Thread: help with the sweep tool
    Member mark2009's Avatar
    May 27, 2015
    109
    04:31 AM
    Unhappy help with the sweep tool
    Hi guys,
    I'm trying to create a flashing that goes around a pitch roof, that's flushed against the roof, not angle to one direction.
    please see the attachments.
    Cheers,
    mark
Name:	sweep tool problem.jpg
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    253
    03:31 PM
    I looked at it and you need 3 types of flashing with 3 different angles.
    Also the roof tool isn't used the way it is intended in this model.
    May 27, 2015
    109
    04:31 AM
    Is there an easier way to achieve that?
    November 1, 2013
    5
    08:31 AM
    Have you tried creating two types of fascia? One with the pitch of the roof for the eaves and the other with a 90 degree angle for the rakes? If I really wanted to model something that specific as flashing, I think that is how I would try it.
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    906
    01:31 AM
    yep, I made 2 for a skillion roof. 0 degrees (90) and 8 degrees. never quite worked out how to make a parametric profile for it.
    May 27, 2015
    109
    04:31 AM
    cheers for all your comments. I've tried the roof: fasica, but the profiles don't miter.
    June 13, 2011
    Australia
    906
    01:31 AM
    Yep, mine didn't at corners.
  1. Profiles with sweep tool - reference plan
    Last Post: October 22nd, 2018, 06:33 PM
  2. How do I use void tool to cut away this sweep blend model-in place
    By revitishard in forum Architecture and General Revit Questions
    Last Post: December 15th, 2017, 05:00 PM
  3. Is there an advantage to using a wall sweep as opposed to an in-place family sweep?
    By cnd in forum Architecture and General Revit Questions
    Last Post: September 14th, 2015, 08:16 PM
  4. Sweep tool Broken
    By Tim West in forum Architecture and General Revit Questions
    Last Post: November 21st, 2012, 10:04 PM
  5. Sweep tool made everything go boom.
    By fallonbrooks in forum Structure - General Questions
    Last Post: August 17th, 2011, 07:50 PM
