Results 1 to 10 of 13
Thread: Grid extension out of crop area
    March 6, 2019
    64
    02:13 PM
    Is it possible to control / minimize it?
    Thanx!
    November 4, 2012
    117
    09:13 PM
    What do you want to achieve? If you change the grid to 2D extents, you can modify the extents the way you want on a per view basis. It can extend out from the crop region. Just click on the small 3D sign, and rightclick on the grid.
    From the help:
    https://knowledge.autodesk.com/suppo...60372-htm.html
    https://knowledge.autodesk.com/suppo...E3220-htm.html
    March 6, 2019
    64
    02:13 PM
    The grid in my model is actually in a revit linked file, no way to manipulate it.
    But, my issue is: in a cropped view plan (floor plan) the grid is extended out of the crop area to a fixed length. If I resize the Annotation crop, grid don't chage. I want that lengh to be zero, so out of the crop area to be only grid IDs, otherwise I cannot fit the building in 4 sheets 48"X36".
    See attached.
    Thanx!Click image for larger version.
    November 4, 2012
    117
    09:13 PM
    I think it's not possible to change this length. If you lock the ends of the grid together you have to modify this once for each side for each page.
    Also try to use a scope box, it makes crop region management much easier: https://revitpure.com/blog/10-tips-t...it-scope-boxes
    You can assign a smaller scope box to the grids, so the length of the grids won't depend on the crop of a view, but from a scope box.
    Also check out the porpagate extents command, if you can't use a scope box for this: https://help.autodesk.com/view/RVT/2...0-7C01163078CC
    Member cganiere's Avatar
    January 5, 2011
    218
    12:13 PM
    Sometimes I turn off the grids in linked files...
    Wellington, New Zealand
    704
    09:13 AM
    Quote Originally Posted by cganiere View Post
    Sometimes? Other than my checking views, I always have them off...using view filters
    November 4, 2012
    117
    09:13 PM
    How do you filter the grids from a linked file? I'm looking for others' solution.
    I assigned a scope box to the grids in my file than I could filter for scope box. Other option is to change or rename the type of the grid in my file and filter for that, but it could mess up copy/monitoring, and can generate false positives. Or add a parameter to all grids and filter for that.
    You cannot filter for linked file name.
    May 4, 2011
    114
    03:13 PM
    -1 Not allowed! Not allowed!
    Make a unique named type for the grids in your file that you know won't exist in the other files. Filter by type does not equal name.
    July 10, 2015
    Boise, Idaho
    773
    01:13 PM
    Turn off their shared levels and grids workset. Reject their file if the levels and grids are not on the proper workset
    March 6, 2019
    64
    02:13 PM
    I simply turn off grids for all linked files in visibility graphics.
  1. Grid Bubble Default Extension
    By koolair in forum MEP - General
    Last Post: February 5th, 2018, 01:01 PM
  2. Grid extension past scope box
    Last Post: December 3rd, 2017, 09:24 AM
    Last Post: April 27th, 2016, 04:15 PM
  4. Grid line extension beyond cropped View?
    Last Post: November 17th, 2015, 04:36 PM
  5. Column Grid Crop Boundary Offset
    By aorton in forum Architecture and General Revit Questions
    Last Post: January 16th, 2013, 09:52 PM
