Thread: Room Tag with OccupanT (NOT OccupanCY)
    3,358
    07:41 AM
    Can't believe I've never run across this before, but I'm trying to create a Room Tag that shows the Occupant and their Department.
    I can add Department into the Tag not problem, but the Occupant parameter is not available in the Tag family Editor.
    Occupancy is in the list, but not Occupant
    That's a built-in Room parameter, so why would it not be allowed in a Room Tag?
    11,160
    07:41 AM
    Occupant? Occupant is not a built in Parameter. Im looking at a file right now that has no parameter called Occupant, for Rooms.
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    368
    08:41 AM
    Started a new file with no template and there is no Occupant parameter.
    3,188
    05:41 AM
    Occupant is a Project Parameter in the stock Architecture templates...at least. It will need to be shared parameter... as you know.
    3,358
    07:41 AM
    Huh.
    I guess we've had that in our Template for so long, I just figured it was a built-in.
    I did figure out what the root cause of my "problem" was, though.
    When you add a parameter to a Tag Label, you have to add the Shared Parameter from inside the Edit Label dialog.
    You can't add the parameter at the family level. It must added be inside the Label.
Name:	Add Tag param.JPG
ID:	38005 Click image for larger version.
Name:	Add Tag Label param.JPG
  1. room tag with occupancy info (2019)
    By ledgewood33 in forum Architecture - Family Creation
    Last Post: December 11th, 2019, 02:29 AM
  2. Revit OpEd: Occupancy Calculations and JavaScript
    Last Post: October 28th, 2014, 05:15 PM
  3. R&D BIM IoT Occupancy Comfort Sensor
    By m.p.diker in forum Third party Add-Ins, API and R&D
    Last Post: October 20th, 2014, 01:33 PM
  4. Revit OpEd: Occupancy Data Application
    Last Post: January 27th, 2012, 05:15 PM
