Results 1 to 10 of 15
Thread: Multi-bend Leader
    3,313
    05:46 PM
    Multi-bend Leader
    Has anyone come up with a decent solution to having more than one elbow in a Leader?
    Or for that matter, any connected multi-segment line (no, I won't use the P-word!)
Name:	Multi-bend Leader.JPG
    11,095
    05:46 PM
    Ugh. Tell me that's for wall finishes...
    2,822
    03:46 PM
    Make it a railing!
    May 30, 2015
    210
    04:46 PM
    If this is for wall finishes, use a Filter and make each finish its own Graphic representation in both color & pattern. Even if the end user can't read the Tag/symbol they can understand where the extent of finishes go.
    (So tired of trying to adapt Revit models to Drafting methods from ages ago)
    11,095
    05:46 PM
    You can't use a filter to change the plan representation of Paint. LOL
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    329
    06:46 PM
    Pencil? Pen? PENGUIN!?
    July 10, 2015
    Boise, Idaho
    783
    04:46 PM
    Quote Originally Posted by Mengelmn View Post
    That's kinda the point. Obsolete methods shouldn't be enabled
    3,313
    05:46 PM
    OK, then.
    Examples of a better method? In Plan?
    11,095
    05:46 PM
    I have this discussion with SO many Interiors Groups. There are only a few choices:
    1. Elevate it all. Obviously most interiors groups wont do that, for a number of reasons (its what i would do, and have done on jobs, even before Revit, but thats irrelevant).
    2. Use a plan symbol. If doing number 2, you have a few choices:
    2a. Manually drawing lines and Leaders (like Dave Shows)
    2b. Drawing lines/leaders/symbols/some annotation through something like Dynamo or an App, and remembering to rerun it before printing.
    2c. Doing it with a non linear symbol/tag (not auto smart) sitting on each wall.
    One way ive seen it done is not with lines following the walls, but with a simple rectangular tag showing the finish, and then a "finish change" symbol somewhere on the wall, indicating the finish or base has changed. Then you look for the next tag.
    The drawing lines thing, aka multi leader segments, is asked for a lot. We have a Detail Component that helps with it, and are working on automating placing them. Because- even though i would elevate every wall and call it a day- not everyone will. And they are going to get to the lines whether we help them draw them or not.
    You can hate on "old school" methods all you want, but so far ZERO other answers that actually work have been provided in the thread. Zero.
    May 30, 2015
    210
    04:46 PM
    OK, then.
    Here is an example from a Demo file. This uses filters to graphically show the locations of applied wall finishes. Typically a Tag would also be added.
  1. multi leader tags
    Last Post: March 18th, 2019, 02:26 PM
  2. Multi Category Tag Leader Alignment Issue
    By denden in forum Architecture and General Revit Questions
    Last Post: June 19th, 2017, 04:20 AM
  3. How i can create a 45deg. PVC bend
    By pascal khattar in forum MEP - Family Creation
    Last Post: September 2nd, 2015, 02:09 PM
  4. Wye combo w/ 8th bend
    By Cottontop22 in forum MEP - General
    Last Post: December 17th, 2014, 01:20 PM
    Last Post: November 26th, 2013, 03:45 AM
