Results 1 to 9 of 9
Thread: stairs
    August 15, 2019
    11:45 PM
    stairs
    hi, need some help on how to model this type os stairs
Name:	Annotation 2019-12-24 105659.jpg
    1,691
    01:45 AM
    we use these stairs a lot in Holland, but I never really got it to work nicely in Revit with the stairs tool. You can get pretty close with the sketch tool, but stuff like risers will not look very good in the turns.
    August 15, 2019
    11:45 PM
    so what do you think will be the best approach, regular extructions?
    6,388
    07:45 PM
    Does the U-Shaped Winder that is built-in not work? I don't know enough about that type of stair to know where the issues are, but at least at a glance it looks fine to me...
ID:	38089   Click image for larger version.
    December 28, 2019
    Pune
    05:15 AM
    Hi krusty2k1,
    I am using Revit 2018, and created the stair by sketch.
ID:	38096Click image for larger version.
    1,691
    01:45 AM
    Quote Originally Posted by krusty2k1 View Post
    It all depends on how nice and exact you want your stairs to be, but from what I have done with these kinds of stairs, that is the only way to get them to look right
    Some of the things that are not right in the image below. For a plan view that is OK and probably for a early design it is too, but for CD's I would not want one of those in my model.
    Quote Originally Posted by abhisekh View Post
    Hi krusty2k1,
    As with the other stairs above a lot of small things that are just not right
    6,388
    07:45 PM
    Good to know
    1,691
    01:45 AM
    Good to know
    A few of those things you can get a bit better, but overall the stairs tool sucks for these kinds of stairs. Problem is for residential in Holland I think 90% of all homes have a stair like that, so I believe that a lot of companies are building them by hand or get them from a manufacturer, some of which do IFC and a lot of which do imported dwg
    November 27, 2013
    52
    07:45 PM
    As a general note - System Families in Revit are good for creating content that is in the LOD 200-300 zone. The small things that Robin has highlighted, which aren't quite perfect with the U Winder tool, are things I feel are in the LOD 350-400 zone, and would be picked up through enlarged details (utilizing detail components, lines, and regions to assist in heightened accuracy). Is this not the case?
  1. [Stairs] Unexpected cutting steps in stairs
    By woszer in forum Architecture and General Revit Questions
    Last Post: January 6th, 2018, 06:22 PM
  2. Structural stairs from architectural stairs
    By wpnc79 in forum Structure - General Questions
    Last Post: October 31st, 2016, 03:28 PM
  3. Stairs
    By vikvar29 in forum Architecture and General Revit Questions
    Last Post: August 27th, 2015, 01:36 PM
  4. Stairs. Damn stairs.
    By Jaime in forum Architecture and General Revit Questions
    Last Post: June 24th, 2015, 07:24 PM
  5. Stairs
    Last Post: May 6th, 2014, 03:58 PM
