Results 1 to 10 of 10
Thread: Colored wall for Fire review ?
    September 23, 2015
    207
    03:58 PM
    Has anyone successfully implemented using view filters to color code walls in a LS plan ?
    I am wondering if this is a real solution that a local reviewer will entertain or if its just us being enthusiastic ?
    In the past I have drafted a line dash dot dot , etc on top of my rated walls and have used a special fire rating tag, but I am not a fan of the disconnect between the 2d line and the modeled elements. I don't like the hatch in coarse view, it is confusing to read - we have been told that.
    What are your thoughts.
    10,716
    02:58 PM
    Filters work and do colors just fine. Been covered in a number of threads here.
    September 23, 2015
    207
    03:58 PM
    yes I know it works, what I meant to ask if anyone has gotten any negative comments or rejections because of this from the fire reviewers.
    November 23, 2012
    97
    12:58 PM
    Quote Originally Posted by Profoxcg View Post
    I use color all the time in my documents, but color presents some real difficulties for reproduction. Many repro processes are still b/w/gray not color.
    My rule of thumb is that you can use color to increase legibility, but if it's in b/w it still has to read properly.
    Obviously this standard would not apply to schematic or descriptive drawings. But for the final / legal CD's I think it's prudent to not use color as a primary way of communicating information.
    -->Let's not get into how to deal with color blind people.
    June 14, 2011
    CT, USA
    608
    03:58 PM
    Check with the reviewers.
    Senior Member DavidLarson's Avatar
    July 10, 2015
    Boise, Idaho
    766
    01:58 PM
    I was a reprographics puke back in the late 90's. Way back in the days when ARC was still Ford Graphics It's not really that big of a deal to insert a color sheet into a set of drawings. Nothing has changed with the advances is repro tech. You still have to manually insert the sheet.
    The main concern I'd have is why is printing still a concern? Why aren't all jurisdictions accepting PDF submittals?
    September 23, 2015
    207
    03:58 PM
    I know, I have to schedule a meeting with the reviewers to get their feedback. Problem is, they will say yes, then we submit a set, and they reject it lol. Happens all the time.
    July 10, 2015
    Boise, Idaho
    766
    01:58 PM
    Get them to say yes in an e-mail. Then when they pull that you have proof that they're dishonest and/or corrupt
    6,309
    03:58 PM
    Quote Originally Posted by DavidLarson View Post
    I've run into several instances where one reviewer says Yes and is fine with something like that, and another reviewer is not ok with it and wants something else entirely... Some things do not have a departmental policy. And then there is AHCA...
    R.I.P. MPwuzhere's Avatar
    Las Vegas, NV
    4,864
    12:58 PM
    Send everything B&W to the reviewers and Color to the contractors/owners. Depends on the project though, sometimes color is very helpful sometimes it isn't. <shrug>
  1. fire rated wall hatch pattern dot or something defference from dashes
    By Hoangtin in forum Architecture and General Revit Questions
    Last Post: August 26th, 2018, 04:55 PM
  2. Automatically assigning a fire rating to a door when placed within fire rated wall
    By BEATl in forum Architecture and General Revit Questions
    Last Post: November 1st, 2016, 10:32 PM
  3. Model line on top of wall - fire rated assembly
    By theotheranony in forum Architecture and General Revit Questions
    Last Post: July 15th, 2014, 01:31 PM
  4. Gypsum Assoc. Fire Resistance Design Manual Wall Types
    By GenreNomad in forum Architecture and General Revit Questions
    Last Post: March 27th, 2013, 06:40 PM
  5. wall type with fill pattern and colored fill
    By Ken Marcus in forum Architecture and General Revit Questions
    Last Post: December 30th, 2011, 11:25 PM
