Results 1 to 9 of 9
Thread: Keyed and General Notes on sheet
    April 2, 2019
    02:58 AM
    Iĺm looking for a way to automate our MEP keynote legend that appears on sheets, or at least make the process less time consuming.
    We are currently manually copying our user keynote annotation symbol down for each keynote in the ôlegendö, which is just text. We also have a General Notes section that we do the same thing except the numbering is text instead of the keynote annotation symbol. This is accomplished with numerous pieces of text, lines, and our copied user keynote symbol.
    The desired end result can be seen in the attached graphic.
    Is there an easier way to accomplish this in Revit? Dynamo?? Please note that the formatting must remain as shown to match company standards.
Name:	keyed notes.JPG
    Member cganiere's Avatar
    January 5, 2011
    218
    01:58 AM
    I created a schedule for the key notes and then copy the symbol (a hexagon) to the top of the table.
    August 7, 2015
    South East England, UK
    14
    09:58 AM
    Could you achieve this with a Detail group? Then you can copy and paste the detail group to any sheet you want in the same position as the copied one.
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    220
    01:58 AM
    I just use note blocks for this. For General notes I have a symbol family that we place in a separate detail view. For the keyed notes I have a symbol family that I place in the specific views and that is symbolically correct (i.e. a triangle with a number in it). Both families have the same parameters: "note filter", "note number", and "note text".
    Obviously by using note blocks you won't be able to have the special key note symbol in the block itself, but I considered this not very much of an issue. Also with this method you get the advantage of having the symbol for the keyed notes in the view itself were it is much less likely to go "missing" and you can centrally manage all of your notes through a schedule.
    February 22, 2013
    375
    04:58 AM
    We've gone around and around with this at my company. I've pushed everyone on our Mechanical side to use Note Blocks, but even after several years there are people who don't get how it works. Every new hire fumbles with it. Our electrical people didn't like it all and are still using a Generic Annotation family for each line, which has to be shifted up/down as they make edits.
    The biggest issue are the stupid #$%&@ circles. The standard is for that circle to appear around every number in the block of notes. So we have to manually place circles over top of the Note Block schedule. Of course, as notes are edited, added, deleted, etc, these circles will no loner be aligned.
Name:	bubble notes.JPG
    I tried to sneak in a change to this standard, where I would put a custom character (a # with a circle around it) in the header and let the numbers in the Note Block just be naked. Revit-using architects that we work with do this so I hoped it would fly here. It did not go over well. Management wants their circles and doesn't care if we have to spend time manually placing them.
Name:	bubble notes2.JPG
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,535
    02:58 AM
    We just use the single identifier symbol at the top of the schedule.
    It would take some experimentation to get the spacing right, but you might be able to use a double schedule, with the circle being provided by a unicode character or image file. Since keynote schedules can display parameters in project you can add a parameter there to hold the circle info. It might take two - one to force the row size in the schedule with information, and a second to underlay with the circle? While it would take some setup, once you figured it out you wouldn't have to manually add the circles.
    I haven't looked at how easily Dynamo works with schedules, but that might be another route to skip manual placement.
    10,875
    03:58 AM
    6 Not allowed! Not allowed!
    This.
    And if someone says *it isnt good enough for the company standard* tell them they need to (seriously) get over it (or themselves). Lets suppose hypothetically, that you COULD automate it with Dynamo... Its not adding any value, and its CERTAINLY adding more work, because any time someone changes a note such that the spacing of the schedule changes, it has to get updated.
    If someone really IGNORES the note because the circle or hexagon isnt copied 8 times, im dumbfounded how they have survived in the real world.
    February 22, 2013
    375
    04:58 AM
    This.
    That was basically my argument: "They're dumb circles... WHO GIVES A F---?" The response was "That's our standard." We have other departments who do industrial and plant design, and they're using AutoCAD or Plant3D. They draw the bubbles, so we have to draw the bubbles, because bubbles are important dammit.
    What I've taken to doing is simply waiting until the day the project goes out to place all of those stupid circles. I looked into creating my own custom unicode characters but I ran into a few issues with that.
    10,875
    03:58 AM
    Thats brutal. I feel for you (seriously).
  1. Keyed Notes not showing up
    Last Post: January 21st, 2019, 04:23 PM
  2. Schedules for General Notes
    By Ant123 in forum Architecture and General Revit Questions
    Last Post: April 9th, 2018, 02:49 PM
  3. Using Keynotes for General Notes
    Last Post: January 8th, 2014, 07:22 AM
  4. General Notes with sheet reference?
    By Barrie in forum Architecture and General Revit Questions
    Last Post: July 8th, 2013, 01:16 PM
  5. Best way to handle Keyed Notes?
    Last Post: August 4th, 2012, 02:31 AM
