Thread: Tags and phasing
    January 11, 2017
    11:43 AM
    Tags and phasing
    My company's starting to work on more projects with multiple phases and I'm wondering if there's a way to make pipe/duct/equipment tags automatically adjust based on the view phase and the phase the element was created. We already have the typical filters and overrides for the elements to show up in the correct way.
    For instance:
    1. Existing pipe, prefix "ETR" shows up on phase 1 demo and new plan
    2. Demolished in phase 2, prefix "REX" shows up in phase 2 demo.
    3. View filter hides pipe in phase 2 new and subsequent phases.
    And:
    1. Pipe created in phase 1, no prefix.
    2. The pipe shows up with prefix "ETR" in phase 2.
    I'm hoping I can create some sort of shared parameter like "if(demo phase property = active view phase, "REX", if(pipe phase created<= active view phase, "ETR"))"
    I'm guessing there's no way, but thought I'd ask.
    2,780
    01:43 AM
    Quote Originally Posted by TAllen View Post
    Not sure you can get a tag to read view phase and element phase. I'd probably just get Dynamo to write the complete text value including prefix, based on filtered selections and get the tag to display that.
    The attached is just combining View Phase, Element ID & Element Phase Created to write to the Comments parameter, which is read by a simple text tag. Is Revit 2018 & Dynamo 2.0.2
  1. Phasing (Again)
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: July 20th, 2016, 02:22 AM
  2. Tags disappeared - tags size
    By filomenanigro in forum Architecture and General Revit Questions
    Last Post: September 27th, 2015, 01:59 PM
  3. Phasing and Phasing Filters
    By jess_labbe in forum Structure - General Questions
    Last Post: April 7th, 2015, 04:18 PM
  4. Phasing and Refurbishment
    By ReViZz in forum Architecture and General Revit Questions
    Last Post: November 14th, 2013, 10:57 AM
  5. Default Position of Door Tags (or any tags for that matter):
    Last Post: December 23rd, 2011, 08:45 PM
