Results 1 to 10 of 18
Thread: Bulk Family Manager / parameter remove, rename..
    November 27, 2012
    633
    06:36 AM
    Is there a tool out there than can remove parameters from a load of families at once, or add paramters or change the text in a paramter in multiple families? I am sure I have had a tool in the past but cant for the life of me find it.
    cheers
    11,024
    12:36 AM
    CTC BIM Manager Suite's Family Processor.
    November 27, 2012
    633
    06:36 AM
    Is there not a cheeper one? Im sure I had one ages ago where you could open a loan of family parameters in excel and modify the text
    2,780
    03:36 PM
    Quote Originally Posted by nick_h View Post
    Dynamo
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    328
    01:36 AM
    I made a script that is designed to take manufacturer families and add our parameters so they work with our schedules. It also sets default values for things like marks, temps, and voltage, models, etc. It's not designed for multiple families at once but I'm betting there is a way. Although other than bulk upgrading families I haven't messed with multiple families in one script. I've heard its messy.
    November 27, 2012
    633
    06:36 AM
    I seen a tool called AGA smart browser pro that looks good but not sure on the price
    11,024
    12:36 AM
    Quote Originally Posted by CRapai View Post
    Its insanely messy. John built a way to do it, with Dynamo, but its wildly erratic. Dynamo really doesnt like being used for that.
    Member aperte's Avatar
    82
    10:36 PM
    Cody, do you use a 'template family' that your script accesses, and makes modifications to the manufacturer (or other source) family to match the 'template family'?
    Or does your script access a Shared Parameter file, and load in specified shared parameters (which would also need supplemental data, such as which categories it applies to, instance vs type, what section to sort under)? I'd be curious to see how your process is structured.
    April 30, 2015
    Michigan
    328
    01:36 AM
    3 Not allowed! Not allowed!
    Oh God, now I'm going to be embarrassed by my implementation. I'd would like criticism though as this is one of the first useful script I made. It cut down adding parameters for schedules for AHUs from 15-20 min to about 1min. Open family, run script, select type, maybe update some parameters, save, load into project.
    Keep in mind this isn't replacing manufacturers. I don't want to accidentally remove something in the family that is necessary for it to work.
    I'm actually using excel. When I started here I redid our SP from scratch and used Excel to organize everything. I also generate the parameters from it using using Dynamo.
    There is a second excel file that has a tab that contains the list of tabs and a tab for each type of equipment that the script can be ran on. Each tab it set up with a version of the schedule we use plus other parameter that we use for visibility/coordination. This is what one looks like. Sort under is handled by the shared parameter excel file.
Name:	family parameters 01.PNG
    The script uses the Data-Shapes pull down node and reads the list of equipment tab. After you select your type it reads that specific tab and throws everything in there.
    It means I have to update the shared parameter excel but that doesn't happen every often. I also have to maintain the scripts for Mech, plumbing and eventually tech/Elec, but I find it helpful to keep this information in excel anyway just as a lookup tool. Either way you have to maintain something with the standards that you want and I think having a few central locations work best.
    Here's a few screenshots:
    That stuff in the blue is to translate group under property from English to Revish.
Name:	family parameters 02.PNG
Name:	family parameters 03.PNG
Name:	family parameters 04.PNG
    Dynamo is REALLY goofy with temperatures.
Name:	family parameters 05.PNG
    Script Name: Mechanical Shared Parameters.dyn
    Packages used in this script:
    Data-Shapes version: 2019.2.33
    Orchid version: 210.0.0.7072
    archi-lab.net version: 2019.2.27
    Clockwork for Dynamo 2.x version: 2.1.2
    TimeStamp : 2019/10/14 16:6
    82
    10:36 PM
    THANK YOU for such a detailed breakdown! I'm surprised that you're 'generating' the SPs from an excel file - wouldn't that create a new/unique ID for each one, rather than loading in from the standard Revit SP.txt approach (which ensures a unified ID per parameter)? I guess it only matters if you rely on standard Revit schedules to consolidate and harvest your final data, which I guess if you Dynamo that out and consolidate post-Revit, probably doesn't affect your process.
    thanks again for sharing!
    Last Post: January 9th, 2018, 09:45 PM
    Last Post: January 9th, 2018, 05:45 AM
    Last Post: October 16th, 2017, 05:45 AM
  4. Bulk apply Shared Parameters to a Revit Family
    By ryntau in forum Dynamo BIM
    Last Post: December 14th, 2016, 04:07 PM
  5. Rename shared parameter
    By kowen1208 in forum Architecture and General Revit Questions
    Last Post: February 24th, 2014, 03:56 PM
