Thread: Show Centerline of Wall/Core
    December 20, 2010
    1,126
    09:51 PM
    We have a request from our layout group to show the centerline of all wall cores for layout purposes. I have never found a way to do this, but am hopeful someone has. Any help is appreciated.
    Wellington, New Zealand
    733
    01:51 PM
    Only way I can think of is that it would be easy to draw lines in correct place for all your walls using Dynamo
    11,096
    08:51 PM
    I wouldnt do it on an actual dontract doc, as they are just going to look goofy, with extra lines on every wall.
    Getting a Detail Line placed down the center of the core wouldnt be a massive undertaking, if you didnt mind them not all being cleaned up at the ends and corners. If they cred about the corners, i imagine its a whole other animal.
    December 20, 2010
    1,126
    09:51 PM
    Well since they actually use CAD for layout it could be a script that places a Centerline Detail line at the center of core of all walls, it won't matter if its clean at the corners, just need to add it, then export the DWG. I'm not really excited about doing this, ie when something changes verifying the re-export will be a pain. its really a feature request. I was thinking the analytical line might be able to be revealed. But not all walls will be structural so they wouldn't show up.
    2,794
    11:51 AM
    2 Not allowed! Not allowed!
    Super quickly thrown together but this might get you started.
    Made in Dynamo 2.02 + R18, just need clockwork and geniusloci packages
    Have tested in attached .rvt with different wall types / number of layers etc.
    It should be self-explanatory what's going on, but basically...
    Find the wall layers
    Look for Structure layers
    Draw curve in dynamo
    Draw detail line in Revit view
    If you have multiple structure layers it will draw a line for each one, but obviously this is just a start and so much more could be done with this like multiple views etc...
    December 20, 2010
    1,126
    09:51 PM
    Thanks Elton!. I've passed this on to the team to see if they can make it work.
    Member BD Mackey's Avatar
    November 1, 2013
    480
    07:51 PM
    Scott if the team is using Dynamo possibly have those lines go directly into a .dwg then you don't even have to export...
  1. change wall location line to wall centerline
    By andreasdraxl in forum Dynamo BIM
    Last Post: May 7th, 2018, 02:59 PM
  2. Dimension to linked file wall core centerline???
    By kwandrew2 in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2017, 10:56 PM
    Last Post: April 30th, 2016, 03:15 PM
  4. How to show only core of the wall in coarse view setting
    By Gumrah in forum Architecture and General Revit Questions
    Last Post: April 28th, 2014, 10:01 AM
  5. Elevator core walls only show up on first floor
    By gentlepuppies in forum Architecture and General Revit Questions
    Last Post: November 29th, 2012, 05:55 PM
