Results 1 to 10 of 12
Thread: Monocle icons
    3,310
    06:46 PM
    Monocle icons
    Hey, John;
    I've got Monocle 2019.11.13 installed (Revit 2020.2), but the icons are missing.
    Same thing in Revit 2019.2, Dynamo 2.0.3 Monocle 2019.11.13
    Everything seems to work. I just can't see what I'm clicking on.
Name:	Monocle icons.JPG
    Any idea what I screwed up?
    Member johnp's Avatar
    March 24, 2015
    180
    04:46 PM
    Wow, that is very odd. They should be there. Let me take a look to see what changed in the new core that shipped with 2020.2. From what I hear it did mess a few things up on other packages as well.
    6,387
    07:46 PM
    I am seeing the same thing after updating this morning (Revit 2019.2)
    March 24, 2015
    180
    04:46 PM
    sigh
    March 24, 2015
    180
    04:46 PM
    let me get the latest dynamoRevit installed and see wtf is going on
    March 24, 2015
    180
    04:46 PM
    Double sigh. I am afraid updating is not reproducing the errors for me.
    I can't even think how to trouble shoot this at the moment. Any info you guys can provide here would be helpful. List of Packages with Versions maybe? Maybe a list of addins installed. I am a bit stumped TBH
    6,387
    07:46 PM
    Revit 2020 - no packages installed in Dynamo except Monocle, no icons show up.
    Revit 2019 - no icons show up, package list is in the attached images. I actually downgraded Monocle, but there were no icons when it was the newer versions.
ID:	37994   Click image for larger version.
ID:	37995   Click image for larger version.
ID:	37996   Click image for larger version.
    6,387
    07:46 PM
    Or I now see an IO error:
    While loading assembly MonocleViewExtension, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null, Dynamo detected that the dependency Xceed.Wpf.AvalonDock, Version=3.4.0.0, Culture=neutral, PublicKeyToken=3e4669d2f30244f4 was already loaded with an incompatiable version. It is likely that another Revit Addin has loaded this assembly, please try uninstalling other Addins, and starting Dynamo again. Dynamo may be unstable in this state.
    It is likely one of the following assemblies loaded the incompatible version:
    UIFramework, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode, Microsoft.GeneratedCode
    While loading assembly Xceed.Wpf.AvalonDock, Version=3.4.0.0, Culture=neutral, PublicKeyToken=3e4669d2f30244f4, Dynamo detected that the dependency Xceed.Wpf.AvalonDock, Version=3.4.0.0, Culture=neutral, PublicKeyToken=3e4669d2f30244f4 was already loaded with an incompatiable version. It is likely that another Revit Addin has loaded this assembly, please try uninstalling other Addins, and starting Dynamo again. Dynamo may be unstable in this state.
    Actually there are several.
    3,310
    06:46 PM
    Here's my deets:
    I'm seeing this in both Revit 2019.2 Dynamo core 2.0.3.8810 Dynamo Revit 2.0.3.8811
    and in Revit 2020.2 Dynamo core 2.3.0.5885 Dynamo Revit 2.3.6270
    The only other thing I can think of that's unusual is that I'm loading all of my Packages from a mapped network drive
Name:	Dynamo Package paths.JPG
    I'll try unloading all of my add-ins (Kiwi Codes Family Browser, COINS, BIMLink, Bluebeam) & see if that helps
    Chad, where'd you see those errors?
    6,387
    07:46 PM
    They are at the end of the menu bar. I also get those for Archi-Labs, but I've been getting those for ages.
  1. Anyone else having problems with the modify icons?
    By billiam in forum Architecture and General Revit Questions
    Last Post: December 19th, 2012, 09:41 PM
  2. File Icons
    By Walica in forum Architecture and General Revit Questions
    Last Post: August 29th, 2012, 03:41 PM
    Last Post: August 6th, 2012, 11:15 AM
  4. Tool icons disappeared
    By leetecture in forum Architecture and General Revit Questions
    Last Post: July 12th, 2012, 09:11 PM
  5. The forum icons
    By Defiant1 in forum Forum Suggestions and Feedback
    Last Post: September 16th, 2011, 07:53 AM
