Results 1 to 6 of 6
Thread: Can't hide/turn off topo section hatch in plan?
    July 7, 2017
    Hernando, MS
    619
    10:23 PM
    I have a crawlspace plan that I need the toposurface to be turned on in order to show spot elevations of the grading underneath the building. Due to the sloping site, part of the plan has the cut pattern of the toposurface showing. I'd like for that pattern to not show up, but I can't seem to get it to hide. I've tried turning off toposurface cut patterns (foreground/background) in V/V, tried overriding the toposurface object in the view to do the same thing, and even tried creating a toposurface filter for the view. Nothing works. It works in section views, but not plan views. Is this some sort of hard-coded behavior where the Site Settings Section Cut Material always shows up when cut in plan regardless of other overrides, or am I missing something?
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    239
    03:23 AM
    hi
    may be i misunderstood your question but i think that you can modify site settings
    unfortunatly you change this aprameter for the whole file...
    Phil
    July 7, 2017
    Hernando, MS
    619
    10:23 PM
    Yeah that's not what I need. I need to hide the Topo cut hatch pattern in one plan only. I need it to show everywhere else.
    I set it to halftone in the view which sort of helps. The problem is I have some dimension strings that run through the hatch pattern that aren't showing up very well. Halftone helps somewhat, but I'd rather just not have the topo cut pattern at all on this one view.
    November 4, 2012
    Budapest, Hungary
    147
    05:23 AM
    Disable the Projection/surface pattern of the topography category in VV, not the cut pattern. This is a strange behavior of toposurfaces.
    June 30, 2016
    Lyon - France
    239
    03:23 AM
    Quote Originally Posted by infeeeee View Post
    hi
    don't know what version of revit you are using but disabling pattern of cut works very well on my 2018.3
    Phil
    November 4, 2012
    Budapest, Hungary
    147
    05:23 AM
    OP asked about plans, not sections.
    I now checked it in 2018.3 as well, on plans projection pattern setting governs the cut pattern, on section cut pattern governs the cut patterns.
  1. How to hide lines with a hatch(mask) in a family?
    By andreasdraxl in forum Architecture and General Revit Questions
    Last Post: April 18th, 2019, 09:50 PM
  2. Topo hatch not showing in just one elevation
    By jgardner in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2017, 08:34 PM
  3. Architectural Wall hatch mismatch in Plan and Section
    By anandmc05 in forum MEP - General
    Last Post: October 14th, 2015, 02:17 PM
  4. How can I make the hatch pattern from a linked Revit file turn off?
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: June 9th, 2013, 12:35 AM
  5. How to turn off the blue region from section view 3D
    By Soea in forum Architecture and General Revit Questions
    Last Post: June 28th, 2011, 01:30 PM
