Thread: PIPE : steel+plastic=isssue
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    236
    03:09 PM
    hi
    i'm working on projects w<here we use PVC and steel (stainless steel nowadays)
    some jonctions are made between theses two kind of pipes
    but the ND of theses pipes are not the same...
    for PVC people use to speak of outside diameter whereas i prefer the speak of ND knowing the thses two sizes are different...
    i had a template from rival company and i took its PVC families without looking at this point
    i have now an issue
    a have a flowmeter which is between a PVC and a stainless stell pipe.... flowmeter is ND100, no problem with stainless but with plastic, as, the ND doesn't exist i have a reducer after my flange (the flowmeter is flanged). in real life there won't have any reducer because the flange is good size (the PVC pipe will be dia110 = DN100)
    what shloud i have to do? change my segments and sizes setting (and all the libraries) ? theres a piece of work but could have the same problem for other material (iron cast, PEHD)
    thanks for your poit of view and have a nice week-end.
    Phil
    June 30, 2016
    Lyon - France
    236
    03:09 PM
  1. Steel Pipe Manufacturers
    By Jack1987 in forum MEP - General
    Last Post: January 9th, 2018, 09:23 AM
  2. Pipe-in-pipe, containment pipe, double-wall pipe ?
    By gerryblake in forum MEP - General
    Last Post: June 14th, 2017, 04:14 PM
  3. carbon steel Pipe Fitting Fmily
    By ali baba in forum Out There
    Last Post: March 8th, 2017, 01:47 PM
  4. Pipe Steel to Copper
    Last Post: June 29th, 2016, 03:20 PM
  5. Steel pipe and fittings
    By tzframpton in forum MEP - Family Creation
    Last Post: July 16th, 2014, 12:31 PM
