Results 1 to 10 of 14
Thread: BIM360 Alternatives
    Member Infinite's Avatar
    November 19, 2019
    Utrecht
    65
    04:54 AM
    BIM360 Alternatives
    Hey guys,
    I know BIM 360 is a great system to work on, with more users on one Revit project internationally.
    It's also known that it has a monopoly on the market. But what are better/cheaper alternatives for cloud worksharing with Revit?
    Are there users here on the forum that have experience with other cloud software packages?
    2,830
    09:54 PM
    I dont know if there are any other realistic choices.
    Dropbox and its ilk are horrible. They cant update each of the attached systems fast enough.
    Before BIM360 we used network accelerators like the SteelHead appliance from Riverbed but thats hardly a cloud based solution and you had to be on the same WAN.
    My recommendation... drink the Kool-Aid.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    299
    11:54 PM
    I don’t know if there are any other realistic choices.
    Dropbox and it’s ilk are horrible. They can’t update each of the attached systems fast enough.
    Before BIM360 we used network accelerators like the SteelHead appliance from Riverbed but that’s hardly a cloud based solution and you had to be on the same WAN.
    I don't have very much experience with the following cloud-based workharing solutions, so I don't know if they're better/cheaper. But here are a few alternatives:
    1. Aconex (Oracle)
    2. Box.com
    3. Egnyte
    11,160
    11:54 PM
    Quote Originally Posted by Knitro87 View Post
    1. Aconex (Oracle)
    2. Box.com
    3. Egnyte
    Not with worksharing. Simply put: Wont work.
    Your ONLY options to use regular worksharing, are: BIM360, Panzura, Nasuni. If you dont mind working on some seriously unsupported software, i think GreenBIM and/or Globalscape has a method, too. But after seeing how they work, big bag of nope.
    Member BD Mackey's Avatar
    November 1, 2013
    480
    10:54 PM
    2 Not allowed! Not allowed!
    I had one client use AWS and set up Revit Server on it. OMG it took 35 minutes every time a user opened the file and Synchronizations were long too. Overall they lost productivity time that would have paid for BIM360 licenses for a decade.
    December 3, 2014
    Austin, TX
    299
    11:54 PM
    You're right. It looks like Aconex is just used for issue tracking and project management/coordination. Egnyte, on the otherhand, appears to have a cloud-based worksharing solution (https://www.egnyte.com/blog/2017/11/...-storage-sync/). The setup seems cumbersome and not as intuitive as BIM 360, though. I thought Box.com had a workflow with Box Sync (or Box Drive), but this solution may have been discontinued.
    November 19, 2019
    Utrecht
    65
    04:54 AM
    If I see the comments and check my research, BIM360 is still the only option. Hate it when I'm forced to use a specific software. Will use it till some other strong competitor will arise. All other experiences are still welcome.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    255
    04:54 AM
    Quote Originally Posted by BD Mackey View Post
    I work for some projects on Azure with Revit server and it works very good. I would recommend it as a BIM360 alternative.
    11,160
    11:54 PM
    Just a heads up:
    Quote Originally Posted by from Egnytes own website
    • Central Files co-located in a Storage Sync instance: If you want to leverage Revits File-based Worksharing mode, all the collaborators require to access the same Storage Sync instance. In other words, Revit users must open the file through their network drive letter, and not through Egnyte Connect Desktop App.
    • Remote workers who wish to work on a Revit central file will require to access the Storage Sync device over VPN.
    I would read this very carefully. What it implies (to me) is that Egnyte will successfully replicate the file, but that people *using worksharing* all need to be in the same spot, while they use it. I might be misunderstanding, but if im not, it is behaving exactly how DFSR, Synology, Dropbox, Box, all do. They *work* with worksharing, but not if people are in different locations using worksharing at the same time.
    Happy to be wrong, of course.
    November 19, 2019
    Utrecht
    65
    04:54 AM
    Just a heads up:
    This is exactly how I image all those apps to be working. The reason why I don't have the guts to make a different step.
  1. Missing Parameter Jerk - Alternatives
    By snowyweston in forum Third party Add-Ins, API and R&D
    Last Post: June 16th, 2015, 02:51 PM
  2. Alternatives to Brownstreak?
    By josephpeel in forum Worksharing and Cloud Coordination
    Last Post: October 8th, 2014, 04:05 PM
  3. Revit Alternatives?
    By Dandharma in forum Out There
    Last Post: August 27th, 2014, 02:05 PM
  4. Revit alternatives to Autocad layers?
    By danzam in forum Architecture and General Revit Questions
    Last Post: May 5th, 2014, 07:30 PM
