Thread: Cut Geometry
    October 15, 2019
    16
    05:29 PM
    Cut Geometry
    Hi there,
    I am trying to do a void in Model in Place, but it does not allow me to do in the column (attached prt scr).
    The cut geometry is not allowing me to create the void, because I can not select the column (grey).
    I can do it with the slab below, but not in the column. Any ideas?
Name:	Cut Geomtery.png
    November 4, 2012
    Budapest, Hungary
    147
    07:29 PM
    You can only cut columns with the Opening By Face command, however it won't work vertically.
    Model it as a wall or floor if you really need this with a vertical void. It's not common in reality that columns have vertical openings. If you have multiple columns like this, try to add the void in the family.
  1. Join geometry
    By sorati22 in forum Structure - General Questions
    Last Post: January 9th, 2019, 06:04 PM
  2. Can you cut imported geometry
    By schiette in forum Architecture and General Revit Questions
    Last Post: April 25th, 2017, 03:07 AM
  3. Always export as geometry
    By cve60069 in forum Structure - Family Creation
    Last Post: December 20th, 2013, 12:31 PM
  4. How to Properly Cut Geometry?
    By Xawier in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2011, 02:43 PM
  5. Mass geometry
    By madsagger in forum Architecture and General Revit Questions
    Last Post: April 6th, 2011, 08:47 AM
