Thread: How do I edit the level lines in revit?
    Lurker
    November 5, 2019
    04:08 AM
    I use level lines but I don┤t want that lines appear in the drawings. I want the mention of the levels.
    How do I edit the level lines in Revit?
    Thank you.
    November 4, 2012
    Budapest, Hungary
    147
    06:08 AM
    If you select a level on a section or elevation, a small '3D' sign will show up. If you click on the 3D sign, it will change to 2D, now you can edit the display of the elevation on the view, it won't change the level, only its visibility in the view. Now disable the sign on one end and drag with the small blue dot to as short as you want. You have to do this in all section and elevation views. It's not possible to show the 'mention' on both side of the drawing this way, only one side.
    Last Post: July 3rd, 2018, 06:45 AM
  2. Send Grid and Level lines to background
    Last Post: November 10th, 2016, 06:14 PM
  3. How to edit leader lines and arrows
    Last Post: April 13th, 2016, 04:54 AM
  4. Overhead Lines - Underlay View from Level Differs from Corresponing Level's Plan
    By Limbatus in forum Architecture and General Revit Questions
    Last Post: January 12th, 2016, 01:15 AM
  5. Adjusting Grid and Level Lines Per View,...Please Help
    Last Post: June 13th, 2012, 09:15 PM
