Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
Thread: Autodesk Certification
    Lurker
    November 14, 2019
    08:05 PM
    Hello everyone, I am going for Autodesk Revit certification next month. I just wanted to ask if anyone has experience with that? What should I prepare for? I have been using revit for couple years now, but there is so much more to it... Thanks for any insights
    Regards, (moderated: removed links)
    Last edited by LeanneZ; November 20th, 2019 at 12:18 PM. Reason: removed OP added links
    6,398
    04:05 PM
    The certification tests aren't too hard if you are using Revit every day. They tend to stick to more basic topics - find the height of a wall, place a stair and find a dimension, find something hidden in a view and pull a parameter, etc.
    3,549
    03:05 PM
    2 Not allowed! Not allowed!
    I felt like I knew too much on some of the questions.
    At a superficial look, you could get the answer, but - Revit being Revit - if you know the tricks to get around things, some of them can get ambiguous.
    Lesson learned: don't over-think your answer. Your first instinct is probably correct.
    Member johnp's Avatar
    March 24, 2015
    188
    02:05 PM
    In the event you do get hung up on a question, use the keyboard shortcut "KS", to search commands to see where they are. Some of the questions (in previous years) revolved around where a command lives on the Ribbon/UI. I found it especially useful when doing other disciplines I spend way less time in, (MEP/Systems).
    Forum Addict Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    1,015
    11:05 AM
    The family creation question got me. I did overthink it and the answer ended up not accepted. Specifically, I added an extra step of flexing the dimensions attached to the reference planes before attaching modeled content to them. Looking back, I can see now that this extra step was and is not necessary.
    May 14, 2012
    584
    02:05 PM
    I found it useful for identifying a couple features I had not used much ... one of which I use regularly now and the other I still rarely use and may never use much.
    6,398
    04:05 PM
    So much this. I ran into that the last time I did the Top Daug competition. They wanted some information about the vertical wall... my argument was that all walls are vertical (I know - tilt walls blah blah blah)
    Also - formatting matters. I missed a question once because I input the column grid location backwards. The test wanted F1 and I said 1F (or something like that)
    Forum Addict
    1,057
    06:05 AM
    I work in a training center for Revit and other products.
    I am the person that supervises the exams, and also I have sat several of the different discipline exams myself (All of them except MEP) and also the Autocad certification.
    I am not allowed to say much because of NDA but here is what I can say or the suggestions I have for you.
    As we are on the strucutre part of the forum I assume you are sitting the structure exam.
    If you are using Revit in production, and have been for several years you will have no problem on the exam.
    If you know the product well you may find that some of the questions you do not even need to actually execute the exercise to have the answer.
    The exam is 2 hours, 35 questions. So it is quite tight on timing. I finished the exam with 1 hour to spare. So as I said, if you feel you can answer the question without executing the steps of the question in the interface do so, mark the question for review, and when you finish if you have time spare you can come back to the question and double check your answer by doing the exercise.
    Additionally the question may ask you to do steps that simply have no bearing on the end result (such as the content of a string of text) You do not need to type the exact string of text in most cases to have the correct answer regarding the modification you need to perform. You will need to assess the need to perform the steps in the test questions, BUT I am simply suggesting you might find yourself questioning why you were asked to do certain steps. In fact, some of them are pointless to that question.
    If you do not use beams and beam systems, learn them.
    Learn how to perform inquiries on linked files.
    Learn the collaboration tools such as copy/monitor, and the options associated with it
    Do not save the file after each question - something you changed in responding to a question might end up effecting your volume, surface etc. in another question later. Close the file (do not close revit entirely) and re-open the file, even if it is the SAME file for the next question.
    Formatting matters, and so do UNITS. Use copy/paste between revit and exam interface whenever you can, that way there are no errors. Be careful not to include spaces before or after the text string if you do use copy/paste. The "robot" that checks the exam after will look for (example) 20 characters, if it sees 21 because one is a space, your answer is WRONG.
    The exam will give you "hints" by telling you how many numbers they expect in the answer it will be shown as ##.### m3 for example next to the answer box.
    If your answer is not 5 numbers long...you've got a problem in your execution...check your process. Also that answer might be 23.540
    Zeros at the start or end of a number string will be ERASED automatically by the robot. So if you put 0023.540000 it will take it down to 23.540 that it is seeking in the answer (as an example)
    Check your UNITS I have seen 1 question where the units needed to be converted, but I think this was a mistake in the exam.
    The exam does contain mistakes...for example I have seen a question that asked for a "volume in m2"
    As someone else stated - don't overthink your answers, if the question felt too easy, or you can see a clear mistake like a volume in m2....then the question was too easy...
    Don't stress too much, it's not that hard if you are using revit in production all the time.
    September 4, 2020
    08:05 PM
    To earn Certification you need to pass an Autodesk Certification Exam or series of exams.
    Choose the certification that is right for you. Select your required certification programme, level and product.
    Assess your readiness.
    Get the training you need and practise your skills.
    Take the required exam.
    Last edited by DaveP; September 30th, 2020 at 09:44 PM. Reason: Deleted sneaky urls
    July 30, 2014
    23
    03:05 PM
    Just out of curiosity, what benefit is there to being certified? and what does it cost?
    Last Post: November 30th, 2012, 10:15 PM
  2. Autodesk REVIT Certification
    By DGoffron in forum Architecture and General Revit Questions
    Last Post: July 18th, 2012, 02:10 PM
  3. Autodesk University: Certification Exams at AU Top 2,600!
    By Autodesk University in forum Blog Feeds
    Last Post: December 2nd, 2011, 02:15 AM
  4. Stair Landing according to...Autodesk Associate Certification
    By dealstu in forum Architecture and General Revit Questions
    Last Post: September 14th, 2011, 03:17 PM
  5. Autodesk Certification
    By safoulkes in forum Out There
    Last Post: May 22nd, 2011, 05:09 PM
