Results 1 to 10 of 15
Thread: Horizontal dimension with vertical text
    March 6, 2019
    64
    06:51 AM
    How do you make horizontal dimension with vertical text, and vertical dimension with horizontal text and text placed by second tick mark (arrow)?
    And more, how do you create a family similar to dimension style 'Baseline' in AutoCAD?
    Thank you!
    July 10, 2015
    Boise, Idaho
    782
    06:51 AM
    In the dimension Type Properties put the Read Convention to Up, then Left.
    March 6, 2019
    64
    06:51 AM
    That doesn't work.
    If this is not possible, I give 2 cents on Revit.
    May 14, 2012
    474
    06:51 AM
    Out of curiosity, why do you want to have text that is not aligned with the dimension line? Maybe an example would help us understand.
    As for having text placed by arrow, after you place the dimension (and cancel the dimension command), select the dimension element. Under the text you will see a little blue dot ... click and drag this blue dot to move the text somewhere else. With the dimension selected, look at the options bar and you will see a checkbox: "Leader" - if this is checked, it will add a line or arc from the text to the dimension line (it's on by default ... it has to be turned off manually). The arc vs line is set in the dimension type itself and you can even add a tick mark to the leader.
    July 10, 2015
    Boise, Idaho
    782
    06:51 AM
    I'm assuming you're looking for something that looks like this exampleClick image for larger version.
Name:	Dimension Example.png
    March 6, 2019
    64
    06:51 AM
    This what I am looking for. Horizontal dimension with vertical text.
    The vertical dimension with horizontal text is solved.
    March 6, 2019
    64
    06:51 AM
    I know that is possible to edit dimension using grips, but it's too much work. I need to be able to make a 'chain' of dimensions like DavidLarson shows.
    July 10, 2015
    Boise, Idaho
    782
    06:51 AM
Name:	Dimension Example2.png
    This gives both of what you're asking for
    March 6, 2019
    64
    06:51 AM
    For vertical text doesn't work.
    Why did you blackout Tick Mark?
    Thank you!
    July 10, 2015
    Boise, Idaho
    782
    06:51 AM
    That's the setup I'm using that gives me what you're asking for.
    I blacked it out because it has a name that can be identified. OPSEC never goes away
  1. Tag leaders not horizontal/vertical
    By Googleye in forum Architecture and General Revit Questions
    Last Post: April 5th, 2019, 07:31 AM
  2. Horizontal & Vertical Offsets
    By jackmitford in forum Architecture - Family Creation
    Last Post: July 5th, 2018, 01:16 PM
  3. scheduling curtainwall vertical and horizontal mullions
    By Anondrafter in forum Architecture and General Revit Questions
    Last Post: June 28th, 2017, 02:15 AM
  4. Mullions: Horizontal and vertical 45 join
    By kosmos3d in forum Architecture and General Revit Questions
    Last Post: February 3rd, 2016, 05:48 PM
