Hello,
As i was creating legends in Revit 2019 I found that the filled regions - though created to match the phase overrides, did not match the plans.
See images...
Additionally, the weird thing is that when I paste that same filled region into the plan, the colors match. There are no overrides in the visibility graphics.
Any ideas on what might be happening here and how to fix would be great.
Thanks in advance,
Do you have any element overrides applied? I just made a file with a new wall, existing wall, filled region, and a legend and didn't run into this. The only thing I noticed was the fills looked a little different depending on my zoom level.
Check the settings for the Phase-Existing material also.
Thank you for the help! I did have an override on it, but did not think anything of it because it was for the line not the fill but i cleared the override and it worked. I didn't realize that would make a difference. Went ahead and created a lineweight rather than using the override.
Thanks!
