Thread: Dynamo Package Versions
    6,387
    05:03 PM
    With the changes in Revit 2020 to how Dynamo is deployed & versioned, does this have a major impact on package versioning? In other words - If I'm still using 2019 (Dynamo 2.0.3) and I update to a package that is updated for Dynamo 2.1, will it brick graphs that I have kind of like the change from 1.x to 2.x?
    Member johnp's Avatar
    March 24, 2015
    180
    02:03 PM
    Since 2.0.3 to later versions does not involve major API changes, I believe you are good to go. Rhythm for instance will work from 2.0.x up to the latest daily builds.
    Dynamo loosely follows semantic versioning. So unless the first number is different, you should be good. https://semver.org/
    However, some of the big changes to keep in mind are that search will perform differently and dropdowns can be different as well. https://www.youtube.com/watch?v=JH_mqj6eiGs
    6,387
    05:03 PM
    Thanks
  1. New Dynamo for RAM just added to the Dynamo SIMPLEX package
    By Simply Complex in forum Blog Feeds
    Last Post: April 30th, 2019, 08:45 AM
    Last Post: June 25th, 2018, 09:45 PM
  3. Replies: 4
    Last Post: August 2nd, 2017, 02:30 PM
    Last Post: March 1st, 2016, 09:45 PM
    Last Post: November 19th, 2014, 11:45 AM
