Thread: multiply isn't equal to divide!!
    Member philsogood's Avatar
    June 30, 2016
    Lyon - France
    208
    01:36 PM
    hi
    i make an unexpected discovery :
    diameter = radius x 2 is different from radius = diameter / 2
    i know i can be silly but the first expression was found in a family and the family works
    when i decided to change the family , because in my mind in think it's more logical, the family doesn't work anymore!!
    crazy...
    i don't know how to explain this!!
    Phil
    https://app.box.com/s/dirnen48tnt7cgqwisw5arpk6jt41ra8
    Member Infinite's Avatar
    November 19, 2019
    Utrecht
    61
    12:36 PM
    Works for me? Or am I misunderstanding something?
    Member Geert's Avatar
    February 8, 2011
    168
    02:36 PM
    With an outer diameter smaller than an inner diameter?
    3,146
    05:36 AM
    When I run into a math problem inside Revit I always assume it is ME...Math is not my game. Math IS their game however...Revit (all CAD) is graphical math at its core.
    If you've built something and constrained elements and then change the logic you need to disconnect the constraining dimensions etc and reassign them. If a parameter value is in play and your geometry needs to change and alter the constraint it will usually break. Reset parameters to zero so Revit can apply the new values required when you attach a parameter to dimension constraints.
    3,228
    08:36 AM
    I don't see any problem in the formulas that you show in the screen capture. They are doing the math correctly. Something strange, as others have noticed, is that the value of your interior diameter is greater than your exterior diameter, at least in the Family Types window. I could not open the family, though. It gave me an error.
  1. EQ won't Equal
    Last Post: October 30th, 2019, 08:11 PM
  2. Divide a curved model line into equal segments
    Last Post: November 2nd, 2017, 12:53 PM
  3. Working with multiply Revit Links
    Last Post: September 9th, 2016, 05:36 PM
  4. Schedule - multiply two values
    By sharkmullet in forum Architecture and General Revit Questions
    Last Post: August 20th, 2013, 08:36 PM
  5. Are all (MEP) categories created equal?
    By snowyweston in forum MEP - General
    Last Post: January 22nd, 2013, 03:14 PM
