Thread: Single sloped (pitch) top chord joist and truss
    November 28, 2011
    Ontario, Canada
    154
    04:11 AM
    Hello All
    I am looking for some revit 2018 families for the following situation as I am working on a project that requires a Single sloped (pitch) top chord joist and truss, the bottom chord is flat as the project has a under slung crane hanging from the joists and truss. I am also looking for a family of a joist that has the middle of the top chord dropped. I have attached a jpeg with highlights of what i am looking for. I was able to make a truss from scratch but i was unable to get the array and the extrusion for the joist should to flex. your help is appreciated. I have contacted a few local joist suppliers but they do not have any revit families for any non standard joists and trusses yet.
    If someone would be willing to share their family or know where I can get one. it would be really be appreciated.
    Thanks in advance
    Regards
    Kevin
    3,215
    03:11 AM
    The existing truss families that come with Revit, for example, the Howe Flat Truss, can attach its top to a roof of structural floor, and their profile can be edited in elevation. Therefore, it is not necessary, in my opinion, to create families of trusses for these conditions.
    Member Darius's Avatar
    May 6, 2013
    494
    03:11 AM
    So i would disagree with Alfredo on this one when you have a butterfly roof u can not use a flat truss for that u need the one highlighted in yellow on the top right because that is the shape of the truss.
    However you will have to make those trusses (start from scratch do not try to modify existing truss families)
    truss families are not hard to make u can get the webing that you want
    here is a version of the truss on the top right make sure you use the structural trusses template ( this one gives the options to assign top and bottom chords and webbing) NOT the structural framing complex truss template
    3,215
    03:11 AM
    Quote Originally Posted by Darius View Post
    ...when you have a butterfly roof u can not use a flat truss for that u need the one highlighted in yellow on the top right because that is the shape of the truss....
    This one, you mean? It can be created starting from a flat truss, then editing its profile.
  1. Chord Length Constraints
    By JT44 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: December 1st, 2018, 08:46 PM
  2. Revit OpEd: Revit 2016 - Truss Chord Rotation
    By Revit OpEd in forum Blog Feeds
    Last Post: May 15th, 2015, 05:15 AM
  3. Sloped Bar Joist Seats
    By cellophane in forum Structure - General Questions
    Last Post: October 22nd, 2013, 08:06 PM
  4. Floor truss w/ top chord and bottom cord bearing
    By Jondoe941 in forum Structure - General Questions
    Last Post: April 19th, 2013, 05:23 PM
  5. DBL Pitched top chord joists
    By chaos2010 in forum Structure - General Questions
    Last Post: May 28th, 2011, 03:32 AM
