Thread: Project parameter is not being reflected in properties palette ?? any suggestions
    December 2, 2019
    11:28 AM
    Im quite new to revit & i'm following steps outlined in"Exploring Autodesk Revit 2019 6th edition". I specifically want to set a project parameter for "illumination level" after following the steps i should be able to see the change reflected in properties palette, this is the problem . I'm not seeing the changes in properties palette , on my own i adjusted VG setting and still to no avail, any suggestions????
    November 4, 2012
    117
    08:28 PM
    - VG stetings has nothing to do with parameters. Parameters are related to elements, while VG is about the current view.
    - Only instance parameters show up on the properties palette, type parameters show up on the edit type dialog. Are you creating instance parameters, or type?
    December 2, 2019
    11:28 AM
    Quote Originally Posted by infeeeee View Post
    Thank you for responding , im trying to change project parameters associated with the model and i want to see the changes reflected in the properties palette. Simply out of frustrations i changed VG settings because after setting the parameters i never saw the changes in the properties palette. At this point im a student just trying to learn how to effectively use this program.
    August 7, 2015
    South East England, UK
    11
    07:28 PM
    What categories are you assigning the project parameter to?
    I assume it is Rooms or Spaces. The parameter will only show up when you select an element of a category to which you have assigned that parameter. It will not show up in the properties palette without selecting an element first.
  1. Parameter location in Properties palette
    By andrus in forum Architecture and General Revit Questions
    Last Post: November 20th, 2017, 04:25 PM
  2. Replies: 1
    Last Post: November 6th, 2017, 09:29 AM
  3. Faster Response w/ Properties Palette
    Last Post: May 24th, 2017, 01:31 AM
    Last Post: February 1st, 2017, 07:15 PM
    Last Post: December 13th, 2015, 06:15 PM
