Results 1 to 10 of 19
Thread: ! AutoCAD polyface Mesh into Revit !
    October 16, 2016
    442
    03:03 PM
    Hello all,
    I received a slab in Revit which is a Polyface mesh in autoCAD. I want to know if there is any way to convert this element in a Revit element in order to work with it. Each time that I explode the cad, it is disappeared with the error 'Import contained some 3D data or points which can't be exploded.' ..any idea?
    Thank you!
    December 11, 2010
    Astana
    237
    09:03 PM
    Hello!
    MESHSMOOTH
    CONVTOSOLID
    But it’s better (to ask) to export as a solid or recreate in Revit, if not a complex shape.
    October 16, 2016
    442
    03:03 PM
    Hello!
    MESHSMOOTH
    CONVTOSOLID
    Hello,
    with the MESHSMOOTH option > the geometry is destroyed ans with the CONVTOSOLID nothing happens.
    It is a really complex shape. I dont know exactly how we can modelised in Revit .
    December 11, 2010
    Astana
    237
    09:03 PM
    In what program was the slab modeled? Can you attach the dwg?
    October 16, 2016
    442
    03:03 PM
    I dont know which software they used. Attached you will find the results from the MESHSMOOTH option. I cannot share the file here.
    Thank you in advance !
ID:	37959Click image for larger version.
ID:	37960Click image for larger version.
    June 21, 2012
    Tours, France
    1,122
    05:03 PM
    That slab looks doable with Revit!!, you need to control the sub elements in the slab shape edit mode (Add points, Split Lines, and so on), And nothing fancy but I'll give it a try with Revit!, I've do this one in 1 min
    December 11, 2010
    Astana
    237
    09:03 PM
    Agree with Andres, try to recreate in Revit using the dwg slab link for tracing.
    October 16, 2016
    442
    03:03 PM
    I cannot tracing the slab in revit. The snaps and the pick lines don't work. Also the bottom of the slab has also slopes .
    June 21, 2012
    Tours, France
    1,122
    05:03 PM
    Quote Originally Posted by MARIA1993 View Post
    Still being doable in Revit, you can modify the slab sub elements and by working in wire-frame mode you can still seeing the corners and slopes, there are a lot of those in your model but there are also some coincident edges, so you can use Reference plane to have some help!
    11,160
    10:03 AM
    Firstly, its poorly modeled in whatever software it was made in, so i wouldnt want to trace it OR import it, anyway. I saw that because looking at the triangulation and where it happens, im 90ish % sure that isnt the actual design intent. If it is, id love to see the drawing that goes with it.
    Second, its 100% doable with shape editing, even with the underside sloping.
  1. Revit Mass - Loft from Adaptive Profile contains only Mesh Geometry
    By Twheat01 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 29th, 2019, 12:30 PM
    Last Post: December 12th, 2018, 11:15 AM
    Last Post: January 6th, 2015, 03:45 AM
    Last Post: December 23rd, 2014, 09:15 PM
    Last Post: November 18th, 2011, 03:15 AM
