Thread: Label Parameters - Titleblock creation
    September 21, 2016
    Boston
    218
    06:56 PM
    I am trying to understand how labels work in family editing.. I am making a sheet which includes a title-block with text fields. Some of the text is set up where the label value is changed per sheet, and on some, it is changed universally on all of the sheets. For example, on each sheet, if you change the date one one sheet, it changes it to the same value on all of the sheets. On other instances, it is unique to each sheet.
    How are the parameters of the labels different in order for one to change universally, vs. on a sheet by sheet basis? I am using an example that someone made, but I can't see any differences in the label family itself.
    10,716
    04:56 PM
    2 Not allowed! Not allowed!
    In typical families:
    Instance: This item only
    Type: All items of this type
    On Titleblocks it gets tricky, because there can be parameters for:
    Titleblock Instance: This titleblock only
    Titleblock Type: All titleblocks of this type
    Sheet (Always instance): This sheet only
    Project Parameters: Project Wide, aka behaves like type.
  1. Sheet Size Intelligent Label for Titleblock
    By BarefootItalian in forum Architecture - Family Creation
    Last Post: August 9th, 2019, 10:22 AM
  2. titleblock parameters via dynamo
    By ncurcio in forum Dynamo BIM
    Last Post: July 24th, 2017, 03:54 PM
  3. Edit Revit titleblock and label
    By Andythebear in forum Architecture and General Revit Questions
    Last Post: March 24th, 2016, 01:32 PM
  4. Label on Titleblock Not Editable
    By Genghis Khan in forum Architecture and General Revit Questions
    Last Post: September 11th, 2015, 07:42 PM
    Last Post: July 31st, 2015, 06:15 AM
