Thread: New Revit Machine
    November 27, 2012
    631
    08:15 AM
    New Revit Machine
    looking at building a new revit machine, just got a new project and the model is 500mb before we have even started working on it.
    what kind of proccessor and graphics card would you recommend, im reading conflicting things, not sure if to go for an I7 or an I9
    Cheers
    1,482
    09:15 AM
    So many threads about this already.
    For just Revit:
    Basically more clockspeed is better.
    No need for an expansive Quadro graphics card and good GeForce is more then enough 2070 for example
    The most RAM you can afford, but that depends a bit on your projects, but with 500mb already 32 would be where I would start for sure.
    November 27, 2012
    631
    08:15 AM
    put together this, what you think? good or bad or could be better?
    1,482
    09:15 AM
    That would be pretty nice to work on for sure.
    I think those 9900K's can be overclocked pretty well too (why it is in the overclock bundle I guess) so you can have the 5Ghz all the time.
    I would make sure though that the extra 16Gb that you buy is the same as the 16Gb that comes in the bundle.
    Other then that, this is pretty similar too what I would probably buy right now if I needed a new workstation
    July 10, 2015
    Boise, Idaho
    766
    01:15 AM
    Only thing I'd be concerned with is if 850W for the PSU will be enough. A bit of double checking to make sure can't hurt
    1,482
    09:15 AM
    I have a 850W myself with a 8086k and 1070ti, no problem at all.
    I do not expect any issues with those specs either.
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    309
    03:15 AM
    850 is pretty big.
  1. Revit to CNC Machine
    By TashaBamhare in forum Architecture and General Revit Questions
    Last Post: December 17th, 2015, 03:32 PM
  2. Low budget Revit machine
    By SidCounter in forum Hardware and Infrastructure
    Last Post: May 18th, 2015, 02:15 PM
  3. How to spec a machine for revit use?
    By nick_h in forum Hardware and Infrastructure
    Last Post: September 10th, 2013, 03:22 PM
  4. New Revit Machine
    By cadman56 in forum Hardware and Infrastructure
    Last Post: September 14th, 2011, 08:52 PM
  5. Best Revit Machine
    By dzatto in forum Hardware and Infrastructure
    Last Post: September 13th, 2011, 09:27 PM
