ample discussion on why this is a good idea.
  1. plan view/view range issues RCP
    By maddyjdelaney in forum Architecture and General Revit Questions
    Last Post: September 13th, 2019, 02:24 PM
  2. View Reference tag that can display a view's name too not just sheet and number data?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: March 16th, 2017, 10:45 PM
  3. Reference other view: <New Drafting View>
    By amarkrish108 in forum Architecture and General Revit Questions
    Last Post: March 18th, 2014, 10:14 AM
  4. View Reference Tag
    Last Post: August 14th, 2013, 08:31 PM
  5. View Reference for Reference Callouts
    By GMcDowellJr in forum Architecture - Family Creation
    Last Post: November 30th, 2012, 04:00 PM
