Results 1 to 3 of 3
Thread: Putting "Z" value to family instances
    December 13, 2010
    Whangarei, New Zealand
    184
    10:10 AM
    Hi. I'm very new to Dynamo, and have a problem that I can't work out.
    I'm querying the insertion point of each foundation pile, projecting down to my topography to get the topo height at that point, then trying to add that "Z" value into a parameter in each foundation pile.
Name:	Topo graph.png
    I have it working (sort of) but it only works on the first pile created, and doesn't step through each pile.
    If I delete the first pile created, it alters the next-created pile.
Name:	Pile deleted.png
    I'm pretty sure this is something simple, that I just can't grasp!
    Any tips?
    Gold Coast
    2,680
    07:10 AM
    Quote Originally Posted by Chris Needham View Post
    Any tips?
    set lacing to longest on Element.SetParameterByName
    December 13, 2010
    184
    10:10 AM
    Quote Originally Posted by elton williams View Post
    Hi Elton. Thanks so much for that. It was a simple solution, as I thought it would be. I also had to set it on the "Point.Project."
    Thanks again!
  1. "Flatten" or "stiffen" parametric family
    By paidpal in forum Architecture - Family Creation
    Last Post: September 14th, 2018, 06:09 PM
  2. Replies: 2
    Last Post: April 12th, 2016, 09:06 PM
  3. "split surface" and "paint" in nested family
    By marcomella in forum Architecture and General Revit Questions
    Last Post: February 11th, 2015, 08:28 AM
  4. Rebar Diameter symbol "ě" is Showing as "0" in Revit 2014
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: July 14th, 2014, 02:49 PM
  5. warning message of "There are identical instances in the same place ..."
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: December 8th, 2011, 10:32 PM
