Thread: How to creating a Tension column in Revit
    July 30, 2014
    4
    02:10 PM
    How to create a Tension column in Revit?
    Newbie here and I'm getting my beak wet (or more likely bent) on modeling a steel structure.
    I'll like to know the best practice on creating a tension column, or a steel hanger as some may call, it in Revit.
    Basically I have a elevated steel beam and I'll like to attach a steel column to it's bottom flange. This column will hang down (maybe 2 or 3 feet) to provide support for another steel beam at a lower elevation. Attaching the column to the underside of the upper beam is not the issue since I can use the "Attach Top/Base" command, making the connection to the lower beam is my issue because I'll like the tension column to be be able to stay attached to lower beam if I decide to change it's elevation. Any thoughts?
    3,231
    02:10 PM
    Welcome to the forum.
    In the same way as you know how to attach the top of the column to the bottom of a beam above, you could attach the base of the column to another beam below. By default, the base of the column would go to the top of the beam below, but in the instance properties of the column there is a parameter to fix that. It is called "offset from attachment at base".
    July 30, 2014
    4
    02:10 PM
    As it stands now, the column base starts at the ground elevation and attaches to the underside of the upper beam. I was under the impression that I can select the column again, envoke the "Attach Top/Base" command again, and have the base of the column snap to the top of the lower beam ... that didn't work.
    So if I understand you correctly, I'm suppose to start my column at the top of the lower beam and then attach the top to the upper column from there? I was hoping I can somehow do it in reverse and attach the lower beam to the column .... I might be thinking too much of the construction sequence.
    The instance properties for the column has an "offset from attachment at Top" parameter which only affects the top of the column, I didn't see and instance for the base.
    3,231
    02:10 PM
    Quote Originally Posted by natedj View Post
    Columns can be attached in any direction. It does not have to be in a construction sequence.
    The parameters for "offset from attachment at... " (top or bottom) appear only after you select a column whose top or base has been already attached, not before.
  1. Creating Column Rebar schedule
    By smith125 in forum Structure - General Questions
    Last Post: July 16th, 2015, 06:47 PM
    Last Post: February 28th, 2013, 04:45 AM
  3. Post-tension in revit?
    By christian0102580 in forum Structure - General Questions
    Last Post: January 5th, 2012, 08:16 AM
  4. What is best tools for creating fence wall with column supporting them ?
    Last Post: October 2nd, 2011, 01:44 AM
