Thread: Roof to Wall
    November 21, 2019
    8
    04:37 AM
    Roof to Wall
    How would I make this roof go up
    against those two walls and not
    through it?
    December 20, 2010
    1,138
    07:37 AM
    use the vertical opening tool, pick the roof, then in plan trace the shape of the wall.
    November 21, 2019
    8
    04:37 AM
    Thanks, that worked beautifully.
    Whangarei, New Zealand
    187
    11:37 PM
    Is there any reason that you can't use those walls to define the edge of the roof?
    Then it won't be an issue.
    Sent from my Mi A3 using Tapatalk
    November 21, 2019
    8
    04:37 AM
    "walls to define the edge of the roof"
    Thank you, please explain how that
    is done. I did use the vertical opening
    tool. Is there a better way?
    May 20, 2011
    Chicago, IL
    814
    06:37 AM
    Quote Originally Posted by five cats View Post
    "Is there a better way?
    Not necessarily better, just different way. You can use Join Roof tool (roof 1.png, roof 2.png), or modify roof sketch lines to follow walls outline (roof 3.png). If you use Join Roof tool, make sure walls have miter cut at corners where in contact with roof.
ID:	37867   Click image for larger version.
ID:	37868   Click image for larger version.
    November 21, 2019
    8
    04:37 AM
    Oh cool, thanks, I'll try those things.
  1. Joining a roof and a wall
    Last Post: October 14th, 2014, 10:11 PM
  2. attach a wall between two roof
    By knosuhor in forum Architecture and General Revit Questions
    Last Post: March 19th, 2014, 12:22 PM
  3. Wall to roof connections
    Last Post: October 18th, 2011, 06:28 PM
  4. Roof to wall connection
    Last Post: October 7th, 2011, 02:06 PM
  5. roof to wall
    By daemonhassan in forum Architecture and General Revit Questions
    Last Post: January 15th, 2011, 03:37 PM
